Author Topic: Converting tach signal on factory gauge cluster  (Read 2004 times)
alwayzbroken
  • Turtle Points: 603
  • Male Posts: 1,905
  • Member since Feb '05
« on: Feb 18, 2008, 10:44:45 PM »
Does anybody know if it is possible to get the tach to read properly when putting a gauge cluster from a V6 into a 4cylinder? I assume it isn't but I have been surprised before.
Duffil
  • *lurker*
  • Turtle Points: 138
  • Male Posts: 4,844
  • Member since Nov '04
    • PhotoBucket
I wouldn't think so, since you have 2 extra cylinders firing. maybe if you made a custom circuit board and put it inline... :dunno:
Toymin8r
  • Turtle Points: 50
  • Male Posts: 929
  • Member since Dec '07
I believe there is a way to adjust this on the gauge itself.  You will need to remove the gauge from the cluster to do it.
Quote
88_Pathy
  • Turtle Points: 65
  • Male Posts: 1,251
  • Member since Oct '06
  • Raised suspension
If it has one coil I don't see why it would differ. Right?
  • Administrator
  • Turtle Points: 2124
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
Duffil
  • *lurker*
  • Male Posts: 4,844
    • PhotoBucket
for the clicky impaired:
Quote from:  Dakota Digital
The SGI-8 Tachometer Interface Unit is designed to allow a factory tachometer to function accurately after performing an engine swap to an engine with a different number of cylinders or tach signal. If you are swapping out a V-6 for a V-8 and you need to recalibrate the tach signal from the V-8 to make it read accurately on the factory V-6 tachometer, the SGI-8 will do the job. The SGI-8 is capable of recalibrating tachometer signals for nearly any engine swap combination.
Last post Sep 01, 2006, 05:38:58 PM
by Lonestar Honcho
Last post Dec 04, 2006, 06:23:48 PM
by Lonestar Honcho
Last post Jan 12, 2007, 06:30:09 PM
by Lonestar Honcho
Last post Aug 28, 2007, 12:43:21 PM
by toyoder
Last post Feb 18, 2008, 07:13:46 PM
by lilbuddy
