Author Topic: push pull steerin box  (Read 1554 times)
usmc_black_85
  • Male Posts: 135
  • Member since Mar '07
« on: Mar 04, 2008, 12:21:11 AM »
i have an 85 toyota 4 runner on 35's and i still have the stock steering power steering with push pull box when i turn the wheel when im drivin i notice that sometimes i have a delayed reaction in the steering and as well as my steering wheel is all out of whack it will be alighned strait and then when i turn the steering wheel will be in a different position but my truck still steers fine and drives straight and i dont have to fight the steering wheel any ideas of what the problem could be cause i cant figure it out ??? :headscratch: :dunno:
"I KNOW I KNOW ITS A JEEP THING THATS WHY I DRIVE A TOYOTA"
"HEY BARBIE CALLED SHE SAYS SHE WANTS HER JEEP BACK"
RN37DD
  • Male Posts: 742
  • Member since Apr '07
Re: push pull steerin box
« Reply #1 on: Mar 04, 2008, 09:16:55 AM »
my power steering dose some strange things now and then, but i think it's the worn out ball joints. on yours I'd put a wrench on all your steering bolts and make sure nothing is sheared. make sure your front axle and springs are tight too. make sure nothings loose or broke and go from there.
DaveZ
  • Turtle Points: 4
  • Member since Jan '06
« Reply #2 on: Mar 04, 2008, 10:28:13 AM »
Check the adjustments on the arm from your box to the jay arm. The slotted plugs in the end are probably loose. Have someone move the steering wheel left and right and look for where the play is.
Diamond Springs, ca 95619  530-622-2148 Dave
82 w/a 44 and a 60
http://www.davezoffroadperformance.com/store/
Hammerhead
  • Turtle Points: 100
  • Male Posts: 564
  • Member since Nov '04
  • Junkyard Dog
« Reply #3 on: Mar 04, 2008, 10:33:30 AM »
If your spring bushings are worn out or missing the springs can move around excessively causing vague steering and also causing the steering wheel to center different each time it is returned to straight.  Check your suspension and also the steering components as previously mentioned...  Also tighten your drag link.
'82 pickup, +3, locked, doubled
'82 pickup, IFS long travel, V8
'85 4runner, V8 rock crawler
'88 X-cab, V6
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #4 on: Mar 04, 2008, 10:57:47 AM »
Check and make sure there is nothing bent in the steering, if it is even tweeked a little bit it may flex with steering input causing it to delay action.
L.D.
  • Male Posts: 74
  • Member since Sep '05
« Reply #5 on: Mar 06, 2008, 06:51:23 AM »
in regards to the steering wheel misalignment, any difference in body hight on the left front corner will change the angle of the steering wheel, if the right rear tire goes low it will lift up on the left front pulling on the draglink, turning your steering wheel just a little.
LETS GET TWISTED
i'm not a damn hippy, i'm a well groomed mountain man
toyJAYota
  • Member since Dec '07
« Reply #6 on: Mar 09, 2008, 10:36:31 AM »
Same thing was happening with my Runner. I adjusted the draglink ends and now the play is gone.
  • Momentum Man
  • Lego Enforcement
« Reply #7 on: Mar 11, 2008, 10:53:48 AM »
I think the most important thing to remember when lifting a vehicle in regards to the steering is to make sure the steeringbox remains in the neutral position. When you lift you may pull the box out of the neutral position and it will want to steer that direction.
Last post Apr 11, 2004, 09:50:37 PM
by WHITE_TRASH
Last post May 22, 2008, 09:28:34 PM
by 4DEES
Last post Feb 14, 2009, 01:33:49 AM
by peacesells
Last post Mar 30, 2009, 07:10:35 AM
by jrock
Last post Jan 19, 2010, 04:39:36 PM
by Mattinker
