Author Topic: 5speed tranny swap in tundra  (Read 4787 times)
0 Members and 8 Guests are viewing this topic.
bajabooster
  • Member since Aug '07
« on: Sep 19, 2007, 01:06:24 PM »
i have a toyota tundra with the 3.4 v6 2wd auto tranny i was wondering if a toco 5speed tranny will bolt up to it im sure it will being both the same motor,,but just want to make sure before i purchase one..the reason im doing so is becouse im going to do a solid axel swap and need th 5speed tranny to bolt a transfer case too let me know ,,,,thanks.. :thumbs:
Taco
  • Turtle Points: -1
  • Male Posts: 20
  • Member since Oct '06
    • www.4x4HIM.org
Re: 5speed tranny swap in tundra
« Reply #1 on: Sep 22, 2007, 04:14:44 PM »
Hey Bajabooster,
I just did this swap into my 03' tacoma doublecab.  It was a lot easier than I thought it was going to be, although I did a lot of research before starting.  I had the auto tranny and swapped in a manual tranny, both had 4x4 trannies.  There is only thing you MUST to check before knowing if it is possible for you to do in the first place.  The crankshaft on your 3.4L v-6 must be factory machined to accept a pilot bearing for a manual tranny.  Most that I have heard of or seen have been machined on both auto's and manuals; however there are a few out there that were not. Once you determine that yours is machined for a pilot bearing, you need to:
1.  Obtain a manual tranny, all the shifters/interior parts, the manual tranny t-case, a flywheel (the auto does not have one) and a new clutch kit.
2.  Relocate your tranny crossmember (I have the front range offroad crossmember so I just moved it back)
3.  Shorten the rear driveshaft and lengthen the front driveshaft (a great time to go with dual cases)
4.  Cut holes in the floorboard to accept all the new shifters
5.  Bypass a few wires to rick the computer into thinking there is an automatic still there (telling the computer the tranny is in park so it will start)
6.  Wire up your reverse lights
7.  Wire in a clutch cancel button and a clutch starter interupt.
8.  install a clutch, master/slave clutch cylinders, and all hydraulic clutch lines In this case you would have to remove the crankshaft and have it machined by a machine shop (not at all a practical solution).
This is about all it takes and you'll have a 5speed!  I have more info on the electrical portion if you need it, feel free to email me anytime.
Russellamanda628@msn.com
2003 Toyota Tacoma TRD
Supercharged 3.4L V6 Dual-Cases Manual Tranny Conversion
HP Dana 44 Conversion with 1 TON crossover/highsteer
Electric Locker (Front)
TRD E Locker (Rear)
37/12.50/15  Good Year MTR's
Custom Bumpers/Sliders
Warn Winch
Taco
  • Turtle Points: -1
  • Male Posts: 20
    • www.4x4HIM.org
« Reply #2 on: Sep 22, 2007, 04:18:52 PM »
In addition, I also have my old 4x4 auto tranny that would bolt right into your setup with most the stuff you will need.  I have a guy that is interested in it but I think he is changing his mind on the sas idea.  This would allow you to keep your auto, let me know if you are interested!  I also have a detriot locker for a dana 44 with a 4.10 ring and pinion, hd diff cover, and front driveshaft.  Let me know!
Taco
TRD E Locker (Rear)
Warn Winch
bajabooster [OP]
« Reply #3 on: Dec 13, 2007, 04:54:33 PM »
well boys i know this thread is old but i just wanted to say that the 5speed sas tundra is under way and im very excited and thanks for the usefull info
yota_krawler
  • Cody Hunter
  • Turtle Points: 5
  • Male Posts: 3,379
  • proud parent!!!
« Reply #4 on: Jan 28, 2008, 10:33:02 PM »
I know it is old but Hey Taco, I am looking to get a taco and I was wondering if you could maybe specify a little more on the trannie swap, I want a 4 door and the only come auto. What did it cost you and honestly is it worth it?
dyogim
  • Turtle Points: 2
  • Member since Jun '03
  • I love Marlin Crawler!
« Reply #5 on: Jul 08, 2008, 09:28:25 AM »
Any updates on this build?
potter85
  • Male Posts: 257
  • Member since May '09
  • complete disregard for sheet metal.....
« Reply #6 on: May 08, 2009, 09:12:41 PM »
i am interested in this i have an 02 4x4 tundra 4.7l v8 and was wondering about how hard this would be to do? i dunno if they even make a manual trans for my truck? does anyone know?
3rz in the making
looking for 38s
2 tundra 4.7l v8 soon to be sas'ed
potter85
  • Male Posts: 257
« Reply #7 on: Jul 16, 2009, 10:58:57 PM »
bump ???
3rz in the making
looking for 38s
potter85
  • Male Posts: 257
« Reply #8 on: Sep 25, 2009, 09:41:33 PM »
guess not?
3rz in the making
looking for 38s
Last post Apr 06, 2004, 10:53:27 PM
by ihanberg
Last post Jan 20, 2006, 11:28:21 PM
by olemisstoy88
Last post Apr 14, 2006, 01:15:21 AM
by 4runner157
Last post Dec 14, 2009, 06:29:43 PM
by trucha
Last post Nov 02, 2021, 04:22:16 PM
by Bonzo
