Author Topic: is a taco elocker rear worth $400 drum to drum  (Read 5182 times)
NaturalDisaster
  • Male Posts: 108
  • Member since Nov '06
« on: Dec 14, 2007, 02:49:47 PM »
i have a chance to buy a taco elocker rear for 400 bucks is it worth that price also i have 5.29's in my truck will they fit in the taco third or do i need to buy v6 gears if so witch would be a recomended brand? also will by disc brake stuff from sky-man fit the taco rear sky says it will but i would like to know for sure from someone who has actually done it? and also will the axle shafts from my 86 rear end fit the taco rear? or does someone make a good set of aftermarket shafts for the tacoma rear?
Thanks for all your help its much appreciated Ryan
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: is a taco elocker rear worth $400 drum to drum
« Reply #1 on: Dec 14, 2007, 02:56:51 PM »
dude,  the elocker  ALONE  is  easily worth the $400
and yes  v6 gears are needed  for the  elocker,
no  your 86 shafts wont fit in the taco housing,  they are about a inch too short
Darrin530
  • Male Posts: 48
  • Member since May '07
  • fish on
« Reply #2 on: Dec 14, 2007, 06:26:14 PM »
i will buy from you for 450 if you buy it for 400
3RD Gen 4runner 5VZ-FE R150f
NaturalDisaster [OP]
  • Male Posts: 108
« Reply #3 on: Dec 14, 2007, 10:40:07 PM »
sweet i will prolly pick it up then but where do i buy v6 gears and how do i know that im getting true v6 gears? what about after market shafts and my sky disc brake brackets?
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
« Reply #4 on: Dec 14, 2007, 10:48:03 PM »
yukon gears, make sure they are for a v6 application from a trusted source....
$400 is a sweet price for an elocker drum to drum axle
people usually get $150-200 for jsut the 86+
  • Male Posts: 108
« Reply #5 on: Dec 14, 2007, 11:02:47 PM »
who would be the trusty source? because thats a big worry for me i have been told that when buying gears even if you ask for v6 gears you will still just get 4cyl gears
  • Male Posts: 8,707
« Reply #6 on: Dec 14, 2007, 11:04:53 PM »
marlin is a good place.....
  • Male Posts: 108
« Reply #7 on: Dec 14, 2007, 11:27:53 PM »
sweet! anybody know about aftermarket shafts tho i will prolly never brake the stock ones if they are as strong as the 86 shafts witch im betting they are and the disc brakes that i just barley finished installing on my 86 rear will they fit the taco rear because i realy want the discs in the rear
Thanks all the help is much appreciated
Darrin530
  • Male Posts: 48
  • fish on
« Reply #8 on: Dec 16, 2007, 07:52:06 PM »
how big of tires do you want to run? I have never heard of someone breaking a shaft on the taco rear end. I think sierra or yukon would be good just measure it when you get it 8.4" not 8"
  • Male Posts: 108
« Reply #9 on: Dec 19, 2007, 04:31:35 PM »
i am running 39'' krawlers. i thought the elocker rear was only an 8'' by what i was looking at for a ring and pinion set. do i have to pull it all the way apart just to measure it to find out if it is an 8'' or 8.4'' or can i do it by a vin # check at the toyota dealer or can it be idenified right on the rear end? Thanks
caldwell636
  • Member since Nov '07
should be able to identify using all those sources ... those are some large tires with stock shafts ...  :thumbs:
Hottrod81
  • Turtle Points: -2
  • Male Posts: 1,392
  • Member since Feb '05
  • Full Trucker Effect
The e-locker is an 8".  I wouldn't second guess about buying it.  Take the housing you have now and modify it for the housing.  You 86 shafts will not work with the taco housing.  There is a writeup on 4x4wire.com.
http://www.marlincrawler.com/htm/diff/tacoma_diff.htm
Last post Aug 24, 2005, 10:39:13 PM
by Skim
Last post Jan 14, 2006, 08:05:20 PM
by SQUIRREL MONSTER
Last post Apr 12, 2006, 09:33:35 AM
by trax28to
Last post Aug 10, 2007, 09:10:53 PM
by Craftsman
Last post Nov 02, 2012, 05:59:17 PM
by desrodunes1
