Author Topic: 22re problem #2  (Read 2143 times)
2toyotas
  • Male Posts: 32
  • Member since Jan '06
22re problem #2
« on: Apr 13, 2008, 10:48:18 AM »
hey guys, im having a problem with my 22re.  first off my truck was running good with my fuel cell, it finnaly poped so i put a new motor in with all of my efi components. from the old motor.  now it will only start and stall right away unless i spray it with starting fluid.  any help would be great
new prob at the bottom of the page
« Last Edit: Apr 13, 2008, 02:54:22 PM by 2toyotas »
tech201
  • Male Posts: 141
  • Member since Jan '08
  • this is who we are this is what we do.
Re: 22re problem
« Reply #1 on: Apr 13, 2008, 10:58:20 AM »
You need to check to see if it has fuel pressure, injector pulse, possibly a loose ground somewhere stuff like that and that should point you in the right direction.
highridin4x4
  • Male Posts: 237
  • Member since Oct '06
Re: 22re problem
« Reply #2 on: Apr 13, 2008, 11:34:55 AM »
Is your intake hose from your air cleaner hooked up? My truck would do that if I had that hose unhooked. Just checking the basics.
Scott
unclejpl4x4
  • Turtle Points: 348
  • Male Posts: 3,522
  • Member since Apr '05
  • Broke & rusted
    • myspace
Re: 22re problem
« Reply #3 on: Apr 13, 2008, 12:14:22 PM »
? fuel cell / EFI   is it a vented cell or not ?
and have you pushed the pin in on the fuel rail 2 see if theres any air trapped in the fuel rail
2toyotas [OP]
  • Male Posts: 32
Re: 22re problem
« Reply #4 on: Apr 13, 2008, 12:57:41 PM »
thanks guys, im heading out now to give those ideas a shot. thanks again
2toyotas [OP]
  • Male Posts: 32
Re: 22re problem
« Reply #5 on: Apr 13, 2008, 02:15:36 PM »
and the winner is.........scott!!!  im an idiot, i didnt think you needed the intake hose for the truck to run.
2toyotas [OP]
  • Male Posts: 32
Re: 22re problem
« Reply #6 on: Apr 13, 2008, 02:17:28 PM »
now that it runs problem #2.   the truck revs up and down from about 1500 to 2200 rpm by itself, any ideas?
highridin4x4
  • Male Posts: 237
Re: 22re problem #2
« Reply #7 on: Apr 13, 2008, 04:23:32 PM »
What did I win? You arnt the first one to try running the engine with out the hose on. I have no ideas about the reving problem. Are you geting any codes from the check engine light? does it have a/c could be the idle up for it? My truck did not have a/c so I am just guessing.
Scott
toyofan7987
  • Male Posts: 124
  • Member since Jan '07
  • yoter boy till i die
Re: 22re problem #2
« Reply #8 on: Apr 13, 2008, 05:10:52 PM »
is the motor actually reving or is the guage just jumping ?
2toyotas [OP]
  • Male Posts: 32
Re: 22re problem #2
« Reply #9 on: Apr 13, 2008, 06:11:52 PM »
motor
2toyotas [OP]
  • Male Posts: 32
Re: 22re problem #2
« Reply #10 on: Apr 13, 2008, 06:38:03 PM »
wow, probs fixed.  the rev was low coolant.  thanks for all you help guys
Last post Sep 28, 2002, 06:56:19 AM
by crash
Last post Aug 24, 2005, 09:45:10 AM
by germ
Last post May 06, 2006, 12:20:45 PM
by kneedownnate
Last post Jul 15, 2008, 06:10:24 PM
by crawlerdan
Last post Oct 12, 2008, 05:50:56 PM
by Joey88RUNR
