Author Topic: drive shaft ??  (Read 2985 times)
brandon95
  • Turtle Points: 3
  • Male Posts: 193
  • Member since Jan '08
drive shaft ??
« on: May 01, 2008, 02:20:42 AM »
Tomarrow Im going to go buy a 1985 toyota, standard cab, long bed, 22r, 5 speed, dual cases, detroits front and rear, all pro 6" springs, all pro X-over, 36" swamper TSL's and plenty of body damage :gap:.
The only problem is that the dual cases where just put in and the drive shafts have not been modified yet. So my question is how much would it cost to get the shafts modified or to get new ones made?
thanks
LOL @ IFS
  • Male Posts: 292
  • Member since Dec '06
  • Not so common common sense.
Re: drive shaft ??
« Reply #1 on: May 01, 2008, 02:33:50 AM »
Call a local driveshaft shop and ask them.  :)
Willy Mammoth
  • Male Posts: 4,252
  • Member since Nov '04
Re: drive shaft ??
« Reply #2 on: May 01, 2008, 02:56:06 AM »
Can you weld? You can do it yourself if you know how to use a cut off wheel on an angle grinder and how to weld.
You will want to move the CV shaft to the rear and the rear to the front.
If you want to try it I can tell you how I do mine without spending big bucks having a shop do it.
If not seek professional help.
Mnmstoy
  • Turtle Points: 50
  • Male Posts: 230
  • Member since Feb '05
  • Mike's 80Toy
Re: drive shaft ??
« Reply #3 on: May 01, 2008, 04:40:31 AM »
I got my rear DS retubed with new u-joint for around $160. They replaced the .076 wall metric size tube with a .096 wall standard tubing...didn't have the know how at the time or welder.
For the front...hahhaha around $350 for a new one...I did the square method instead for $40 coast of tubing.
Side not...I have sense busted the .096 rear. I now have drill stim pipe....that tube is crazy thick.....and have yet to bend it....got it for free. I did the front with my Lincon 135 and rear with a 220 stick.
Mike
here you can see my front square and rear drill stim...the paint is marked up from Rocks but it is still straight.
Also the Driveshaft shop will need to know the measurments from flange to flange to dertermine how long to make yours...you will also have to take both parts of the rear driveshaft in.
DTB
  • Shoutbox Moderator
  • Turtle Points: 2
  • Male Posts: 7,110
  • Member since Nov '05
Re: drive shaft ??
« Reply #4 on: May 01, 2008, 05:36:01 AM »
Should be 2-300 at most to redo front and rears
Quote
bigarms23
  • Turtle Points: 111
  • Male Posts: 2,897
  • Member since Jun '07
Re: drive shaft ??
« Reply #5 on: May 01, 2008, 11:53:58 AM »
should  be around 250 for both
brandon95 [OP]
  • Turtle Points: 3
  • Male Posts: 193
Re: drive shaft ??
« Reply #6 on: May 01, 2008, 01:16:10 PM »
thanks guys im going to go talk to a few of my frends that are very good welders and see if they are up for it. If not tomarrow ill go talk to some local shops.
DTB
  • Turtle Points: 2
  • Male Posts: 7,110
Re: drive shaft ??
« Reply #7 on: May 02, 2008, 05:29:31 AM »
Just be careful looking....make sure you find a competent shop with references
Quote
sabenson82
  • Male Posts: 70
  • Member since Mar '08
Re: drive shaft ??
« Reply #8 on: May 02, 2008, 07:27:57 PM »
I just had my rear DS done and it cost me $110
Build it, Break it, Build it again...STRONGER
alwayzbroken
  • Turtle Points: 603
  • Male Posts: 1,905
Re: drive shaft ??
« Reply #9 on: Aug 19, 2008, 08:19:09 PM »
Can you elaborate more on what this tube is?
Mnmstoy
  • Turtle Points: 50
  • Male Posts: 230
  • Mike's 80Toy
Re: drive shaft ??
« Reply #10 on: Aug 22, 2008, 09:08:59 PM »
The tube is made for drilling wells. After a buddy busted up his rear drive shaft. SORV was kind enough to hook him up. And I took the scraps. I later made mine.
Here is the difference between .096 (drive shaft unlimited on the right) and drill stem pipe(on the left).
The tubing is smaller but I tell you 1000 times stronger.
Mike
Last post Aug 14, 2006, 08:47:58 PM
by 89YOTER
Last post Aug 29, 2006, 07:47:06 PM
by ddement
Last post Mar 12, 2007, 07:42:05 AM
by MiniSimp
Last post Mar 20, 2008, 09:03:58 AM
by FIREBALL
Last post Jun 17, 2010, 04:44:33 PM
by 8D3TOY
