Yup ran a new wire. Does anyone know if there is a way to check the tach
And youre sure you have it all in the right place on the coil...
I know im just saying the obvious but sometimes its things that when I did it, I messed up on
When I did it i had it in the wrong spot and i also put it on hte wrong spot on the cluster.
ALso if ou have access to like an aftermarket tach you can try that and just make sure that the input from the coil to the tach is working too...
