Author Topic: '99 4Runner lift  (Read 17165 times)
mmml4
  • Member since Jun '06
Re: '99 4Runner lift
« Reply #30 on: Mar 23, 2008, 05:15:54 PM »
How much lift can you do on the rear of a 99 4runner without doing anything to the links.
skid
  • Turtle Points: 144
  • Male Posts: 295
  • Member since Oct '04
« Reply #31 on: Mar 23, 2008, 08:17:31 PM »
I've seen 4" in a 95(non taco). Worked, but drives very funny.  I'd stick to 3"
Diggin a hole with plastic
90 ext cab toy, short 40 Iroks, detroit and diamond, mco8-r10 duals with twin stick, 4.7 gears and 30 spline Longs/hub gears-studs
DeMented Toys
  • Turtle Points: 160
  • Male Posts: 1,151
  • Member since Aug '04
  • Woo-Hoo!!!
« Reply #32 on: Apr 07, 2009, 11:27:39 PM »
I just bought a 99 4 Runner highander.  I have about the same lift questions...  And if the 99 is higher than other 3rd gen 4 runners then how much do the advertised lifts actuall lift it?
I have around $600 to spend.  I just want to level it out, the back sags just barely, and maybe add an inch or two...   The back is going to have camping gear etc in it and I may pull a small utility trailer on occasion...
Im thinking of going with tundra coils up front and OME 891s in the rear...
Any rear spring reccomendations?
Anyone know how much lift tundra springs give on the front for a 99 4Runner?
« Last Edit: Apr 08, 2009, 12:00:35 AM by DeMented Toys »
Jeff DeMent
-DeMented Toys-
Ric
  • Male Posts: 65
  • Member since Apr '06
    • 6dgr
« Reply #33 on: May 16, 2009, 09:53:12 PM »
3" sus. max. with CVs any higher you will be snapping CVs
Please Read This:
http://www.6dgr.com/6dgr_Explanation.pdf
If it gets your attention,
You can sign up at:
http://www.6dgr.com/index.php?mode=join&ref_id=11427
Nafe0810
  • Male Posts: 22
  • Member since Aug '08
« Reply #34 on: Jun 25, 2010, 06:45:00 PM »
I'm currently runnin the Revtek 3" front and rear on my 2000 4runner and its doin pretty good.  I just threw on some 285 75 r16's on it and I'm not rubbing at all, its close but no rubs so far.  You can get the kit for around $340 too so its not a bad way to go.
It's only tough if you weren't built for it
Last post Mar 13, 2005, 05:59:48 PM
by bikerider
Last post Mar 27, 2006, 12:08:32 PM
by yotapride
Last post Jul 27, 2006, 08:00:54 PM
by Mr_Cheese
Last post Nov 04, 2006, 12:20:52 AM
by Mr_Cheese
Last post Jun 15, 2007, 05:54:43 AM
by Petzl21
