=THE 1 TON DADDY=
Started by 4DEES, October 11, 2007, 10:30:28 PM
TIMS89CRAWLER
nice what do they do when they machine them? we have a place up here in oregon that makes converson hubs for those and I never knew how else to get it converted to single wheel
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
4DEES
Quote from: TIMS89CRAWLER on January 29, 2009, 06:49:43 PM
Really? What Company??
You See Where The Wheel Studs Are? Well That Gets Removed And The Hub Body Itself Is Wider Than A Single Wheel Hub, So After The Plate Where The Studs Are Gets Removed, The Hub Body Gets Machined Down To The Thickness Of A Single Wheel Hub. Then I Believe I Have To Get Rotors From A Single Wheel Axle, And I'm Still Not Quite Sure How The Studs Get Re-Attached  :ha_ha: , I'm Figuring It Out As I Go Along. It's A Little Bit More Work And A Little More Complicated But It Is Cheaper Than Picking Up A Set Of Single Wheel Hubs. I Would Jump On A Set Of Single Wheel Hubs If I Found Some Cheap Enough  :thumbs:
***ROCK BRAWLERS~Southern Cali***
www.rockbrawlers.com
'85 Toy, 42's and a body lift!
ROCK IT TILL THE WHEELS FALL OFF!!
TIMS89CRAWLER
the company up here that makes them is called six states.... they build driveshafts and a bunch of other drivetrain related items.... ya that sounds like it will work fine having them machined though and like you said prolly a lot cheaper too if I remember right those hubs were quite spendy to buy I will check into them again today and see how much they want for them now days
www.choptechfab.com
CHECK THE BUILD
4DEES
 I Got A Little Work Done This Weekend Thanks To A Couple Of My Buddys  :thumbs:
MIDGET Cutting Off My Old WMS
Dually WMS Cut Off
The Sweet Smell Of Burned Grease  :laugh:
Also Went And Picked Up My 42" Iroks And Re-Centered H1's
Took The H1's Apart And STarted Cleaning Them Up So I Can Paint Them
I Found Out That My Buddy max Has A Lathe At His Yard So I Will Be Cutting Down My Hubs This Week  :gap: I Will Also Be Ordering Some More Parts This Week  :thumbs:
TIMS89CRAWLER
ballin man! cant wait to see it done
www.choptechfab.com
CHECK THE BUILD
Wermz84
I love the Sweet smell of burning grease.  :hahaha:
Nice work so far.  :eye: will be watching this, want to start learning more about the Beefy axle's.  :thumbs:
I like to Drive!
4DEES
#637
Quote from: TIMS89CRAWLER on February 01, 2009, 09:42:46 PM
Thanks Brotha Me Either!
Quote from: Wermz84 on February 01, 2009, 09:52:29 PM
Thanks Man, I'll Be Posting Pics As I Go Along :thumbs:
4DEES
4DEES
 Not Much Done Today. Was Looking AT My 60 And Noticed That It Had A Bit Of Surface Rust On It So I Wire Wheeled It All Off And Painted It  :yupyup: Also Picked Up Some More Parts  :thumbs:
Axle Before:
After:
Off-Road Design High Steer Arm
Painted  :eyebrow:
Also Got A Ram Off Of My Buddy Max, The Oil On There Is From His Engine  :joke:
TIMS89CRAWLER
hell ya man those hi-steer arms are beef  :yupyup:
www.choptechfab.com
CHECK THE BUILD
Loosekannon
Come on man, use Marlin to host the pictures so I can see them over here too...  :biggthumpup: :greengrin:
Tool Pimp
 :beerchug:
Loosekannon
Thanks bro....  :beerchug:
Looks good Carlos, get those hub bodys turned down and get the crap under your truck  :biggthumpup:
This thing is gonna be a monster, and that unsprung weight will help keep you on your rubber side. :gap:
Loosekannon
Quote from: Rocksurfer on February 03, 2009, 07:49:19 AM
We hope  :rofl2:
Hyena
Jud
I don't think anything can keep him on the rubber side. He should just put HUGE tires on it so he can roll over and still wheel upside down. haha
"bout tree fiddy"
TIMS89CRAWLER
Quote from: Jud on February 03, 2009, 10:53:28 PM
:rofl2: :rofl2: I wanna wheel upside down!
www.choptechfab.com
CHECK THE BUILD
rednk1980
lookin good those steering arms are straight beef.
AaronB
what are you going to about lockers?
Quote from: skipnrocks on November 08, 2011, 05:36:37 PM
:rofl:
94MtnYote
Marlin 1200LB clutch
4DEES
:hahaha: :hahaha: I Hope So!!
Quote from: Hyena on February 03, 2009, 09:32:35 PM
done yet?  :)
:pokinit:, I'm Trying To Catch Up To Your @$$!!
49" Iroks :eyebrow:  :rofl2:
Quote from: rednk1980 on February 04, 2009, 06:25:16 PM
Thanks Man, Yeah They Are Dude. I Trip Out On How Much Bigger And Heavier They Are Then The Toyota Arms.
Quote from: Aaronb on February 04, 2009, 08:25:26 PM
Going Welded Front And Rear  :thumbs:
AaronB
Quote from: 4DEES on February 04, 2009, 11:41:13 PM
Yeah I think im going to do the same thing
toywthbdydmge
Hurry up I need some motivation  :beerchug:
Hyena
your gonna pass me up here soon!
Lizard_lips
You done yet? You are moving as fast as me haha
The statistic on sanity is that One in every four is insane, Think of your three best friends if they're ok then its you.
4DEES
Quote from: Hyena on February 05, 2009, 08:59:52 PM
Wanna Race?  :burnout:
Quote from: Lizard_lips on February 09, 2009, 05:31:52 PM
  :hahaha: Yeah No :pokinit: Huh?
Finally Dropped Off My Hubs To Get Machined This Past Weekend, Should Be Done Some Time This Week  :gap: STarted Ordering Parts For My Steering, Pics Soon!!  :yesnod:
rednk1980
