Author Topic: is a 1'' bore mc not big enough to push 4 wheel discs chev rear calipers  (Read 2906 times)
NaturalDisaster
  • Male Posts: 108
  • Member since Nov '06
i just installed the sky man rear disc brake set up using 85 monte carlo front calipers and a 1'' bore mc and my brakes are no good now they go almost clear to the floor before it trys to stop. bleeder valves are on top i have ran a whole bottle of fluid threw just bleeding them. do i need to get an adjustable proportioning valve? or is their maybe some other problem? the stock lspv is gone and the brake line is ran right into the t on the axle and then out to the wheels. let me know what ya think cause im stumped. Thanks all
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
Read this it may help you out. Did you put a residual valve on the rear brakes, you may need one you may also need an adjustable prop. valve.
http://home.4x4wire.com/erik/4runner/brakes/
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
you should have a valve..
DanS
  • Turtle Points: 5
  • Male Posts: 434
  • Member since May '06
OOPS has the right idea and a proportioning valve is necessary
DanS
Wow, been looking at my 4Runner rust away too long, need some inspiration and here I will find it...!
85 Toyota 4Runner, solid axle, 22Re, original paint and graphics and not a straight panel to be found!
crawlerdan
  • Turtle Points: 1319
  • Male Posts: 4,770
  • Member since Feb '05
i had good luck with a twin turbo supra MC, it was 1 1/4 if i remember right-i was pushing 3/4 ton chevy discs
*ROKTOY*
  • Male Posts: 1,066
What year Supra
« Last Edit: Dec 30, 2007, 06:20:24 PM by toyguy86 »
crawlerdan
  • Male Posts: 4,770
mk4 twin turbo, such as 95, around there
the last bady style they produced
  • Male Posts: 8,707
the orange one in fast and the furious
NaturalDisaster [OP]
  • Male Posts: 108
sorry im tarded but whats a residual valve? what does it do and how does it work
Duffil
  • *lurker*
  • Turtle Points: 138
  • Male Posts: 4,844
  • Member since Nov '04
    • PhotoBucket
it is a spring loaded valve that keeps a slight amount of pressure in the line (like 2lbs) to keep the pistons from retracting too far.
edit:
ToyotaTom
  • Turtle Points: -16
  • Male Posts: 40
  • Member since Jun '05
  • Locked and Loaded
    • Toms Toyota
Hey Natural,
I did the same setup with the sky rear brakes and the MC 1", with no problems as far as braking goes.  I wonder if you have air somewhere in the line.  I didn't add any thing else to my system.  Good luck in you findings.  One note, the only thing that squeaks or makes noises is those Chevy parts on my truck! :tantrum:
1985 Toyota 4X4, SR5
Detroit Locker Rear
Electric Locker Front
Disc Brakes on all 4
8000xi Warn Winch
  • Male Posts: 108
ya i know isnt that terrible having to put chevy junk on a yota.
My truck has the weirdest brakes i have ever seen in a toyota before. Back when the brakes were totally stock absolutly nothing modified at all a 13/16's bore mc was just not big enough to push my brakes no matter what i had changed mc's about 5 different times all differnt mc's and no matter what a 13/16's bore mc would just not do it. So i put on a 1'' bore mc and fixed the brakes no problem at all worked great and once again like i say the rest of the brake system was totally stock weird huh.So after all of this i then did the rear disc and then again the 1'' bore mc was just not big enough to push the the brakes again so i have went ahead and put more chevy junk on my truck in the form of a 1.1/8'' bore chevy mc and the brakes pedal is nice and firm again. But my probem now is the rear brakes are locking up bad. So do i need a prop valve to fix this problem or a prop and residual both? is the residual valve ment to hold a little bit of pressure to the rear calipers so that a smaller bore mc can push the brakes Thanks for all your help Ryan
Last post Mar 22, 2005, 07:20:05 PM
by UNBREAKABLE
Last post Dec 08, 2007, 08:24:09 AM
by OOPS
rear discs
Last post Sep 17, 2009, 10:02:49 PM
by boggerunner
Last post Jan 13, 2010, 09:42:40 PM
by cruiserfj45
Last post Sep 27, 2011, 10:32:31 PM
by toysfreak
