Author Topic: Critical Hi Steer install question  (Read 2154 times)
HyDesertMutant
  • Turtle Points: 6
  • Member since Oct '03
« on: Jul 09, 2004, 06:08:06 AM »
Hello! This weekend I am finally going to install my hi-steer, and I've been reading up on the issue here on various thread and over on pirate...
My question is this:  IF after everything is put together, and I have the box mounted as high and forward as I can, and there is contact with the pitman arm and spring, is there enough adjustment in the system to just install a flat or flatter pitman arm without tearing it all down, re- mounting the box and starting over?
I have The Fear.
I cant wait to install this expensive stuff thats been sitting in a crate for months in my garage and I want to do it right!
derek
  • Turtle Points: -61
  • Male Posts: 600
  • slow truck=more time to nap
Re: Critical Hi Steer install question
« Reply #1 on: Jul 09, 2004, 06:29:22 AM »
cant tell you for sure since i cant predict how your setup will turn out.
but there are flatter pitman arms you can buy.
get it mocked up first and double check it all before cutting an welding.
derek
lowgeared
  • Turtle Points: -1
  • Male Posts: 556
« Reply #2 on: Jul 09, 2004, 06:30:53 AM »
Skys and OTT sell less drop pitman arms as well as flat ones.  I have the same trouble due to too much flex.  I am also lowering the front spring hangers a bit to help.  I can't run a flat one since it will hit the frame.  I will use one of the less drop ones to keep it out of the springs.
derek
  • Male Posts: 600
« Reply #3 on: Jul 09, 2004, 06:31:50 AM »
also dont forget to leave a little room between the frame and pitman arm to clear the castle nut.
or you will have to notch the frame to clear it.
derek
  • I'm Legit!!!
  • Turtle Points: 2401
  • Male Posts: 6,715
  • Member since Feb '04
  • AKA Baja Brad
« Reply #4 on: Jul 09, 2004, 09:07:45 PM »
I don't know if it will work but it is worth a try i guess.  You can flex the truck with just the stock steering and then measure how much room you have inbetween the frame and the spring.  Then when you go to put the box on you know how much room you have to work with.
HyDesertMutant [OP]
  • Turtle Points: 6
« Reply #5 on: Jul 12, 2004, 01:48:34 AM »
Thanks for the input guys, it appears that I will no prob with the pitman arm- The problem is with the tie rod hitting the top leaves.
I figure it's on account of the damn degree shims and the problem would be solved with dropping the front spring hangers 1 inch.
I'm wondering if MarlinCrawlers front spring hanger for the SAS kit would work on a truck that already had a solid axle- an 82 truck...
Hmm mmm
  • Turtle Points: 679
  • Member since Feb '03
  • Don't blame me, I didn't vote for this crap.
« Reply #6 on: Jul 12, 2004, 01:49:36 AM »
yup it would work out just fine.
Last post May 01, 2006, 08:51:48 PM
by 79coyotefrg
Last post Feb 24, 2018, 06:05:26 PM
by dunejunkie
Last post Mar 17, 2008, 07:16:18 PM
by David
Last post Mar 05, 2009, 04:23:03 PM
by OOPS
Last post Sep 15, 2009, 09:15:13 PM
by studentwheeler
