Author Topic: swapped the cam and rockers  (Read 2801 times)
allbones
  • Turtle Points: -1
  • Male Posts: 127
  • Member since Sep '07
  • This is my 2 wheel drive buggy!!
« on: Feb 16, 2008, 09:52:49 AM »
Is it possible that when I had the cam sprocket tied up and pulled it back on that I got it off a tooth at the bottom? It ran descent just noisy when took apart run like :pokinit: when put back together.
He who dies with the most toys wins: 92 toyota climber and bogger, 96 xcr sp 600 polaris snowmobile, 134 cc honda pit bike, 07 honda crf250 dirt bike,06 joyner 250 sand buggy,02 yamaha pw80, 97 yamaha wolverine 4x4 quad and several rc buggies
allbones [OP]
  • Turtle Points: -1
  • Male Posts: 127
Re: swapped the cam and rockers
« Reply #1 on: Feb 16, 2008, 09:54:24 AM »
We tied the chai to the cam sprocket so that didnt move, had some trouble getting top sprocket back on cam. can i move it a tooth without taking off timing cover?
84pickup
  • Male Posts: 335
  • Member since May '07
  • Barnwell Mountain (stock) Texas TrailRiders Jam 08
« Reply #2 on: Feb 16, 2008, 04:37:52 PM »
yeah, you can move it with out taking the timing cover off. it might be frustrating but you can do it. i did it with my 84 22R. when i took my head off i put some cheap wire through the link that you're supposed to line up with the mark on the sprocket so i knew i had it right and so i could pull it back up if it fell down into the tc cover. you could also be off a tooth or two on the distributor. that's what happend with me you have to get it just right or else it won't run or run crappy.
lets not and say we did.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #3 on: Feb 16, 2008, 05:29:22 PM »
yes  move it  one tooth,  one direction and use a ratchet to rotate the motor  1 full rev,  if it doesnt bind up (one tooth the wrong way  could bind a valve) so  if it doesnt bind  beyond  the regular  stiffness of the engine  rotating, compression  etc,  then  try starting it,
another  and  much quicker way is to put the crank  timing mark on 0*,  then look at the dowel in the cam gear, if its at 12 o clock  and the timing mark is  like 1/2 tooth to the passenger  side of  12 o clock  then its tiimed right
allbones [OP]
  • Turtle Points: -1
  • Male Posts: 127
« Reply #4 on: Feb 16, 2008, 10:10:40 PM »
my mark with the cam lined up at 12 is to the driver side a tooth, it should be to the passenger side???????
allbones [OP]
  • Turtle Points: -1
  • Male Posts: 127
« Reply #5 on: Feb 17, 2008, 05:22:38 AM »
79 coyote can you help me out ?
unclejpl4x4
  • Turtle Points: 348
  • Male Posts: 3,522
  • Member since Apr '05
  • Broke & rusted
    • myspace
« Reply #6 on: Feb 17, 2008, 07:00:47 AM »
I like 2   use a bungy cord on the sprocket/chain  and hook it on the ceiling/over head  keeping  constint  pressure   so the chain don't come off the bottum
allbones [OP]
  • Turtle Points: -1
  • Male Posts: 127
« Reply #7 on: Feb 17, 2008, 07:15:10 AM »
thats where we made the mistake we secured the chain to sprocket but let sprocket rest on a little piece of wood with no tension? dangit!
allbones [OP]
  • Turtle Points: -1
  • Male Posts: 127
« Reply #8 on: Feb 17, 2008, 11:19:06 AM »
I was a tooth off runs good now but drove about 20 miles  and pulled plugs out they are awfully lean, any way to richen it up????
84pickup
  • Male Posts: 335
« Reply #9 on: Feb 19, 2008, 07:49:13 PM »
turn fuel mix screw on carb out i think. could be wrong glad you got it figured out. although i take my sprocket out, but i remember exactly how i had it before and mark everything good. and as i said put a wire through the links that line up with the mark on the sprocket.
Last post Jul 05, 2009, 10:42:00 PM
by sirhc0306
Last post Oct 18, 2009, 03:17:03 PM
by wslytoy
Last post Jan 26, 2011, 07:45:24 PM
by stevesyota
Last post Apr 06, 2023, 07:44:09 AM
by 4runner17
Last post Aug 01, 2023, 12:15:11 PM
by D2therick
