Author Topic: Electric fan measurements.  (Read 3210 times)
LOL @ IFS
  • Male Posts: 292
  • Member since Dec '06
  • Not so common common sense.
« on: Apr 30, 2008, 05:19:09 AM »
I don't have access to my truck at the moment, but I found a 14" electric fan for $45, shipped.  Thing is, it's 2.5" thick.  Will this fit between the engine and radiator in an '81?
Thanks!  I can't wait to get back so I can work on my junk.   :beerchug:
TheCookieMonster
  • Male Posts: 973
  • Member since Dec '07
Re: Electric fan measurements.
« Reply #1 on: Apr 30, 2008, 10:12:13 AM »
that should fit....there is quite a bit of room in there :thumbs:
LOL @ IFS [OP]
  • Male Posts: 292
« Reply #2 on: May 02, 2008, 05:46:18 AM »
Thanks for the info!
TheCookieMonster
  • Male Posts: 973
« Reply #3 on: May 02, 2008, 08:24:24 AM »
 :thumbs:
DeadlyPeace
  • Male Posts: 593
  • Member since Nov '07
  • HEAVILY medicated for your protection!
    • ToyotaOffRoad
« Reply #4 on: May 02, 2008, 09:15:25 AM »
I have a 3 core radiator in my 85 and my e-fan is about 2.5" wide also and I've about 3/4" to spare so you should be fine.
BTW what's the CFM rating on the fan you're looking at? I don't remember, but I think the min on a TOY is around 1,800 cfm. Anyone?
I REJECT YOUR REALITY AND SUBSTITUTE MY OWN
Never let people think you’re a horrible person and always keep the heart of a young child…
       ...I prefer mine in a jar on my desk.
3 CAT scans a MRI and some time with the shrink and it's comfirmed. I'm just not right in the head.
Global Moderator for www.ToyotaOffRoad.com
LOL @ IFS [OP]
  • Male Posts: 292
« Reply #5 on: May 02, 2008, 10:14:12 PM »
Permacool says 1600 CFM for a four cylinder, and it's a good thing I found that before I bought the fan.  I found a 14" Procomp fan for less that flows 2000 CFM.  http://cgi.ebay.com/ebaymotors/PROCOMP-14-INCH-ELECTRIC-RADIATOR-COOLING-FAN-14-BLADE_W0QQcmdZViewItemQQcategoryZ33600QQihZ016QQitemZ260233795744QQrdZ1QQsspagenameZWDVW
spc mike
  • Male Posts: 428
  • Member since Apr '08
« Reply #6 on: Jul 30, 2008, 01:48:45 PM »
Hey lol@ifs, did you end up getting that fan?? did it work out ok? let me know, because iam about to buy that same fan!
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
« Reply #7 on: Jul 30, 2008, 02:08:46 PM »
Get the biggest fan that will fit...............
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #8 on: Jul 30, 2008, 03:36:06 PM »
Or if it is one of those fans that zip-ties flat to the radiator make a fan shroud for it. It will cool it better.
spc mike
  • Male Posts: 428
« Reply #9 on: Jul 30, 2008, 03:52:50 PM »
thanks for the info guys. Also what brand temp switch are you guys using?? iam looking at the adjustable one from jegs because its inexspensive.
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
spc mike
  • Male Posts: 428
« Reply #11 on: Jul 30, 2008, 04:05:14 PM »
Thanks for the link! at about what temp do you have it kick on at? what the lowest temp it will activate on?
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
« Reply #12 on: Jul 30, 2008, 04:21:40 PM »
No idea on the temp.     I set it so that the needle stays in normal position and so it cycles on and off at idle (about 20% on time at 80 degrees outside).
It has a very large range.   I think it was 100 degrees low, and there was still adjustment left with boiling water (212).      Since it's not in the water, but next to the radiator (or fins depending on how you mount it)  It would tend to be lower than water temp.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
spc mike
  • Male Posts: 428
« Reply #13 on: Jul 30, 2008, 08:37:12 PM »
ok thanks!
aiza22
  • Member since Jul '09
« Reply #14 on: Jul 02, 2009, 08:34:29 PM »
I just want to know if how can we measure electric fan? Is it circle?
_________________
Thermostat
« Last Edit: Jul 06, 2009, 08:54:52 AM by aiza22 »
myyota
  • Turtle Points: -1
  • Male Posts: 120
  • Member since Nov '06
« Reply #15 on: Jul 05, 2009, 10:23:15 PM »
The fan is round, so you want one that will cover as much of the radiator as possible but not hang over the edges
_________________
Ceiling fan
86 4Runner
Solid Axle Swap, 5'' Of Lift, 37x12.50-15 MTR Tires, 5 Speed Manual Swap, Inchworm Duel Cases With 5.7 Gears, 63'' Chevy Springs In The Rear, 5''Trail Gear Springs In Front, Marlin Crawler Third Members, 4.88 Gears With A Detroit In The Rear, High Pinion Front With 4.88 Gears and an ARB, Downey Header, Optima Battery, Trail Gear Sliders.
Last post Oct 09, 2004, 07:26:29 AM
by abnormaltoy
Last post Dec 24, 2004, 04:02:00 PM
by KYOTA
Last post Jun 10, 2005, 12:51:48 PM
by gonzo
Last post Aug 05, 2007, 11:26:58 PM
by AaronB
Last post Jun 02, 2011, 04:05:14 PM
by 95toyrunner
