Author Topic: Trouble with Steering setup.  (Read 2369 times)
Crawler677
  • Turtle Points: -43
  • Male Posts: 324
  • Member since Oct '05
  • BRRAaappp!
« on: Mar 14, 2008, 05:52:10 PM »
I am finishing up my SAS and need to order lines and fittings for the Powersteering. i am planning on running -8AN russel powerflex hose and russel fittings and hose ends. but i need to know what the ports are on the steering box and pump, the pump is from a 99 tacoma w/ 5vzfe. and the box is your standard SAS used early 90's IFS box. what are the bore and thread pitch of these?
Ramrod
  • smelling like vag and loving it
  • Turtle Points: -59
  • Male Posts: 3,600
  • Member since Jan '05
  • fully bodied & Fully getting it
Re: Trouble with Steering setup.
« Reply #1 on: Mar 15, 2008, 05:12:12 PM »
you could also just use a stock toyota ps line from a 89-95 3.0 truck or 4runner.  if your set on using the aftermarket stuff look in the toyota faq on pirate
Crawler677 [OP]
  • Male Posts: 324
  • BRRAaappp!
« Reply #2 on: Mar 15, 2008, 07:53:07 PM »
sweet found it there. thanks a bunch, while im at it. does anybody here have a 99 tacoma that know or would measure the angle of there output shaft? i need to figure out exactely where this FROR crossmember needs to sit so i dont get any vibrations.
lbz134
  • Male Posts: 105
  • Member since Feb '07
« Reply #3 on: Mar 15, 2008, 08:19:12 PM »
Dont think there is an exact angle??  Might as well tuck it up as much as possible.  You'll have more vibs no matter what you do.. unfortunatly :sad2:
DrCoop   :flamer:
THE NOW KNOWN AS "SOFT TACO" BUILD
http://board.marlincrawler.com/index.php?topic=33969.0
Ramrod
  • Male Posts: 3,600
« Reply #4 on: Mar 16, 2008, 07:32:43 PM »
not really ^  lift it as high as you can and then point your rear pinion at it and run a cv rear driveling any you'll be nice and smooth. ive taken mine up to almost 100mph a few times
kiyul4130
  • Brown Star Award
  • Turtle Points: 279
  • Male Posts: 3,265
  • Member since Jul '05
  • Turdburgalin since 1985
« Reply #5 on: Mar 16, 2008, 07:51:25 PM »
bingo, its all about the pinion or CV, an mine is complete :pokinit: right now!!!
-kiyul-
ECV 7-11
KYOTA FOREVER
Last post Apr 14, 2004, 08:19:02 PM
by toyotaboy
Last post May 14, 2004, 12:24:34 PM
by BMFN_TOY
Last post Mar 15, 2005, 05:08:01 AM
by Bloomcounty
Last post Nov 22, 2015, 09:41:06 PM
by crazymoritz97
Last post Nov 18, 2013, 06:02:12 PM
by crazymoritz97
