My 1980 Toyota Pickup Build
Started by AR80Toy, February 10, 2008, 12:40:37 PM
Add a Black Rollbar or Black Toolbox ?
Rollbar
5 (31.3%)
Toolbox
11 (68.8%)
Total Members Voted: 16
yep,  must be a corona engine :yesnod:
75 ish  i would assume
Gittinit
How are you going to mount the tensioner pully for the ps pump without that threaded boss on the head? You may have to make a custom bracket, or extend yours over to another hole in the front cover. It will be worth it to have power steering though.
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
AR80Toy
Quote from: Gittinit on February 12, 2008, 02:43:00 PM
That's already in the works , gotta have power steering .
1983 Toyota 4-Banger Completely "Stock" For now ......HeHe
82rustbeast
That thing should be nothin to drive without p/s. I drive and wheel my 82 on 35s with no p/s with no problem. I think parallel parking is the hard part though.
AR80Toy
Well , I got the airsoft BB's put in the tires and it still shimmies at about 55 mph , the 20R can't get them over 55mph . I wonder if adding a header will give it a little more power , it is stock geared 4:37's . Does anyone else have this problem with running 32's and bigger with 4:37's ?
I made a half assed bracket that wrapped from the idler pulley mount to the pass side of the engine to the first available mounting boss.  I always intended to make a stout mount but never quite got around to it, maybe when I get to that point during my rebuild I'll make something.  I contacted lc engineering a while back to see if they had a bracket but they didn't, wouldn't even offer a suggestion on what to do.  Probably should avoid using early heads when building a hybrid :thumbs:
YotaJosh
Quote from: AR81Toy on February 14, 2008, 05:27:06 PM
I'm running 4.37's, 33"s, and the 20R, and I can hit 70 in the interstate if I try real hard. I have a header, and the stock carb.
'79 Short Bed Pickup 4x4
'04 4Runner V8 Sport 4x2
AR80Toy
I'm definately getting a header , I think that will help out alot . In town it will get up to 40 mph in a hurry but on the hwy it takes awhile to get it at 55mph and it doesn't really want to go past that with pedal to the floor . I think a Weber and a header would do wonders .
Quote from: AR81Toy on February 14, 2008, 09:12:56 PM
i agree.
and...
i know IFS handles differently and the steering is different.
but im not running my PS in it right now as my pulleys out of wack and throwing belts...
and im on 35s.
id rather drive 35s, no PS then throw a belt every 10 seconds and risk ripping my distributer sensor wires again doing 75 down a 6% grade and kill the truck... NOT FUN!
but i do agree PS does make it easier, but w/o it, it is totally managable.
come over next week sometime and we'll do a compression test on that thing,   you might  need to swap the other engine in :dunno:
and i might can play with the timing to get you more power also
AR80Toy
Quote from: 79coyotefrg on February 15, 2008, 07:23:49 AM
and i might can play with the timing to get you more power also .
The other engine would need a rebuild before I could throw it in but that is my plans . I think that would help if we played with the timing and maybe set the valves , they may be a little off .
Quote from: AR81Toy on February 15, 2008, 10:35:58 AM
supposed to be kinda crappy this weekend,  maybe monday :dunno:
we need to find you a  81-83  22R block  and put the other 20R head on it  :burnout:
AR80Toy
Sounds good but there's no way in H3LL I'm driving all the way to Arkadelphia with those TSL's on , I'll put my other tires on so the ride will be better .
AR80Toy
Just ordered a Weber 32/36 and a Doug Thorley Tri-Y Header , will get pic.s of the install .
AR80Toy
Weber has been installed , definatley can tell the difference . Pic.s of the install will follow as soon as Glen aka 79coyotefrg uploads them . Next will be the header , hopefully within the next week I should have it and pic.s of the install as well .
base adapter (works with 20R and 22R intakes)
adapter to weber base
newly installed 3236 weber
AR80Toy
Thanks for the pic.s , Glen !!!! Should have the header in the next couple of days .
Gittinit
How do you plan to bypass the old antifreeze tempature controlled choke? I'm doing the opposite and I'm putting a stock carbed 20r into a truck origonally equipped with a 22r.
my favorite places:
AR80Toy
Quote from: Gittinit on March 04, 2008, 06:57:08 AM
I'm gonna get a short hose and run it from each side of both openings and toss the old choke . Got the Doug Thorley Tri-Y Headers put on this afternoon , pic.s will follow . The jets are running too rich for what I have so I'm gonna order a jet kit and rejet the carb. after that she should open up pretty good .
