Author Topic: new cab  (Read 563 times)
YotaJoe
  • Male Posts: 34
  • Member since Sep '06
new cab
« on: Jan 14, 2008, 03:44:59 PM »
I was told you could have a reg. cab and put on a extra cab.If it is would it be tough to do.
93tonkatoy
  • Turtle Points: 5
  • Male Posts: 463
  • Member since Jul '07
  • drive it till it breaks! then break out the tools.
Re: new cab
« Reply #1 on: Jan 14, 2008, 03:59:43 PM »
You can do whatever you can dream, but, you will have to move the frame brackets for the rear of the cab, remove the front bed mount brackets, and check for clearance with the fuel tank/lines. Actually, if you can weld and grind, and measure, you could do it fairly easily.
SAVE TELLICO post 491
