Author Topic: SPARK PLUGS  (Read 2056 times)
acerbis
  • Male Posts: 102
  • Member since Dec '07
SPARK PLUGS
« on: Jan 22, 2008, 12:53:55 PM »
What does it mean when you have black specs on your plugs?
And i wonder if I can replace the valve seals (the rubber piece that wraps around the stem) without pulling the head off?
you'll never be younger then you are today
85xcab
  • Male Posts: 81
  • Member since Jan '07
Re: SPARK PLUGS
« Reply #1 on: Jan 22, 2008, 01:40:36 PM »
Black specks on your plugs can be caused by detonation/pinging.
It can be caused incorrect ignition timing, bad fuel, engine overheating. The black specks are aluminum from your pistons and if the problem is not fixed it will destroy your engine.
Duffil
  • *lurker*
  • Turtle Points: 138
  • Male Posts: 4,844
  • Member since Nov '04
    • PhotoBucket
Re: SPARK PLUGS
« Reply #2 on: Jan 22, 2008, 01:58:47 PM »
the valve seals can be done, but it is a PITA.  rotate the piston to TDC on whichever cylinder you are working on.  pressurize the cylinder with Air Hold fittings and an air compressor.  slide the rocker to the side, and compress the spring, remove the keepers etc.
acerbis [OP]
  • Male Posts: 102
Re: SPARK PLUGS
« Reply #3 on: Jan 22, 2008, 02:06:06 PM »
I think someone told me that the black specs were from a bad valve guide seal. The engin doesn't seem to be overheating and how can that be caused from timing?? My engin (22r) uses a little bit of oil too so thats why i'm thinking its the seals???
DeadlyPeace
  • Male Posts: 593
  • Member since Nov '07
  • HEAVILY medicated for your protection!
    • ToyotaOffRoad
Re: SPARK PLUGS
« Reply #4 on: Jan 22, 2008, 02:28:20 PM »
Does it look like this?
If so this is the common cuase of it (I know you said it doesn't seem to be overheating)
OVER HEATING – An extremely white insulator with small black deposits and premature electrode erosion.
SYMPTOMS:
Loss of power at high-speed or during heavy load
CAUSES:
Plug insufficiently tightened
Engine insufficiently cooled
Ignition timing too advanced
Plug heat range too hot
I REJECT YOUR REALITY AND SUBSTITUTE MY OWN
Never let people think you’re a horrible person and always keep the heart of a young child…
       ...I prefer mine in a jar on my desk.
3 CAT scans a MRI and some time with the shrink and it's comfirmed. I'm just not right in the head.
Global Moderator for www.ToyotaOffRoad.com
RN37DD
  • Male Posts: 742
  • Member since Apr '07
Re: SPARK PLUGS
« Reply #5 on: Jan 22, 2008, 03:01:42 PM »
do all the plugs look the same. or is it different on each plug. i had an engine with bad valve seals and it would start with a puff of smoke in the morning after oil would leak  pass the seals and down the valve stem. after that it would run clean.  if their bad you should see some smoke.
acerbis [OP]
  • Male Posts: 102
Re: SPARK PLUGS
« Reply #6 on: Jan 24, 2008, 09:29:43 AM »
there is smoke. And some oil loss? I'll check the plugs tomarrow and see if they are all the same. I'm pretty sure they are. Also I have cleaned the carb and it works good but there is a stumble in every gear when i ease on the gas while moving. Like when you let off the gas on the freeway and coast for a sec then just barley get on the gas. If i just punch it it skips that part and gets to business. It sounds like my idle jet is clogged but......the carb is clean. Maybe it needs a rebuild but I have a theory that my vaccume advance is messed up? could tht cause those specs on the plugs??
Last post Mar 17, 2010, 07:26:35 PM
by joeycool00
Last post May 21, 2007, 07:11:49 AM
by Yota87Truck
Last post Jun 19, 2009, 08:29:09 PM
by emsvitil
Last post Jul 31, 2011, 04:44:13 PM
by Snowtoy
Burnt ceramic on spark plugs
Last post Feb 01, 2019, 01:35:49 PM
by V-Man
