Author Topic: RUF's and Front Springs Q's  (Read 12161 times)
fordh8r
  • Turtle Points: 850
  • Male Posts: 2,588
  • Member since Jan '07
  • when my toyota grows up it'll be just like my chevy!
Re: RUF's and Front Springs Q's
« Reply #30 on: Sep 09, 2011, 09:32:23 PM »
what are your guys thoughts on how much to cut off each individual spring?   you have your main leaf and wrap then each leaf from there after progressively get's smaller... but by how much?  does it matter?  i'd imagine the more spring you leave the stiffer the ride.   :dunno:
comments?
I don't know how much it matters as far as how much to cut off between leafs...but you'd be right in thinking that the longer they are they should be a bit stiffer. I just kinda gauged what the spread was in the stock pack and cut the 'added in' leafs to follow suit with those.  I figure it's easier to go with what's there (basically) without overthinking the whole process and adjust it later if need be.  :biggthumpup:
Shamb
  • Raisin in the making..
  • Turtle Points: 133
  • Male Posts: 3,414
  • Member since Oct '04
  • Proud Parent
« Reply #31 on: Sep 09, 2011, 10:12:53 PM »
well the only problem with that is you can always recut the springs but once they're cut your kinda screwed.. unless you wanna go locate another spring pack and do it all over again.
I'm thinking about cutting them down in 2" increments and going from there.
fordh8r
  • Male Posts: 2,588
« Reply #32 on: Sep 09, 2011, 11:12:10 PM »
That sounds like a good place to start! :yupyup:
86rustbucket
  • Turtle Points: 45
  • Member since Jun '09
    • Buy me a soda
« Reply #33 on: Sep 10, 2011, 09:13:20 AM »
I totally winged it, and basically cut them to what I thought looked good.  This is what I came up with. It is six leaves using two stock pairs of springs.    They are super soft, flex like crazy and I definately need to put bumpstops back in there.  I wouldnt be afraid go with a 7 leaf pack either, just dont try five. I tried a five leaf pack and they flattened out in no time, and were negative soon after that.
Shamb
  • Male Posts: 3,414
  • Proud Parent
« Reply #34 on: Sep 10, 2011, 10:10:39 AM »
yea i picked up a 2 leaf pack from a 94' T-100 just in case I needed to add a leaf. I'm also gonna start with a 6 leaf pack consisting of stock rears from an 87 4runner and a 89 extra cab pick up.
just got finished painting the leafs.. gotta get some 3/4" flat bar for the clamps and some grade 8 bolts. I'll post the results when i'm finished, really hoping it doesn't give me too much lift.
86rustbucket
  • Turtle Points: 45
    • Buy me a soda
« Reply #35 on: Sep 10, 2011, 10:33:09 AM »
thats exactly what I used, it seems that the springs from the 89 are a bit softer, Dont worry about getting to much lift.  I barely trimmed anything off my fenders, and I was running the same tires you are.
here's how mine sat
Mytattootears
  • Male Posts: 196
  • Member since Feb '11
« Reply #36 on: Feb 06, 2012, 06:43:16 AM »
Bump, lots of good ideas, I need more ideas and ... More like help,
MiniSimp
  • Outdoor Enthusiast
  • Male Posts: 5,120
  • Member since Jan '05
  • SimpsonBrothers.net
« Reply #37 on: Feb 06, 2012, 06:46:28 AM »
It would be easier to help if you asked a question. :yesnod:
Mytattootears
  • Male Posts: 196
« Reply #38 on: Mar 20, 2012, 10:16:58 AM »
Ok I have a question, when doing the rufs I saw that guys would say cut so many inches off the leaf but I would like to know if to cut say 2 inches on each side of the leaf or just 2 inches total
Peterbuilt84
  • Turtle Points: 12
  • Male Posts: 1,049
  • Member since Sep '09
    • Poly Goats
« Reply #39 on: Mar 20, 2012, 10:48:53 AM »
You just want a staggered pack. I can't remember how much I cut off mine, but 2 inches total wouldn't be enough.
Mytattootears
  • Male Posts: 196
« Reply #40 on: Mar 20, 2012, 12:23:57 PM »
On mine I did stock 86 4runner left the 3leafs uncut then did the next left 2inches shorter on each side to make it 4inchs total, I didn't that to the next 2 also, the leafs just look long compared to some I have seen
Peterbuilt84
  • Turtle Points: 12
  • Male Posts: 1,049
    • Poly Goats
« Reply #41 on: Mar 20, 2012, 08:58:51 PM »
Those look too long. I'd say take another inch or two off each leaf, just look at some pics of other setups. If you aren't planning on running spring clamps I'd recommend those too.
Mytattootears
  • Male Posts: 196
« Reply #42 on: Mar 21, 2012, 06:22:21 AM »
I thought they seemed long, I'm going to cut a inch more on each side, and the clamps I messed up realized I shouldn't have cut them off till it was to late, any pointers on what I should do to replace them with?
Peterbuilt84
  • Turtle Points: 12
  • Male Posts: 1,049
    • Poly Goats
« Reply #43 on: Mar 21, 2012, 09:09:14 AM »
Here's a thread on pirate with some info: http://www.pirate4x4.com/forum/showthread.php?t=1020227
Last post May 04, 2004, 11:42:44 AM
by Jimmyg
Last post Nov 11, 2004, 03:25:00 PM
by kneedownnate
Last post Apr 13, 2005, 07:37:39 AM
by TRDISMO
Last post Apr 07, 2006, 02:19:13 PM
by twerp
Last post Dec 01, 2006, 07:41:33 AM
by Gittinit
