Author Topic: toyota part numbers  (Read 63582 times)
toyota part numbers
« on: Mar 18, 2008, 08:47:16 AM »
$35-$40 for a 2-stage thermostat, Toyota P/N: 90916-03070
The stock is thermostat listed for my '85 22RE is #90916-03078
    TSB: 029032787 22R-E Engine Temperature Overshoot
    It says:
    Some 1984 pickup trucks and 1983-1984 Celica models, equipped with 22R-E engines, may experience a condition called "temperature gauge overshoot". After starting a cold engine the temperature gauge will indicate a higher than normal engine temperature for a short time just prior to the thermostat opening. After the thermostat opens, the temperature gauge will return to the normal range. A new double valve thermostat has been made available to reduce temperature gauge overshoot.
    And calls for part number 90916-03070 which according to the TSB replaces 90916-03055.
« Last Edit: Mar 29, 2012, 08:55:42 PM by 79coyotefrg »
AR80Toy
  • Turtle Points: -2
  • Male Posts: 319
  • Member since Mar '06
Re: toyota part numbers
« Reply #1 on: Mar 18, 2008, 09:05:23 AM »
1980 20R Headgasket (Toyota Part # 11115-38014)
1983 Toyota 4-Banger Completely "Stock" For now ......HeHe
Duffil
  • *lurker*
  • Turtle Points: 138
  • Male Posts: 4,844
    • PhotoBucket
« Reply #2 on: Mar 18, 2008, 06:12:56 PM »
Knuckle Cone Washers:42323-60020
Knuckle Nuts: 90170-12005
Knuckle Studs (with Torx head): 90126-12005
Outer door window trim clip: 68211-89104
79coyotefrg [OP]
« Reply #3 on: Mar 20, 2008, 05:52:16 PM »
79coyotefrg [OP]
« Reply #4 on: Apr 04, 2008, 08:04:08 PM »
for putting a  V6 detroit carrier  in a 4 cylinder diff housing
hi khagerty--
 Yes...you can adapt your V6 DSL to fit in the 4 cylinder 3rd by using "adapter carrier bearings" part number 32010X by Timken. I think http://www.greatlakeoffroad.com/ sells them.
ZUK :beer:
Duffil
  • *lurker*
  • Male Posts: 4,844
    • PhotoBucket
« Reply #5 on: Apr 05, 2008, 05:20:27 PM »
I found my part number book :yupyup:
2nd Gen Pickup/ 1st Gen 4Runner heater valve cable: 55907-89116
6mm bolt--head to timing cover: 91611-60855
Valve Adjuster Screw: 90913-05019
Valve Adj. Screw Locknut: 90179-08049
Brass SFA Spindle Bushing: 90999-70067
Rear Axle O-ring: 90301-88077
Hub Cone Washers:42323-60010
Duffil
  • *lurker*
  • Male Posts: 4,844
    • PhotoBucket
« Reply #6 on: Apr 05, 2008, 05:21:54 PM »
G-Series Trans parts:
Front Cover Gasket: 33132-28010
Intermediate Plate Gasket: 33138-28020
Input Shaft Seal: 90311-30115
Tcase Seal: 90311-38140
Duffil
  • *lurker*
  • Male Posts: 4,844
    • PhotoBucket
« Reply #7 on: Apr 25, 2008, 05:50:48 PM »
2nd Gen Horn Contact Button: 84312-20011 (not sure if it's the same for others though)
Duffil
  • *lurker*
  • Male Posts: 4,844
    • PhotoBucket
« Reply #8 on: May 03, 2008, 09:40:23 PM »
2001 4Runner 3.4L
Here is the Toyota part number for the wires: 19037-62010
Here is the Toyota part number for the spark plugs: 90919-01192
The wires should be correct for ALL 3.4L V6s, double check the plugs unless you have an 01.
Duffil
  • *lurker*
  • Male Posts: 4,844
    • PhotoBucket
« Reply #9 on: May 18, 2008, 08:21:23 PM »
2nd Gen Headlight adjuster screws: 81131-89103
  • Turtle Points: 2872
  • Male Posts: 8,707
« Reply #10 on: May 19, 2008, 02:55:31 AM »
Redbeard1
  • Turtle Points: 54
  • Male Posts: 414
  • Member since Mar '07
    • Project Pete
« Reply #11 on: Jul 20, 2008, 10:59:23 AM »
Not a Toyota part number but If you cant find Toyota injector harness pig tails to replace the ones that are so easely broked on 22re injectors here is a general motors part number with better weather seal boot that will work.
I used these to replace all 5 of the injector plugs on my truck while I was doing the engine swap they will also work for about half of the other sensors on the engiine.
GM part # 12085491
Discription: Connector
If you dont stand behind our Troops... you can stand infront of them...
Project Pete==> http://board.marlincrawler.com/index.php?topic=43370.0
85 Toy: Built 22re, locked F, spooled R, 5.29's, R151F, MCO7 duals, Sky x-member 37 MT/R's on jack stands
 __________________________________________
||____________||____________||___TOYOTA ___||
||____________||____________||_____________||
RIP Bobby Long
79coyotefrg [OP]
« Reply #12 on: Aug 15, 2008, 09:45:21 AM »
passenger side second gen frame/shock mount
sixonthefloor
  • Male Posts: 17
  • Member since Jan '08
  • fix or replace often
« Reply #13 on: Aug 21, 2008, 06:25:24 AM »
ENGINE RELATED
22R
gas tank pickup tube assy (longbed tank) 77203-35141 $26
engine insulator (t-case mount) ’83 12371-38020 $85
NOTE: The insulator/mounts vary through the years. They look similar, but are different.
22R rebuild gasket set (pre 8/84) - 04111-35022
22R oil pump O-ring - 15188-38030 $9.95
22R front crank seal - 90311-45014
22R oil pan gasket - 12151-35010
22R/RE idler pulley bearing - 90099-10091 $6.95 - or IR Torrington 6204PP, SKF 6204-RSJ, NSK 6204V, CR (Chicago Rawhide) 6204-2RSJ
22R/RE A/C idler pulley bearing - SKF/CR 6203-2RSJ $6.95
Crankshaft Oil Seal (Rear main seal) - 9031180010 $26.58
1986-1995 In-Line4
22Rxx cam rocker spacers 90561-16005
valve cover gasket/seal set - FelPro VS50357R $15.00 (should fit 22RE too)
- - Or separately from dealer:
gasket - 11213-35010
seals (for thru-bolts) 90210-08026
semi-circular plug - 11183-38010
PVC grommet - 90480-18180 $ 2.14
Carb components for Aisin, dealer only (Feb, 2006)
Float assembly 21209-37041 approx $26
Jet, first main 90999-41116 approx $8
Jet, second main 21253-35410 approx $8
Jet, S/A, slow 21205-35410 approx $10
Spacer, carb to intake manifold 21912-35050 approx $20
FOR LATE 22R – (after 8/84)
timing chain cover 11302-38010 $282.65
timing chain guide, long - 13561-35010 $ 25.04
timing chain guide, short - 13562-35010 $ 18.35
timing chain tensioner assy - 13540-35011 $ 54.82
Rocker Arm Valve Adjusting screw - 90913-05019 $2.86
lock nut for above - 90215-42025 $1.07
water pump stud - 92122-60622 $ 1.14
water pump bolt/washer - 91651-60628 $ 1.03
water pump nut - 90179-06159 $ .43
22RE
Plate, Eng (22R-E valve cover sticker) - 11291-35040 $1.19
EGR GASKETS for 22RE -
EGR Valve and Lower Plenum Intake Assy to Engine Block (One piece) Gasket. - 17177-35050
{Note: This gasket can be cut to make two separate gaskets.}
EGR Valve to Engine Block only Gasket. - 25627-38011
Intake manifold to head gasket - 17177-35050
Plenum to intake manifold gasket - 17176-35020
EGR inlet gasket - 25628-35011
NOTE: The intake man. to head gasket comes complete with the EGR outlet gasket, there is no longer a separate gasket for the EGR outlet. The last year they were produced is 1977.
Valve cover gasket (Toyota calls it the "cylinder gasket") - 11213-35010 ($8.91)
Valve cover grommets (Toyota calls them "washer, seals") - 90210-08040 ($1.07 ea, you need 4)
1986-1995 In-Line4
Gasket, exhaust (donut, manifold to down pipe) - 90917-06038, 06045
bolt, stud (for above) - 90116-10019
nut (for above) - 90179-10070 or 90179-10175
bolt, washer for heat shield 90105-08112
Harmonic Balancer Repair Sleeve (Speedy Sleeve): FelPro 16214
Oil Pressure Sender - Gauge Type: Toyota 83520-35030
Alternator Brushes: Toyota 27370-35060
Fan Shroud: Toyota 16711-35020
Belt, Power Steering: Toyota 99332-11120-78
Belt, AC: Toyota 99332-10890-78
Oxygen Sensor: Toyota 89465-19265
Oil Dip Stick: Toyota 15301-35020
Cold start injector gasket> 23293-35020
Valve Adjusting Screws --> 90913-05019 ($2.49 ea, need 8)
TPS (throttle position sensor) 89452-14050 ~ $99
BVSV (bi-metal vacuum switching valve) 25820-13020 ~ $79
3VZE 3.0V6
Fuel Filter - 23300-65010 or 23300-65020
Air Filter - 17801-70020
Oil Filter - 90915-20001
Spark Plug - 90919-01176
Distributor Rotor - 19102-61246
Distributor Cap - 19101-65010
Rotor, Dist cap - 19102-61240
Spark Plugs (1.17) - 90919-01176
Cord Set, Plug Wires - 90919-21501
Plate, Engine Label (3.0 EFI, top plenum) - 11291-65010
Gasket Kit, Engine (all the goodies, top end) - 04111-65018
Head Gasket Kit (complete upper) - 04112-65018
FIPG, oil pan/camshaft hsg (form in place gasket) - 00295-00102
Air Flow Meter Gasket - 22275-41010
Gasket, Oxygen Sensor - 89466-20020-83
Cyl Head Bolts - 90910-02075
Cyl Head Bolt Washer - 90201-11018
Oil Pump Assy, Eng Fr Cvr - 15100-65020
Exhaust manifold, #2 (drivers) - 17110-65012
Exhaust manifold (pass) - 17141-65011
Exhaust Crossover - 17106-65010
Wire, Knock Sensor (sensor to harness) - 82219-89103
Knock Sensor - 89615-20010
Sender, Oil Pressure - 83520-35030
Sensor, Throttle control (TPS) - 89452-12040
tps - 89452-20050 $71.42
Igniter assy - 89621-30010
Thermostat - 90916-03079
Water Pump assy, cooling - 16100-69225
Hose, Air Cleaner (tb-jct box) - 17881-65011
Hose, Lower Rad to Thermostat (No. 2) - 16572-65010
Hose, Oil Cooler to Therm bypass - 15778-65010
Hose, Air intake, T-body to elbow - 17881-65011
Hose, Oil Cooler to Block (short U turn) - 15777-65010
Grommet, PCV hose (pass side valve cover) - 90480-18001
EGR Vacuum Modulator - 25870-65010
Hose to bottom of EGR Mod - 25695-65010
O2 Sensor (w/gasket) - 89465-39325
Engine Wiring Harness - 82121-89230
Oil Drain Plug Gasket - 90430-12028
Valve Cover Gasket - 11213-65010
Intake Plenum Gasket - 17176-65020
Valve Shims - 13753-65780
Valve shims - 13753-65600
Valve shims - 13753-65760
Injector O-Ring - 90301-23004
Fuel Damper - 23207-65010
Fuel Injector - 23209-65020
Timing Belt assy Parts
Timing Belt - 13568-69055
Timing Belt, Spring Tensioner - 13568-69055 - 90 to 94 (ish)
Bolt, T-belt hyd Tensioner - 13556-65010 - 1994 & up
Washer, T-belt hyd Tensioner bolt - 90201-10117 - 1994 & up
Hyd T-belt Idler Tensioner Assy - 13505-65040 - 1994 & up
T-belt Idler Assy (top w/water neck) - 13503-65010 - All
Timing cover assy - 11303-65020 - 1994 & up
Timing Belt, Hyd Tensioner - 13568-69075? - 1994 & up
Fuel System
Bracket, Fuel supply, tank top - 23206-35121
Gasket, Fuel Suction - 77169-14010
Screw, tank top supply - 90159-50157
Screw, Fuel inlet to body - 90159-60032
Hose, Fuel, short flex tank top to line - 23091-35030
Fuel Gauge Sending unit - 83320-80127
Fuel Pump, Nippon Denso - 23220-16190
Fuel Pump, Aisin - 23220-16084
AXLES / STEERING / BRAKES
1985 4runner
2005 Tacoma
sixonthefloor
  • Male Posts: 17
« Reply #14 on: Aug 21, 2008, 06:27:15 AM »
FRONT
to 85 (solid axle)
Toyota solid pinion spacer P/N 41231-39010
Shims:
90564-30035 .25mm
90564-30193 .30mm
90564-30194 .35mm
90564-30195 .40mm
pwr steering gear box gasket kits
04455-22010 - $48
04455-22021 - $62
drag link dust seal - 45447-35020
Cone washers for solid axle steering arms - 42323-60020
Knuckle Stud, Hex - 90126-12005 $1.57 EA (12MM stock SA steering arm stud)
Nut for above stud - 90170-12005
Washer for above nut - 42323-60020
diff gasket (8”) - 42181-35010 $2.50
diff drain plug gasket - 12157-10010
Magnetic drain plug, allen head, 8" diff - 90341-18021
Breather plug 8" axle - 90404-51319
Filter for extending diff breather - 90930-03136
3rd member mounting studs:
long (total of 2) - 90116-08226
Short (total of 8) - 90116-08235
Nuts for above - 90170-08204
Washers for above - 94512-00800
84+
Bolts, diff flange to DS --> 90105-10085
Nuts for above bolts --> 90080-17239
Lock ("Spring") washers for above bolts --> 90204-10002
SA (locking) hub gaskets:
body - 43422-60010 $1.00
cover - 43422-60011 $1.00
Locking hub dial o-ring - 43532-60010
Locking hub cover gasket - 43531-60010
Locking hub body gasket - 43422-60020
Locking Hub Handle Seal: - 90311-62001 ($10.19)
caliper pistons
small - 47732-30010
large - 47731-30020
caliper seal kits - 04479-30030, 30021
Birfield outer snap ring - 90520-28036
Birfield inner snap ring - 90520-27091
Outer axle snap ring - 90520-31001
54mm nut - 43521-60011
front axle thrust washer - 90214-42030
front axle lock washer - 90215-42025
front wheel bearing seal - 90313-93011
front wheel bearings/races :
- - Timken / Federal Mogul / BCA
Front wheel outer - LM102949 & LM102910
Front wheel inner - JLM104948 & JLM104910
Knuckle bearing/race set - SKF 30303J2
front inner (axle) seal – Timken/BCA/FM – 710070, CR – 12810, Toyota – 90311-33085
front outer (hub) seal - Timken 226285
brass spindle bushings - 90999-70067
Complete knuckle wiper kit including: outer retainers , felt, rubber and Cadium plated scraper seal.
Toyota - 43204-60020, $28.83 as of 03 May 04 for one side of a knuckle for a solid axle.
86+ (pre_Taco) (IFS)
IFS Axle
2 - Inner Bushing, Fr axle shaft (Lg) - 90381-30006
2 - Outer Bushing, Fr axle shaft (Sm) - 90381-30003
2 - Inner Bearing, Fr wheel (Lg) - 90368-49084-77
2 - Outer Bearing, Fr wheel (Sm) - 90368-45087-77
2 - Seal- Axle shaft, front - 90316-60002
2 - Seal- Hub Brgs, front - 90311-66001
inner rear axle seal 90313-48001 $3.25
outer rear axle seal 90310-50001 $3.95
Manual Hub o-ring for knob - 43532-60010 $2.54 (should fit SA hub too)
Manual hub gasket - 43422-60010
CV Shaft end clips 9052029028
IFS Differential
1 - Seal, Fr diff shaft - 90311-35032
1 - Snap ring- fr axle out - ?96152-00280
1 - Snap ring- fr axle inr - ?90520-33008
2 - Brg, Fr diff needle, carrier - 90364-33009
2 - Snap ring- fr axle tube,brg - 90521-29002
5 - Lock Plate, Fr diff - 41222-35030
1 - Brg- diff side gear tube - 90369-36009
1 - Seal - diff side gear tube - 90311-35032
1 – O-ring- diff axle tube - 90301-68003
2 - Brg, Side diff Carrier (special to vin) - 90368-50006
Front brake pads (V6) - 04465-YZZA6 $31.45
Front Brake Anti-Rattle Spring - 47748-60010
REAR
Shims:
90564-30035 .25mm
90564-30193 .30mm
90564-30194 .35mm
90564-30195 .40mm
to 85
diff gasket (8”) 42181-35010 $2.50
diff drain plug gasket 12157-10010
Magnetic drain plug, allen head, 8" diff 90341-18021
Breather plug 8" axle 90404-51319
Filter for extending diff breather 90930-03136
84+:
86+ (pre-Taco)
Retainer Bushing - 42423-20010
Bearing, axle - 90363-40020-77
Snap ring, axle shaft - 90520-36045
Seal, axle shaft - 90310-50001
O-ring, axle shaft - 90301-88077
Lock Plate, Rear diff - 41222-35020
Seal, Pinion, Diff - 90311-38047
Parking Brake Rear Cable Assembly - 46420-35500
V6 Brake Cylinder - 47550-35190
Brake Line, Left Side - 47325-35170
Brake Line, Right Side - 47324-35160
[b/]T-CASE/TRANNY
21 SPLINE GEAR DRIVEN
t-case shift lever gasket - 36146-35010
t-case output seal - 90311-38140
t-case input seal - 90311-32001
t-case/tranny gasket - 36146-35010
Transfer case output seal - 90311-38016 $4.96
Mag. drain plug for tranny - 90341-18057 $8.03
fill plug t-case works for tranny too - 90341-18006 $3.32
gasket for t-case & tranny plugs - 90430-18008 $1.09
snap ring that holds in t-case lever - 90521-49003 $1.74
tranny shift lever:
Socket - 33548-31010 $4.26
Seat - 33505-35020 $11.64
The seat and socket fit all: '81-'82 L45, 50; '83 L52 ; '84-'85 G52 ; '85-'87 G54;
'89-'95 G58 ; '85-'95 W56 ; '96-'03 W59 ; '86-'87 R151F ; '88-'03 R150F
The seat and socket will not fit the '79-'80 L43.
MISC
glovebox label, 4WD info 36369-35030 $ 7.37
1ST GEN P/U
2ND GEN P/U / 1ST GEN 4RUNNER
Sheet, Heater CNTL(sticker) 81942-89102 $ 3.30
Heater Fan Coil Resistors: Toyota 88635-89103
console lid assy, gray - 58925-89101-13$ 54.10
door window weatherstrip - 68160-89116 $ 8.70
(outside, w/clips) is this w/ or w/o vent window ?
4Runner tailgate window w/o heat - 68131-89101 $74.45
cable assy for 4Runner passenger seat release - 72210-89105 $30
Headlamp adjusting screw - 81131-89103 $2.46
Grille retaining clips - 90467-12008
Rear spring hanger 89-95 left side - 48415-35050
Rear spring hanger 89-95 right side - 48414-35120
Factory Service & Owners Manuals:
Toyota Material Distrib Ctr
750 West Victoria ST
Rancho Dominguez, CA 90220-5538 or
Compton, CA 90220-5503
1-800-622-2033 (M-F, 7-5 PST)
1-800-443-7656 (in CA)
89 Toy Pickup 22re
- TPS (throttle position sensor) 89452-14050 ~ $99
- BVSV (bi-metal vacuum switching valve) 25820-13020 ~ $79
-   PVC Valve "Valve Sub-Assy." 12204-35040
-   1993 toyota truck 4x4 sr5 xtracab 3.0l v6
engine wire harness-82121-35261 $514.78
1990 3.0 V6 auto 4x4:
85910-35010 Relay, Circuit Opening
90987-02004-83 Relay, EFI (engine compartment fuse box-round )
79-83 Lo-Med-Hi verticle blower switch: 84732-89105. Currently $33.72
Just went to the dealer and got me the knock sensor and the wire, it seem that the part # listed is incorrect or if I was looking at certain year model so I like to address that the knock sensor part # is 89615 -50010 and the wire part # is 82219 - 35010, this is toward to the 1992 4runner, I don't know if it will be the same as those 89 to 91 but I believe it will fit most of those 2nd generation 4runner.
TOYOTA HILUX GEAR DRIVE TRANSFER CASE 21-SPLINE (RF1A)
QTY: PART NO: DESCRIPTION: I.D. NO: ALT ID NO: SIZES:
1 90363-35009VP BEARING, INPUT SHAFT, FRONT 6307N 6307ZNR
1 90364-19006VP BEARING, INPUT SHAFT, REAR, NEEDLE 19 X 31 X 23.6
1 90364-45002 BEARING, OUTPUT SHAFT, FRONT, NEEDLE 45 X 51 X 30.6
1 90363-40007 BEARING, OUTPUT SHAFT, FRONT 6308N 6308NR
2 90364-35001VP BEARING, OUTPUT SHAFT, REAR, NEEDLE KT354216 35 X 42 X 16.6
1 90363-28002 BEARING, OUTPUT SHAFT, REAR 63/28 28 X 68 X 18
3 90360-06004 BALL, OUTPUT SHAFT SB1/4 1/4"
1 33481-22010 GEAR, SPEEDOMETER, OUTPUT SHAFT
1 33482-39045 GEAR, SPEEDOMETER DRIVE, NYLON
2 90201-20005 WASHER, FLANGE
2 90179-20001 NUT, FLANGE
1 90363-32006VP BEARING, COUNTER SHAFT, FRONT 83A400 63/32NR 32 X 75 X 20
1 90369-45001VP BEARING, COUNTER SHAFT, REAR, NEEDLE 45 X 55 X 20
1 90365-38001 BEARING, IDLER SHAFT, FRONT 038RUSS1
1 90363-30012VP BEARING, IDLER SHAFT, REAR HR6306NX2 6306ZNR
1 90363-30014 BEARING, FRONT DRIVE GEAR, FRONT 6307N 6307ZNR
1 90369-45001VP BEARING, FRONT DRIVE GEAR, REAR, NEEDLE 45 X 55 X 20
1 90311-32009 SEAL, OIL, ADAPTER 32 X 52 X 11
1 90312-48001 SEAL, OIL, INNER 48 X 62 X 6
1 90311-38140VP SEAL, OIL, REAR FLANGE 38 X 58 X 11
1 90311-38016 SEAL, OIL, FRONT FLANGE 38 X 58 X 11
1 90303-38010 SEAL, FELT, FRONT FLANGE
1 33145-30010 RETAINER, FRONT FLANGE SEAL
1 36146-35021 GASKET, ADAPTER TO T-CASE
1 36143-35010 GASKET, REDUCTION TO FRONT HOUSING
1 36141-35010 GASKET, FRONT TO REAR HOUSING
1 36145-35010 GASKET, EXTENSION HOUSING
1 36153-35010 GASKET, FRONT RETAINER HOUSING
1 84222-35020 SWITCH, 4X4 DETECTION
2 90341-18006 PLUG, FILLER / DRAIN
1 90341-18057 PLUG, DRAIN, MAGNETIC
1 36304-35H20 HOUSING, T-CASE LEVER + GASKET
1 36360-35031 LEVER, T-CASE + BOOT
1 90521-49003 RING, SNAP
1 36303-3503001 KNOB, T-CASE LEVER
10 90119-10128 BOLT, L = 47mm
2 90119-10245 BOLT, L = 49mm
7 90119-10066 BOLT, L = 37mm
4 90119-10130 BOLT, L = 112mm
This is the Toyota Part number for the bearing and dust cover that gets pressed on the side shaft of a non-ADD IFS front diff.
Bearing: 90369-36009
Dust cover: 41336-28010
1985 4runner
2005 Tacoma
Duffil
  • *lurker*
  • Male Posts: 4,844
    • PhotoBucket
« Reply #15 on: Sep 05, 2008, 09:21:44 PM »
1st Gen windshield gasket:56121-89114
1979 2WD fuel sender: 83320-39176
79coyotefrg [OP]
79coyotefrg [OP]
« Reply #17 on: Nov 02, 2008, 09:22:45 AM »
koyo inner and outer bearings  LM102949, JLM104948
                             race       LM102910, JLM104910
i would only use the koyos myself  :twocents:
79coyotefrg [OP]
« Reply #18 on: Nov 24, 2008, 05:32:40 PM »
part number for the VSV (2wd and 4wd ADD) on the wifes 1999 4runner with the V6, it is the blue one on the drivers side fender well.
85440-35010 084800-1631
Tallchevy
  • Turtle Points: 236
  • Male Posts: 3,562
« Reply #19 on: May 07, 2009, 11:53:41 AM »
This is the part # for the bolts that attach the fuel lines to the fuel filter on a 22RE. Toyota calls them  bolt, union but they are called banjo bolts.
Part # 90401-12097
87 4Runner redo
bng1
  • Member since Jul '09
« Reply #20 on: Jul 09, 2009, 06:58:54 PM »
Here is the Toyota Part Numbers for general service on a 22R Turbo Engine
90915-YZZD1 - Oil Filter - List Price $5.41
90341-12011 - Oil Pan Drain Bolt Washer - $1.23
11213-35010 - Valve Cover Gasket - $14.20
90210-08026 - Valve Cover Grommet - $4.34
12204-35040 - Valve Cover PCV Valve - $5.37
19101-35190 - Distributor Cap - $16.15
90099-14090 - Distributor O-Ring - $3.77
19102-73021 - Distributor Rotor - $10.04
90919-21431 - Spark Plug Wires Set - $65.17
90919-01064 - Spark Plug - $2.12
16100-39346-83  - Water Pump - $94.56
90916-03078 - Thermostat - $15.13
16341-35010 - Thermostat Gasket - $2.43
11183-38010 - Crank Plug - $10.17
23300-39035 - Fuel Filter - $39.38
22271-35011 - Throttle Body Gasket - $2.89
99331-10870-83 - Alternator Belt - $7.13
99332-11120-78 - Power Steering Belt -$12.93
99332-10880-78 - A/C Compressor Belt -$12.63
17801-70010 - Air Filter
Smog Reference:
18450-35100 - Catalytic Converter - $599.81
89465-29076 - o2 Sensor - $145.29
25620-35160 - EGR Valve - $189.63
25690-35030 - EGR Vacuum Modulator - $92.03
bng1
« Reply #21 on: Jul 09, 2009, 07:01:49 PM »
Good reference to look up any Toyota vehicles on this Toyota Part Factory Catalog
Give you list prices, pictures and part numbers. Also a good source as a semi service manual on where bolt and connect parts to.
http://www.toyodiy.com/parts/
baja2oy
  • Member since Mar '08
« Reply #22 on: Aug 07, 2009, 07:17:41 PM »
GM part # 12085491
on toyota and lexus connector they usually have a five number stamp on the back of them and if you ad this other five number in front 90980-xxxxx is usually the part number for that connector not all connectors have those five numbers
« Last Edit: Aug 22, 2009, 09:15:50 AM by 79coyotefrg »
79coyotefrg [OP]
« Reply #23 on: Sep 05, 2009, 01:23:51 PM »
BUDDERS
  • Turtle Points: 15
  • Male Posts: 1,335
  • Member since Jul '05
« Reply #24 on: Nov 11, 2009, 02:05:42 PM »
And if your looking for anything else, go to ToyoDIY.com.  They have all the parts microfiche and parts numbers that you should need.  The only thing it doesn't tell you is if a part superseeds to a different number.
Muddytazz
  • Turtle Points: -10
  • Male Posts: 396
  • Member since Jan '11
  • I hear voices in my head!
« Reply #25 on: Jan 23, 2011, 01:19:24 PM »
I need to find all the parts and/or numbers for a 22R emission stuff.  Previous owner yanked it all and I need to put back on to pass emissions.
Build it right or get off the trail
Tallchevy
  • Male Posts: 3,562
« Reply #26 on: Apr 14, 2011, 11:10:02 AM »
8" Toyota e-locker shift fork p/n 41451-60020
87 4Runner redo
79coyotefrg [OP]
« Reply #27 on: Aug 21, 2011, 08:46:42 PM »
Today at 09:39:19 PM Rockcrawlintoy – Shock towers- '88 F250 shocks towers (part number E5TZ-18183A) purchased from Harold Ford in Sacramento ($10.85/ea).
Antihero1974
  • Male Posts: 15
  • Member since Nov '10
« Reply #28 on: Oct 06, 2011, 12:00:17 PM »
Found these #'s today:
4353160010 & 4342260010 Gaskets for manual hubs (star shaped gasket and round gasket behind hub body)
4343560011 Gasket between spindle and steering knuckle
4343660011 Gasket between brake dust cover and dust seal
These where for an 83 pickup front axle
Hope this helps someone? It sure helped me!  :thumbs:
83 Truck, Marlin L52 Tranny, 4" front, F150 Rears, High Steer, Stock Gears, No Lockers, 02 4Runner Seats, AKA Money Pit!
REG535
  • Turtle Points: -287
  • Male Posts: 1,083
  • Member since Jul '07
  • Shes traveling to many celestial worlds
    • Buy me a cigar
« Reply #29 on: Mar 05, 2012, 07:38:00 PM »
90401‑12097?, am looking for a bolt that bolts the fuel filter to the fuel filter bracket? Am missing the bottom one, unless I find it tomorrow, i will need another. Thanks
Last post Jun 10, 2006, 08:22:37 AM
by Weldo
Last post Nov 13, 2012, 10:45:41 PM
by NorCalPR
Last post Jul 13, 2009, 02:08:53 PM
by Dr.Maxwe001
Last post Jul 04, 2020, 07:30:57 AM
by Hickory Nut
Last post Feb 13, 2022, 03:08:12 PM
by dweinberg01
