. A quality manufacturer will give you many years of reliable use if they are set up properly.
how are 4.88's???
It's not the pinion that is weaker it, its the stress exerted onto the teeth that is higher. With a numaricly higher gear ratio you have less pinion teeth, there for less contact withthe ring gear. When there is less pinion contact with the ring gear the force exerted onto the pinion teeth rises and causes the failure. The more teeth in contact the more the load is spreadJust like a wide tire vs nerrow. The nerrow tire has more pressure per square inch than the wide one because of the size of the contact patch.
Started by 88toy4x4 Toyota Tacoma/4Runner/T100/Tundra/FJ Cruiser 1995+
Started by Joe S. Project Research and Build-Ups
Started by apimpdad Engine
Started by skipnrocks General 4WD Discussion
Started by weakyota91 General 4WD Discussion
