Author Topic: front shackles hitting cab mounts  (Read 2673 times)
LOckEdSolidTOy
  • Turtle Points: -1
  • Male Posts: 24
  • Member since Mar '08
« on: Mar 20, 2008, 07:55:14 PM »
i have yj springs up front on my 85 PU and marlin 4" in rear. what can i do to fix this problem, its limiting my flex
Nor Cal, just livin it & keepin it real
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
Re: front shackles hitting cab mounts
« Reply #1 on: Mar 20, 2008, 07:56:24 PM »
banana shackles or cut the body mount... what shackles are currently on there? longer than stock shackles may help depending on the severity of its current situation
yota_krawler
  • Cody Hunter
  • Turtle Points: 5
  • Male Posts: 3,379
  • Member since Oct '06
  • proud parent!!!
« Reply #2 on: Mar 20, 2008, 07:58:27 PM »
 :welcome: from nor cal, where are you from!
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #3 on: Mar 20, 2008, 08:02:04 PM »
Sky Mgf. http://www.sky-manufacturing.com/
Toyota Front Wide Body Boomerang Shackles.
Our new wide body boomerang shackles were designed so that not only do you eliminate the narrow portion of the shackle hitting the frame, but now you will also cure the second problem. The problem we saw was that under compression, the wide body shackle now hit the body mount. Instead of cutting the body mount, we decided to build a shackle that cleared it all together. Above is the Boomerang shackle kit. It includes all 4 shackle plates, 4 metric bolts, 4 lock nuts, and 4 aluminum spacers. They Are 2 inch's longer than stock, which nets 1 inch of lift.
Price- $60 Pr.
LOckEdSolidTOy [OP]
  • Turtle Points: -1
  • Male Posts: 24
« Reply #4 on: Mar 21, 2008, 04:24:09 AM »
thanks i'm hella from norcal too, Sonora as well. i already have marlin 5.5" shackles up fornt i really don't want to buy boomerang shackles, how do i go about cutting the body mounts? what about reinforcing the mounts?
tlcruiser66
  • Member since Feb '08
« Reply #5 on: Mar 27, 2008, 02:00:56 AM »
Cut that body mount and call it a day.
OOPS
  • Male Posts: 2,561
« Reply #6 on: Mar 29, 2008, 08:29:12 AM »
thanks i'm hella from norcal too, Sonora as well. i already have marlin 5.5" shackles up front i really don't want to buy boomerang shackles, how do i go about cutting the body mounts? what about reinforcing the mounts?
After flexing out for a while mine just bent enough to where they are not limiting the travel. :yupyup:
Last post Nov 20, 2005, 03:02:29 PM
by Rocksurfer
Last post Feb 19, 2006, 09:37:28 PM
by blackdiamond
Last post Apr 28, 2006, 11:17:17 PM
by medtro
Last post Apr 11, 2007, 12:24:51 AM
by rednk1980
Last post Feb 03, 2011, 08:27:30 AM
by bdcplayer_83yota
