Author Topic: 22re swap  (Read 1184 times)
84_yota_4wd
  • Turtle Points: 219
  • Male Posts: 831
  • Member since Feb '06
  • mountain goat
    • Buy me some coffee
22re swap
« on: Feb 08, 2008, 11:49:35 AM »
hey there guys ive been out of the marlin loop for about a year but i got a fresh engine for my truck only a year late but oh well. :beerchug:
its a 22re but i am still going to run my carb and intake because i only could afford the block and head. its all put together i just need to put my intake on it and put it into my truck.
I just want to know what if any frustations i will run into because of it being a r-e.
i know people do this all the time but is it the same as if it were just a 22r. my understanding is that the only difference is that its fuel injected.
Is it really that easy to swap them around?
Thanks mitchell
« Last Edit: Feb 08, 2008, 02:13:00 PM by 84_yota_4wd »
Marlin Crawler
Developers of the longest lasting and most successful
Toyota Transfer case, Transmission, and Differential products on the planet
(888) 94-CRAWL / 888-942-7295
toby
  • Male Posts: 276
  • Member since Aug '07
Re: 22re swap
« Reply #1 on: Feb 08, 2008, 03:29:14 PM »
The block and the head are the same as far as I know. I just put a re head on my r block, intake bolts up the same. It just has idle issue now, but, i don't believe it is related to the head.
I'm not as good as I once was, but, I'm as good once as I ever was.
70 Cam Guy
  • Turtle Points: 4
  • Male Posts: 115
  • Member since Apr '07
Re: 22re swap
« Reply #2 on: Feb 08, 2008, 10:02:59 PM »
You might need to use your stock distributor and ignition since the RE model uses a different distributor and coil (from what I've read about the EFI conversion)
84_yota_4wd [OP]
  • Male Posts: 831
  • mountain goat
Re: 22re swap
« Reply #3 on: Feb 09, 2008, 11:35:41 AM »
ok i can do that i still have the old stuff. thanx
Marlin Crawler
Last post Dec 03, 2004, 03:11:10 PM
by Mike D
22RE swap
Last post Feb 02, 2005, 11:21:06 PM
by kyle_22r
Last post May 08, 2005, 10:44:52 AM
by 79coyotefrg
Last post Dec 13, 2005, 03:03:00 AM
by wa4x4
Last post Mar 26, 2007, 01:36:56 PM
by Cheesemaker
