Author Topic: r150f chipped transmission gear  (Read 5005 times)
RN37DD
  • Male Posts: 742
  • Member since Apr '07
« on: Mar 17, 2008, 02:49:23 PM »
after inspecting the counter gear on a r150 i discover 1 tooth on the gear thats driven by the input shaft ,has a small .10 chip. everything else looks perfect. should i use it? i could buy a complete used r150f cheaper than a counter gear from Toyota.
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
Re: r150f chipped transmission gear
« Reply #1 on: Mar 17, 2008, 10:39:31 PM »
Chipped teeth on gears are funny things, some last forever while others go out right away. Do you feel lucky!!!!!! :yupyup:
  • Turtle Points: 7571
  • Male Posts: 3,561
    • emsvitil's album
« Reply #2 on: Mar 17, 2008, 10:45:42 PM »
Post a picture of the chip.
Some chips can be dremeled smooth and are fine................
RN37DD [OP]
  • Male Posts: 742
« Reply #3 on: Mar 18, 2008, 09:52:08 AM »
OK I'll try to get a picture. i may have a lead on another r150f core i can part out.. if not i guess i just run this and hope for the best. anyone know where a cheap r151 counter gear is..?  I've got a good 4.31 first gear.
« Last Edit: Mar 18, 2008, 10:24:39 AM by rn37dd »
  • Male Posts: 3,561
    • emsvitil's album
« Reply #4 on: Mar 18, 2008, 01:02:53 PM »
I'd just dremel that smooth (so there's no possibility of a hairline crack propogating) and call it good.
That area is outside of the teeth contact area when the gears mesh (if you look close you can figure out where the teeth contact).
RN37DD [OP]
  • Male Posts: 742
« Reply #5 on: Mar 18, 2008, 01:52:56 PM »
 OK i'll do that.  i cleaned it up with the dremel being careful not to hit the other tooth. it's constant mesh so with any luck it should be good. now i got to run it just to see if it works.
« Last Edit: Mar 18, 2008, 02:00:47 PM by rn37dd »
OOPS
  • Male Posts: 2,561
« Reply #6 on: Mar 18, 2008, 02:53:37 PM »
It may have a tick/click but I would run it.
RN37DD [OP]
  • Male Posts: 742
« Reply #7 on: Mar 18, 2008, 03:01:24 PM »
guess I'd better get some headers so i don't hear the clicking and ticking.
dropthattaco
  • Male Posts: 49
  • Member since Feb '08
  • Deep in thought.
« Reply #8 on: Mar 20, 2008, 06:29:56 PM »
Hell, with headers, you'll probably hear more ticking!! :yupyup:
cause headers often lead to exhaust leaks, get it?!?!?
RN37DD [OP]
  • Male Posts: 742
« Reply #9 on: Mar 21, 2008, 08:58:42 AM »
well that's why ya run em open!  :burnout:  :biggthumpup:
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #10 on: Mar 22, 2008, 12:08:07 PM »
As long as it is just a chip and not cracked you should be fine, I have a chip out of 5th in mine and except for the clicking it makes everytime it passes I've had no issues. Granted with the big tires and stock gears I rarely hit fifth but it works fine.
Last post Jan 08, 2003, 01:57:01 PM
by tntdes
Last post Dec 07, 2004, 06:50:55 PM
by Sluice Box Hero
Last post Jul 10, 2008, 11:29:09 PM
by LONGDROP
Last post Jan 14, 2010, 08:31:02 AM
by Yota87Truck
Last post Jun 17, 2020, 02:13:47 AM
by Silverlegacy
