Author Topic: head light help  (Read 1919 times)
85yodaon33s
  • Male Posts: 227
  • Member since Jun '07
head light help
« on: Aug 26, 2007, 06:04:50 PM »
:smack:
« Last Edit: Aug 27, 2007, 07:07:34 PM by 79coyotefrg »
85yodaon33s [OP]
  • Male Posts: 227
head light help
« Reply #1 on: Aug 26, 2007, 06:05:48 PM »
man i just got my 81 today and then damn head lights don't want to come on  until they are ready to come one all the fuses are good bulbs are good I'm thinking it is the switch and i need some help figuring it out just the head lights dont come on the running lights do and all the other lights just the beams them self dont
bigarms23
  • Turtle Points: 133
  • Male Posts: 2,862
Re: head light help
« Reply #2 on: Aug 26, 2007, 06:34:56 PM »
Sounds like the switch i would pull your steering colum and check the connections to the switch
85yodaon33s [OP]
  • Male Posts: 227
Re: head light help
« Reply #3 on: Aug 26, 2007, 06:41:56 PM »
thanks man i do apprecate it a lot hope fully it dont cost nothing to fix due to the fact im am retired early so that means no money for a while
  • Turtle Points: 1420
  • Male Posts: 22,619
  • Solid axle Toys Rule ! ! !
Re: head light help
« Reply #4 on: Aug 26, 2007, 07:01:14 PM »
head light relay  drivers  side kick panel
85yodaon33s [OP]
  • Male Posts: 227
Re: head light help
« Reply #5 on: Aug 26, 2007, 08:06:37 PM »
thanks for your help i will try and then i will post up on it
4XFlyin
  • Turtle Points: -8
  • Male Posts: 541
  • Member since May '05
Re: head light help
« Reply #6 on: Aug 26, 2007, 09:22:49 PM »
also inspect the fusible link wire at the battery.
82 1st Gen with 4.3L vortec and 4l60e. Linked front and rear
My build up. Getting linked
http://board.marlincrawler.com/index.php?topic=50700.msg711361#msg711361
trail mate
  • Male Posts: 19
Re: head light help
« Reply #7 on: Aug 26, 2007, 09:55:14 PM »
you can use an ohm meter to check the switch, also check to make sure all of the wires going to and from the switch have a good connection
fordh8r
  • Turtle Points: 808
  • Male Posts: 2,582
  • Member since Jan '07
  • when my toyota grows up it'll be just like my chevy!
Re: head light help
« Reply #8 on: Aug 26, 2007, 10:08:55 PM »
  If you know which relay is for the headlights you can have someone else turn on and off the headlights while you listen for the relay to click. If the relay is clicking then try swapping it with another relay and then see if the lights work. If they still don't work then check for battery voltage at the relay terminals in the box. One of those terminals should be hot all the time. If no voltage then possibly a bad fusible link in the same box. It may look like a little plug in box with a fuse type strip inside or a wire type.
  If no relay is clicking while switching the headlights on and off. then the problem may be in the switch or wiring to the switch. If you have to get into the wiring a schematic may be needed to get you through.
  Hope this helps.  :beerchug:
85yodaon33s [OP]
  • Male Posts: 227
Re: head light help
« Reply #9 on: Aug 26, 2007, 10:16:10 PM »
will try all methods any one know the ohm needed for the switch so i dont make a mess of things trying all this stuff and burn down my truck i just got
fordh8r
  • Male Posts: 2,582
Re: head light help
« Reply #10 on: Aug 26, 2007, 11:02:18 PM »
Should be 0 (zero).  :yesnod: Switches are not supposed to have resistance. If they have resistance they get hot and no workie!  :smack: Then you could have a fire.  :shudder:
trail mate
  • Male Posts: 19
Re: head light help
« Reply #11 on: Aug 27, 2007, 01:35:55 PM »
what you are checking for with an ohm meter is little to no resistance, and checking to see if there is continuity in the switch, if your meter says OL when you should have continuity your switch is probably bad.
  • Momentum Man
  • Turtle Points: 505
  • Male Posts: 13,802
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
Re: head light help
« Reply #12 on: Aug 27, 2007, 03:41:57 PM »
Before you go pulling it apart, are the headlights burned out? Do you have power at the plug? Could just be a bad ground. High beams work? I know there is something else that if it is disconnected the headlights won't come on but I can't think of it right now.
:ninja: The Ninja
R.I.P. Paul Acosta: In work, In play, In life, a friend forever
  • Momentum Man
  • Lego Enforcement
Re: head light help
« Reply #13 on: Aug 27, 2007, 03:57:25 PM »
Hey there are two of these trucks with identical problems, man they even look identical....
http://board.marlincrawler.com/index.php?topic=36497.0
Double Post :rofl:
:ninja: The Ninja
Re: head light help
« Reply #14 on: Aug 27, 2007, 07:09:16 PM »
Double Post :rofl:
not anymore  :disturbed:
85yodaon33s [OP]
  • Male Posts: 227
Re: head light help
« Reply #15 on: Aug 27, 2007, 10:17:13 PM »
head lights are good the running lights work fine and come on with the switch just no head light or hi9gh beam and on top of it all there is no power to the fuse block where the head light fuse is o sorry for the double post my computer is tripping out on me  :smack: :smack: :smack: :smack: :shocking:
85yodaon33s [OP]
  • Male Posts: 227
Re: head light help
« Reply #16 on: Aug 27, 2007, 10:19:58 PM »
well the truck has a name now and it is named rock sloth
4XFlyin
  • Turtle Points: -8
  • Male Posts: 541
Re: head light help
« Reply #17 on: Aug 28, 2007, 07:03:24 AM »
Have you checked the fusible links at the battery yet?
85yodaon33s [OP]
  • Male Posts: 227
Re: head light help
« Reply #18 on: Aug 28, 2007, 08:30:48 AM »
i cant find one at all
4XFlyin
  • Turtle Points: -8
  • Male Posts: 541
Re: head light help
« Reply #19 on: Aug 28, 2007, 08:27:22 PM »
Do you know what it looks like. I don't have a picture to show you. Maybe someone can post one or you can look in your repair manual. I have had two toys with your issue and it ended up being the fusible link.
85yodaon33s [OP]
  • Male Posts: 227
Re: head light help
« Reply #20 on: Aug 28, 2007, 09:28:24 PM »
thanks i will look in my book
Last post Nov 22, 2004, 04:38:55 PM
by 2utadud
Last post Aug 28, 2007, 12:10:53 PM
by Tallchevy
Last post Oct 11, 2007, 09:35:30 PM
by Mistaken
Last post Dec 20, 2011, 10:40:29 PM
by 83 Crawler
Last post Jun 11, 2014, 09:11:34 PM
by Dingman.
