Author Topic: High steer with 2.5in lift springs...  (Read 5052 times)
Phazertwo
  • Turtle Points: 8
  • Male Posts: 812
  • Member since Aug '05
« on: Apr 02, 2008, 07:44:06 PM »
Ok, I seem to remember reading that high steer won't work on a 85 p/u with high steer...  Is this true.  I ask because I have some 2.5in no name springs that I want to put on a 85, but I want to go highsteer at the same time...
I know that I will need an IFS PS pox, and a mounting kit, but why won't it work?
PZ
Homefries
  • Male Posts: 241
  • Member since Apr '07
Re: High steer with 2.5in lift springs...
« Reply #1 on: Apr 02, 2008, 07:54:25 PM »
Usually if you don't have more than 3" of lift, most people keep the stock steering and modify the j-arm.  No real need to have hy-steer except to move the tie rod up with that small of a lift.  I would just buy a Marlink and do a j-arm flip.   :twocents:
Phazertwo [OP]
  • Turtle Points: 8
  • Male Posts: 812
« Reply #2 on: Apr 02, 2008, 07:58:44 PM »
I am not familiar with a j-arm flip. I will have to research.  However, High steer is nice to have, and since there is a decent chance that she wants to go bigger, High steer is a good idea.  Also, if you do high steer you don't have to mess with the stupid axle link on the drivers side, which limits flex, but is necessary for the push pull system.
KDXSR5
  • Poser Shot Extraordinaire
  • Turtle Points: 61
  • Male Posts: 2,812
« Reply #3 on: Apr 02, 2008, 08:02:45 PM »
umm... I remember hearing something to the effect of wont clear the springs if under 3 inch lift, and even at 3 inch lift its iffy, and much care has to be taken to mount the box and set everything up just right for it to work. Someone that is more experienced than I please help?
Homefries
  • Male Posts: 241
« Reply #4 on: Apr 02, 2008, 08:03:55 PM »
Here is the link to that thread.  I've done it on mine with a 3" home brew lift and it works good.
http://board.marlincrawler.com/index.php?topic=33240.0
Phazertwo [OP]
  • Turtle Points: 8
  • Male Posts: 812
« Reply #5 on: Apr 02, 2008, 08:17:21 PM »
so do you still need a drop drag link with this set up?
Homefries
  • Male Posts: 241
« Reply #6 on: Apr 02, 2008, 08:24:37 PM »
Yes, that would be the best unless you want to modify the stock drag link.
REG535
  • Turtle Points: -287
  • Male Posts: 1,083
  • Member since Jul '07
  • Shes traveling to many celestial worlds
    • Buy me a cigar
« Reply #7 on: Apr 02, 2008, 08:43:59 PM »
What about no lift? would it work? i want hysteer before i lift. I dont see why it could not work without lift, i guess am missing something with hysteer, for some reason i thought you could put a hysteer on a toy without lifting it. maybe am wrong.
Phazertwo [OP]
  • Turtle Points: 8
  • Male Posts: 812
« Reply #8 on: Apr 02, 2008, 08:49:31 PM »
I guess thats what I am not getting
Can anyone explain what actually interferes, and when (ie full steer, all the time, left steer?)
« Reply #9 on: Apr 02, 2008, 08:56:33 PM »
because with hysteer  the  ifs box is used  and with no lift  the spring will be smacking the  ifs  steering box
NO  if you dont have a lift  DONT  histeer
REG535
  • Male Posts: 1,083
    • Buy me a cigar
« Reply #10 on: Apr 02, 2008, 08:58:48 PM »
Umm, i dont belive it!, you have to mount the ifs box the right way so it wont hit the springs. Am going to try it hopefully this year, and i will post what happened.
KDXSR5
  • Turtle Points: 61
  • Male Posts: 2,812
« Reply #11 on: Apr 02, 2008, 09:00:08 PM »
Did you just say you don't believe Glen?
Good luck with that :rofl2:
« Last Edit: Apr 02, 2008, 09:06:52 PM by KDXSR5 »
Homefries
  • Male Posts: 241
« Reply #12 on: Apr 02, 2008, 09:07:25 PM »
I would suggest that you take some measurements before you start disassembling your rig.   :twocents:   Good luck, take lots of pics and let us know.
Phazertwo [OP]
  • Turtle Points: 8
  • Male Posts: 812
« Reply #13 on: Apr 02, 2008, 09:12:01 PM »
so I am guessing that it works better with marlin springs and hanger because it moves it fwrd not just up??? So, it seems to me that the IFS box sits mostly above the frame...
I would think that lift springs would hit it when they are at full compression? Or is this why you HAVE to use the bump stops?
PZ
Homefries
  • Male Posts: 241
« Reply #14 on: Apr 02, 2008, 09:53:57 PM »
When you add the front spring hanger it does move the springs forward and down and also a lift spring has way more arc than the stock springs which are sometimes flat.  That is why most people don't do hy-steer unless your lift is more than 3".
The bumpstops are to keep your springs from going into a negative arc and bending the springs but it does also help to keep the spring from hitting under full compression.
KDXSR5
  • Turtle Points: 61
  • Male Posts: 2,812
« Reply #15 on: Apr 02, 2008, 09:57:56 PM »
And sometimes the stock springs are negatively arched and riding on the bumpstops like mine! :rofl:
KDXSR5
  • Turtle Points: 61
  • Male Posts: 2,812
« Reply #16 on: Apr 02, 2008, 10:05:59 PM »
Now that I think about it, I e-mailed MC :turtle: about this like two years ago, because I wanted high steer on my 85. I was told 3 inch minumum to do high steer. I will see if I can find the e-mail and get the rest of the info from it.
Lowrider
  • Turtle Points: 47
  • Male Posts: 128
  • Member since Mar '05
  • campfire wheeler
    • Yota Masters
« Reply #17 on: Apr 03, 2008, 03:45:58 PM »
It could be made to work if you dont mind limiting you uptravel to oh.... about 0.00".  :gap:
I run high steer with about 2.5-3" of lift. I have a two finger gap between my bumpstops, and the tie rod end on the pitman arm rubs the top of the driver side spring. It works good in the rocks, not so smooth on the way to the rocks.
www.YotaMasters.com
Lowered Headlights & Disco Lights!
REG535
  • Male Posts: 1,083
    • Buy me a cigar
« Reply #18 on: Apr 03, 2008, 03:48:10 PM »
Ya i guess you cant you put hysteer on at stock yota. According to allprooffroad.com, you have to have at least a 4'' lift to install hysteer.  ;)
WHITE_TRASH
  • Turtle Points: 679
  • Member since Feb '03
« Reply #19 on: Apr 03, 2008, 05:13:00 PM »
If you use bumpstops set right and a flat pitman arm you can run 2" springs with no problem.  Much nicer to drive too. :)
Phazertwo [OP]
  • Turtle Points: 8
  • Male Posts: 812
« Reply #20 on: Apr 03, 2008, 08:47:05 PM »
Thats what I am looking for!!!! THANKS!
WHITE_TRASH
« Reply #21 on: Apr 03, 2008, 09:02:18 PM »
When you mount the steering box with a flat pitman arm mount it as high as you can leaving about 1/4" between the arm and the bottom of the frame.  You'll need to notch the bottom of the frame where the castle nut for the drag link goes above the pitman arm.
Yes its a bit of work but its way worth it in the end. ;)
All_Set
  • Turtle Points: -145
  • Male Posts: 543
  • Member since Mar '04
    • Blue Ribbon Coalition
« Reply #22 on: Apr 04, 2008, 09:22:10 AM »
Won't work because unless done perfect, odds are your PS box BIG nut will hit your spring on compression.  You will need to either notch frame, buy flat or less drop Pitman arms or limit travel to prevent rubbing.  Drag link has better chance of rubbing on the spring on compression as well.
Mock it up, cycle your suspension and make sure everything clears before you weld.
The cookie cutter answer is 3"+ min.  But you can make it work with less.
WHITE_TRASH
« Reply #23 on: Apr 04, 2008, 09:29:10 AM »
If you toss the yota steering box and use a scoutII bot mounted around the motormount you can run high steer with less lift than that...  its a forward swinging box and it causes everything to clear beautifully.
Mavericks
  • Turtle Points: 2535
  • Male Posts: 256
  • Member since Apr '08
« Reply #24 on: Apr 04, 2008, 05:56:26 PM »
wait intell you get new springs otherwise you well end up tearing the steering box mount off the frame and redoing it, and that sucks.
1985 toyota SR5, 22re,  5.29's locked front and rear, duals with twin stick, longfields.
REG535
  • Male Posts: 1,083
    • Buy me a cigar
« Reply #25 on: Apr 05, 2008, 11:55:04 AM »
I wonder if i could use the scout2 box like WT said, on the stock yota. and then run the high steer like that, the only problem would be how would i make it hook up to the scout box?....
what about the chevy sagniaw box's
WHITE_TRASH
« Reply #26 on: Apr 06, 2008, 09:56:33 PM »
Check my $300 build thread in the projects section.  I have good pics of how the box mounted and how it sits in there.  If I had to do it again I'd use a stock waggy pitman arm, its closer to the length of the steering arms so it'd work the box less.
No lift high steer
Last post Jun 15, 2010, 10:13:26 PM
by jrock
Last post Jan 29, 2010, 09:37:32 PM
by GRM
Last post Jun 11, 2010, 12:04:29 PM
by motoracer
Last post Nov 13, 2010, 09:38:13 PM
by 4x4yota
Last post Jul 14, 2016, 07:27:37 AM
by H8PVMNT
