umm grease thats intersting but it would probally work well.
ok so if i use electrial grease on everything i can, and use it on the sealing the distrubuter and coil, after that, i could, use that black rubber/plastic stuff to cover all of the wires and zip tie them tight or something like that.maybe put the ecu inside the dash? i heard you could put in the glovebox, but then no glovebox for stuff haha. then the other side the fuse panel on left side could be put inside the dash too... make my own custom snorkel all the way up to the roof. the only problem i keep thinking about is on the efi engine, if i make a snorkel, i would have to run the snorkel all the time? seems how the stock air cleaner is kinda closed up, i guess it wouldnt hurt for having a snorkel hooked up all the time.
umm am lost, putting a hole in the stock air filter? is that what you mean, its plastic, i was thinking of just using the snorkel tube to connect it to where the stock tube went, and throw away the stock enclosed filter and tube, then use some type of filter on the top of the snorkel, like you said cone one.
yes it makes sense now, it will also make more sense when i do it this summer, i luv your idea kdxsr5, thanks. this should work great, good insight, i was about just but the snorkel tube into that sensor/afm and throw away the factory filter box thingy. but this is a much better idea!
die electric grease every connection. i mean every one
Started by Serenity now! Toyota Pickup/4Runner Tech 1979-95
Started by Eli Engine
