Author Topic: Anti-wrap bar  (Read 6181 times)
88_Pathy
  • Turtle Points: 65
  • Male Posts: 1,251
  • Member since Oct '06
  • Raised suspension
Anti-wrap bar
« on: Feb 15, 2008, 10:22:16 PM »
I know it has been discussed a lot but... I need to know if it is ok to mount the bar on the far side of an axle by the spring perch.  Pics and input is welcome. I am out of space.
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
Re: Anti-wrap bar
« Reply #1 on: Feb 15, 2008, 10:25:46 PM »
should be fine, there are many traction bars that mount to the spring perch area....
have you lookied into one liek this though? that uses the diff centersection? it is in my opinion the best setup as it wont kill articulation
http://www.budbuilt.com/new/traction_bars.html
88_Pathy [OP]
  • Turtle Points: 65
  • Male Posts: 1,251
  • Raised suspension
Re: Anti-wrap bar
« Reply #2 on: Feb 16, 2008, 11:00:39 AM »
E-locker is in the way. I just need a far mounted one or a center mounted one.
88_Pathy [OP]
  • Turtle Points: 65
  • Male Posts: 1,251
  • Raised suspension
Re: Anti-wrap bar
« Reply #3 on: Feb 18, 2008, 05:01:23 PM »
Anyone?
KYOTA
  • Turtle Points: 1759
  • Member since Jan '04
  • Wreckin Ball '09
Re: Anti-wrap bar
« Reply #4 on: Feb 18, 2008, 05:21:52 PM »
mount it as close to center as possible. Off to the side (especially as far out as the springs :o ) is gonna limit the hell out of your travel not to mention wont do :pokinit: for controlling wrap. In (as close to) the center, the trac bar will have a ton more leverage against wrap. Make sure to have two mounting points at the axle (above and below the housing centerline) and one at the horscollar with a slip or shackle. look around theres pics here of different ones
88_Pathy [OP]
  • Turtle Points: 65
  • Male Posts: 1,251
  • Raised suspension
Re: Anti-wrap bar
« Reply #5 on: Feb 18, 2008, 06:18:37 PM »
Thanks for the reply.
Huhwhye
  • Turtle Points: 24
  • Male Posts: 639
  • Member since Jan '03
  • Huhwhye, esq.
Re: Anti-wrap bar
« Reply #6 on: Feb 18, 2008, 06:54:38 PM »
Budbuilt site says you can mount on either side for certain years.
"79-95 trucks and 84-89 4Runners  $379
- 8" differentials, 4 cyl., V6 and Turbo.  Left side and right side mounting available.
- 8" TRD electric locker converted.  Left side and right side mounting available."
'04 Taco DC 4x4
88_Pathy [OP]
  • Turtle Points: 65
  • Male Posts: 1,251
  • Raised suspension
Re: Anti-wrap bar
« Reply #7 on: Feb 18, 2008, 07:12:13 PM »
I know that but... I have exhaust on one side that is all snaked over the horse collar and a gas tank on the other side. Dead center would be nice.
Homefries
  • Male Posts: 241
  • Member since Apr '07
Re: Anti-wrap bar
« Reply #8 on: Feb 18, 2008, 08:16:51 PM »
It will fit in between gas tank and drive shaft with no problem so I would mount it there.   :twocents:
88_Pathy [OP]
  • Turtle Points: 65
  • Male Posts: 1,251
  • Raised suspension
Re: Anti-wrap bar
« Reply #9 on: Feb 18, 2008, 10:33:28 PM »
No way. My drive shaft is so close to the tank already. I will snag some pics of it and see what you guys think. Anyone have pics of one mounted centered.
  • Administrator
  • Turtle Points: 2124
  • Male Posts: 18,291
  • Member since Apr '02
  • 511:1 Club
Re: Anti-wrap bar
« Reply #10 on: Feb 19, 2008, 01:22:40 PM »
KDOG: So why can't you just keep it near the center right now? Just build a bracket to get around the e-motor
88_Pathy [OP]
  • Turtle Points: 65
  • Male Posts: 1,251
  • Raised suspension
Re: Anti-wrap bar
« Reply #11 on: Feb 19, 2008, 01:41:15 PM »
Well that is what I was thinking but that friggin exhaust is all up in that. Pics up soon.
88_Pathy [OP]
  • Turtle Points: 65
  • Male Posts: 1,251
  • Raised suspension
Re: Anti-wrap bar
« Reply #12 on: Feb 19, 2008, 02:39:51 PM »
jrock
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
Re: Anti-wrap bar
« Reply #13 on: Feb 19, 2008, 03:10:35 PM »
Why not weld a perch on top of the axle and use it like the face of the third? I've seen that, somewhere.
  • Administrator
  • 511:1 Club
Re: Anti-wrap bar
« Reply #14 on: Feb 19, 2008, 09:55:39 PM »
KA-BAM!
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
Re: Anti-wrap bar
« Reply #15 on: Feb 19, 2008, 10:20:39 PM »
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
88_Pathy [OP]
  • Turtle Points: 65
  • Male Posts: 1,251
  • Raised suspension
Re: Anti-wrap bar
« Reply #16 on: Feb 19, 2008, 10:27:36 PM »
Explain your thoughts?
And I don't know how a single bar would eliminate the axle wrap?
jrock
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
Re: Anti-wrap bar
« Reply #17 on: Feb 19, 2008, 10:42:10 PM »
You could do it like this:
http://board.marlincrawler.com/index.php?topic=5835.0;highlight=trac+bar
Or you could make it similar to the stock front track bar.
88_Pathy [OP]
  • Turtle Points: 65
  • Male Posts: 1,251
  • Raised suspension
Re: Anti-wrap bar
« Reply #18 on: Feb 19, 2008, 11:59:00 PM »
KYOTA has the design I am going to use. It is exactly what I want to do. I wonder if he used a shackle or a slip joint.
bluetoy84
  • Turtle Points: -100
  • Male Posts: 300
  • Member since Jun '04
  • rice bouncer
Re: Anti-wrap bar
« Reply #19 on: Feb 20, 2008, 11:27:03 AM »
Here's mine, it has a slip joint at the front. I had the same clearance issue with the exhaust.
88_Pathy [OP]
  • Turtle Points: 65
  • Male Posts: 1,251
  • Raised suspension
Re: Anti-wrap bar
« Reply #20 on: Feb 20, 2008, 01:23:58 PM »
With the slip joint is it clanky and noisy at all. I hear they are but don't have first hand experience.
Hammerhead
  • Turtle Points: 100
  • Male Posts: 564
  • Member since Nov '04
  • Junkyard Dog
Re: Anti-wrap bar
« Reply #21 on: Feb 20, 2008, 03:07:40 PM »
You have plenty of room to use Jay Ks design
http://www.mindspring.com/~jayk3/toyota/rear_susp.htm
I've used this style myself and had good luck with it.  In fact I'm building another one for a project I'm working on right now.
'82 pickup, +3, locked, doubled
'82 pickup, IFS long travel, V8
'85 4runner, V8 rock crawler
'88 X-cab, V6
88_Pathy [OP]
  • Turtle Points: 65
  • Male Posts: 1,251
  • Raised suspension
Re: Anti-wrap bar
« Reply #22 on: Feb 20, 2008, 06:26:50 PM »
That is one good link. Thanks a ton.
KYOTA
  • Wreckin Ball '09
Re: Anti-wrap bar
« Reply #23 on: Feb 21, 2008, 11:21:49 AM »
the first one I built was a copy of Jay's (in posted link) I ended up cutting the bracket off the top of the housing and centering the trac bar more for clearance and it controlled wrap much better. best way is to lose the springs and link it  :talkingn:
KYOTA
  • Wreckin Ball '09
Re: Anti-wrap bar
« Reply #24 on: Feb 21, 2008, 11:27:23 AM »
found a couple pics.
Hammerhead
  • Male Posts: 564
  • Junkyard Dog
Re: Anti-wrap bar
« Reply #25 on: Feb 21, 2008, 03:33:22 PM »
The one I am running right now is much like the one in that pic.  I have it right next to the third like that but I raised it higher for ground clearance.
Mine works well, I mean, it's no 4-link...
'88 X-cab, V6
Last post Aug 18, 2004, 11:06:30 AM
by WHITE_TRASH
Last post Sep 30, 2004, 04:11:04 PM
by brainlessfool
Last post Aug 02, 2007, 06:40:14 AM
by jimbo74
Last post Feb 02, 2011, 09:54:45 PM
by SloCrawler
Last post Oct 13, 2020, 06:44:58 PM
by Groundpounder17
