Author Topic: Shackle angle??  (Read 4717 times)
SLIVER
  • Male Posts: 503
  • Member since May '06
  • ))--SLIVER-->
Shackle angle??
« on: Apr 16, 2008, 04:18:21 PM »
What is the optimal shackle angle? I have MC 5" springs in the rear of my 4runner and I think that I need to relocate my rear spring hanger further forward to increase my shackle angle. I am getting pretty good flex out of the rear springs, but I do lift a tire here and there. I know that this is to be expected but I would like to get the most flex out of my vehicle. I have plenty of travel in my shocks so I know they aren't the limiting factor.
So I guess my question is, what is the best shackle angle for up and down travel, my springs are broken in.
I hope my ? makes sense.
))--SLIVER-->
))--SLIVER-->
Tice
  • Turtle Points: 8
  • Male Posts: 881
  • Member since Feb '05
  • I named my son Wheeler!!!!
Re: Shackle angle??
« Reply #1 on: Apr 16, 2008, 05:33:48 PM »
I run my rear shackles at about 45* to the spring. Seems to work pretty good.
I don't need a winch, I wheel a TOYOTA!!!!!!!
www.wheelingarizona.com
MiniSimp
  • Outdoor Enthusiast
  • Male Posts: 5,120
  • Member since Jan '05
  • SimpsonBrothers.net
Re: Shackle angle??
« Reply #2 on: Apr 16, 2008, 06:15:20 PM »
My rears are set to about 25*
My fronts are set to about 35*
Both work perfect for my setup, but yours may be different.
I think having your shackle 90* or less to your spring surface is good enough if your springs have a lot of arc.
SLIVER [OP]
  • Male Posts: 503
  • ))--SLIVER-->
Re: Shackle angle??
« Reply #3 on: Apr 17, 2008, 02:56:22 PM »
Thanks for the replies guys, I'll go home tonight and see what my angle is, if it is not enough angle do you think that it would be worth it to relocate the rear hanger for the rear spring? Will the flex that I gain be enough to justify the hassle of doing it?
Thanks a ton
))--SLIVER-->
))--SLIVER-->
Ramrod
  • smelling like vag and loving it
  • Turtle Points: -59
  • Male Posts: 3,600
  • fully bodied & Fully getting it
Re: Shackle angle??
« Reply #4 on: Apr 17, 2008, 03:34:11 PM »
yes the flex will be worth it and it will ride much better also, i like my shackle to sit back pretty far
SLIVER [OP]
  • Male Posts: 503
  • ))--SLIVER-->
Re: Shackle angle??
« Reply #5 on: Apr 18, 2008, 06:23:57 AM »
I checked last night and found that my shackles are at 90* to my spring almost exactly. I don't have an angle finder but I am guessing that they are at about 20*. When I set up my lift I put them at 10* hoping that they would settle out to around 25*. What do you guys think should I move the mounts forward, or leave them?
Thanks again,
I will try to find a pic that shows a good resting position so you can see.
))--SLIVER-->
))--SLIVER-->
SLIVER [OP]
  • Male Posts: 503
  • ))--SLIVER-->
Re: Shackle angle??
« Reply #6 on: Apr 18, 2008, 06:28:49 AM »
Here is one.
))--SLIVER-->
))--SLIVER-->
SLIVER [OP]
  • Male Posts: 503
  • ))--SLIVER-->
Re: Shackle angle??
« Reply #7 on: Apr 18, 2008, 06:35:58 AM »
Here is another.
))--SLIVER-->
))--SLIVER-->
MiniSimp
  • Male Posts: 5,120
Re: Shackle angle??
« Reply #8 on: Apr 18, 2008, 06:39:11 AM »
My fronts are a little more angled than my rear, but all droop equally.
SLIVER [OP]
  • Male Posts: 503
  • ))--SLIVER-->
Re: Shackle angle??
« Reply #9 on: Apr 18, 2008, 07:04:19 AM »
Yours look close to the same angle as mine, if you think that they are good enough than maybe i'll leave them.
))--SLIVER-->
))--SLIVER-->
tom w.
  • Male Posts: 760
  • Member since Jul '06
Re: Shackle angle??
« Reply #10 on: Apr 18, 2008, 07:50:24 AM »
You have shorter shackles, don't you, Mini?
MiniSimp
  • Male Posts: 5,120
Re: Shackle angle??
« Reply #11 on: Apr 18, 2008, 08:04:35 AM »
Rears are 6" fronts are 5.25"
With the new winch and bumper I think I'll be going 6" in the front very soon. :yesnod:
88_Pathy
  • Turtle Points: 65
  • Male Posts: 1,251
  • Member since Oct '06
  • Raised suspension
Re: Shackle angle??
« Reply #12 on: Apr 18, 2008, 10:08:06 AM »
Mine were like that and I moved the mounts 1/2in and it rides a ton better.
SLIVER [OP]
  • Male Posts: 503
  • ))--SLIVER-->
Re: Shackle angle??
« Reply #13 on: Apr 18, 2008, 12:18:35 PM »
Did you notice that you got any better flex?? My ride is ok but I feel that my flex could be better?
Thanks
))--SLIVER-->
))--SLIVER-->
SLIVER [OP]
  • Male Posts: 503
  • ))--SLIVER-->
Re: Shackle angle??
« Reply #14 on: Apr 20, 2008, 02:36:04 PM »
:headscratch: I guess not :dunno:
))--SLIVER-->
))--SLIVER-->
88_Pathy
  • Turtle Points: 65
  • Male Posts: 1,251
  • Raised suspension
Re: Shackle angle??
« Reply #15 on: Apr 20, 2008, 11:08:28 PM »
A little better flex ( like 1 in more droop). But it was more for the ride. If you want flex look at lbz134s build. He cut the front clamp off the springs and took out the stinky axle wrap leaf. And wow, 42in under the rear tire, it was 24in. Oh and my rear still flexes like poo, but I need to cut the clamp off and remove the leaf still.
Rockcrawlintoy
  • 4 doors for more whores
  • Turtle Points: 2147
  • Male Posts: 2,339
  • Member since Dec '03
  • RIP Kyle
    • Buy me a soda
Re: Shackle angle??
« Reply #16 on: Apr 20, 2008, 11:27:54 PM »
i have mine kicked way back . rides great and flexes even better
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
SLIVER [OP]
  • Male Posts: 503
  • ))--SLIVER-->
Re: Shackle angle??
« Reply #17 on: Apr 21, 2008, 07:10:51 AM »
Thanks for the reply, Do you have a link to this build? I did a search and couldn't find anything.
Thanks again
))--SLIVER-->
))--SLIVER-->
88_Pathy
  • Turtle Points: 65
  • Male Posts: 1,251
  • Raised suspension
Re: Shackle angle??
« Reply #18 on: Apr 21, 2008, 08:19:44 AM »
Here it is. But if you look through the build he added an axle wrap bar to prevent axle wrap after the spring mods. But I feel that flexy leaves need an axle wrap bar anyways, And the difference in flex is worth it, almost double.
http://board.marlincrawler.com/index.php?topic=33969.90
SLIVER [OP]
  • Male Posts: 503
  • ))--SLIVER-->
Re: Shackle angle??
« Reply #19 on: Apr 22, 2008, 07:07:30 AM »
Thanks man, I will check it out. I'm headed out for Moab tomorrow so my set up will have to be good enough, for now at least. I'll start playing around with it when I get back.
Thanks again
))--SLIVER-->
))--SLIVER-->
Last post Jan 24, 2010, 09:03:12 AM
by dweinberg01
Last post Nov 11, 2012, 08:02:17 PM
by 85Flatty
Last post May 08, 2015, 04:52:21 PM
by GreenYoterKrawler
Last post Dec 28, 2016, 07:55:55 PM
by TRox
Last post Mar 19, 2017, 02:44:09 PM
by oleblue22
