Author Topic: Blaster SS Coil Problems  (Read 657 times)
RynothealbinO
  • Turtle Points: -15
  • Male Posts: 141
  • Member since Aug '06
  • 36's on no lift!
« on: Mar 08, 2008, 12:24:30 PM »
Hello, for about the last year or so I have been running a MSD 5 ignition box and a Blaster SS coil.  It worked gret until last week when it seemed to die for no reason.  I think everthing is still hooked up right, but I am not sure.  I think I might have wrecked the MSD box somehow.
But even when I try to just hook up the MSD coil by itself it will not work.  The stock coil works just fine but when I switch the wiring back over to the MSD it does not work at all.  Should that coil hook up the same as stock?  I also used a multimeter to make sure the MSD coil is not shorted out or anything and it seems to check out fine.  Does anyone know what is going on?
Trust in the LORD with all your heart and lean not on your own understanding, in all your ways acknowledge him and he will make your paths straight.  Proverbs 3:5-6  Don't let anyone look down on you because you are young, but set an example for the believers in speech, in life, in love and in purity.  1 Timothy 4:12
Last post May 27, 2006, 07:23:36 AM
by FSAD
Last post Mar 19, 2008, 05:22:47 PM
by ROCK CRUSHER
Last post Oct 28, 2009, 04:13:39 PM
by 86rustbucket
Last post Jan 13, 2011, 12:37:41 PM
by cruiserfj45
Last post Jan 28, 2011, 05:58:51 PM
by Offroadassassin
