Author Topic: Setting up new carb  (Read 1341 times)
H8Mud
  • Member since Jun '07
Setting up new carb
« on: Sep 19, 2007, 10:56:00 PM »
Just had my Aisin carb professionaly rebuilt by import carburators. It was fully redone with new everything and was tested on a flow jet and im putting it back on tomarrow. What all do i need to do besides adjust idle and double check timing (just put a new timing set in at the same time).  From what i understand you can only adjust idle mixture because the other mixture is factory plugged. Any help would be great this is my first carburated and first yota build but im not new to wreching.
H8Mud [OP]
Re: Setting up new carb
« Reply #1 on: Sep 20, 2007, 01:25:13 PM »
bump
H8Mud [OP]
« Reply #2 on: Sep 20, 2007, 06:07:16 PM »
anyone? i got it started up today and it will run, but my foot is on the gas a decdnt amont, i need to know what screws are the idle mixture and so on so i can get this baby to idle!  Or if anyone in socal can help me i got lots of beer and food money!
H8Mud [OP]
« Reply #3 on: Sep 21, 2007, 05:31:25 PM »
found a leaky egr mounting surface, so i think im headed in the right direction
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
« Reply #4 on: Sep 21, 2007, 05:45:22 PM »
this might help.... i dont remember what the screw is in the green circle....
also the mixture screw should be about 3.5 turns out from closed i think.... dont remember what i run mine at, usually takes some fine tuning... and that is only if someone drilled out the plug... that hole isnt usually accessible
Last post May 21, 2008, 12:59:36 PM
by ROCKO
Last post Aug 31, 2009, 01:39:13 PM
by 4RunnerChevy
Last post Jun 06, 2011, 10:37:21 PM
by SFD4x4
Last post Dec 14, 2011, 07:27:14 AM
by OOPS
Last post May 08, 2013, 09:09:13 PM
by kneedownnate
