Poll
Cost for bill
300-
0 (0%)
500+/-
2 (40%)
700 to 900
1 (20%)
1000+
2 (40%)
Total Members Voted: 5
Author Topic: 88, 3.0 ignition read (not done deal ) read on  (Read 11735 times)
Plowking
  • Turtle Points: -75
  • Male Posts: 504
  • Member since Jan '05
  • Awesome yota
    • Buy me a drink
« on: Aug 21, 2007, 07:06:22 PM »
I have noticed lately my timing has gotten rather sloppy, sometimes it goes sometimes the timing seems way off, verry inconsistent.  I had it apart today and it appeared that the rotor was not a  perfect fit but not really sure.  my question being what is the most likely problem?
1) My shaft in my distrubitor is good with no wobble or side play.
2) Engine now has almost 10k miles on top and bottom end, yes with all new timing components.
3) Help!
« Last Edit: Jan 29, 2008, 05:51:48 PM by Plowking »
2008 Dodge Diesel  (Cummins Rule)
6.7 manual quad 8 foot bed H&S delete, banks air box
93 yota 3.0 locked up...
2004 Yamaha Raptor 660R
BLACKDOG
  • 3.0 Killer
  • Turtle Points: 718
  • Male Posts: 7,644
  • Member since Aug '04
  • I used to fit
Re: 88, 3.0 ignition timing question please advise
« Reply #1 on: Aug 22, 2007, 12:03:23 AM »
In the past I've had issues with the distributor bolt loosening, and the distributor moving on its own. Might want to check that :dunno:
Also, does the cap look like the rotor has contacted it?  If it seems like the rotor is loose, I would replace it.  Mine have always been a very tight fit, with no doubt that it was tight.
If  your dist., rotor, and cap all seem good, check your wires, and check your coil.  Any of them could be faulty, or the coil could be on its way out.  You may have a problem with the computer itself, but lets check the easy stuff first, shall we?
              -Ronald Reagan
Plowking [OP]
  • Male Posts: 504
  • Awesome yota
    • Buy me a drink
« Reply #2 on: Aug 27, 2007, 07:09:14 PM »
Well I am gonna tell you it is such a random problem, In fact the truck wont start in the morning without the game with the key (ignition). Timing is allover the place you can feel it in the throttle response. Millage is no different than usual. All components replaced 10 or 12 k miles ago.
Another question If the rubber seal was gone would that make a difference on the distrubtor cap?
Thanks
Plowking [OP]
  • Male Posts: 504
  • Awesome yota
    • Buy me a drink
« Reply #3 on: Nov 19, 2007, 05:48:15 PM »
Update 11-19-07
Now I am getting nervious. Have replaced cap and rotor, The old ones were beat, changed but runs the same real poor ignition timing, all over the palace. Engine does seem to miss, randomly. Pulled the code and and came up code #11
meaning Momentary interruption in power supply to ECU  (according to HANES manual)
They are telling me to look at IG sw circuit, main relay and ecu.
My question would be the truck wouldnt start without main relay or IG right?
lucky7
  • Turtle Points: 303
  • Male Posts: 778
  • Member since Sep '07
  • CAN'T POLISH A TURD!
Might want to try a little dialectric grease on your connections .My tranny used to go into limp
mode all the time greased it no problem. :headscratch:
Plowking [OP]
  • Male Posts: 504
  • Awesome yota
    • Buy me a drink
found some time today. Wires replaced, cap rotor as well. going to break out the handy Fluke meter tomorrow. I will post my results. When motor was built all the vac lines were replaced. hoping its not a bad injector vacuum leak.
As for grease I am a big believer in that moisture barrier thanks
Plowking [OP]
  • Male Posts: 504
  • Awesome yota
    • Buy me a drink
Update spent some time over the weeks and felt the TBS sensor was bad, did seem to help till truck was disconnected from battery over nite now the truck wont idle. All spark pugs were replaced, The timing is still jumpy.
Finally got my freshly rebuilt trans in along with the rear main oil seal replaced oil leaks all gone If I could get it to run right.
HELP
Snow is coming and will need for snow plowing season.
lucky7
  • Male Posts: 778
Wondering if you fixed the problem just failed smog computer isn't retarding timing wondering if tps is bad.
Plowking [OP]
  • Male Posts: 504
  • Awesome yota
    • Buy me a drink
Tps was replaced with borg warner TPS sensor and it did run great for about one week, till battery was disconnected for 24 hours while trans was out. It is running worse then ever and am very close to just ordered the air meter box and the ECU, hell what's another $800.00 bucks.
 :rivers: :rivers: :rivers: :rivers:
lucky7
  • Male Posts: 778
Are you running an auto opr stick
Plowking [OP]
  • Male Posts: 504
  • Awesome yota
    • Buy me a drink
Manual 5 Speed trans is that what you are asking? Parts bin says they are selling the ecu for 10.95, 489.00 cheaper than anyone else
http://www.thepartsbin.com/catalog/products.php?year=1988&make_text=toyota&model_text=pickup&category=engine_electrical&subcategory=engine_module
Plowking [OP]
  • Male Posts: 504
  • Awesome yota
    • Buy me a drink
The local Toyota dealer is getting this dinosaur monday I am done searching. Will post the bill when it is fixed
  • Shoutbox Moderator
  • Male Posts: 7,110
  • Member since Nov '05
Plowking [OP]
  • Male Posts: 504
  • Awesome yota
    • Buy me a drink
Well so far the word is timing belt jumped a tooth or two, then I got a call today, and the mass air flow sensor is bad. Something tells me thats not the end, will keep you all posted.
Total bill to date is 950 +/-
BLACKDOG
  • 3.0 Killer
  • Male Posts: 7,644
  • I used to fit
 :yikes:
That sucks. :therethere:  I hope that is it.  Make sure you ask for all your old parts back, so you can test them yourself.  :thumbs:
              -Ronald Reagan
Plowking [OP]
  • Male Posts: 504
  • Awesome yota
    • Buy me a drink
well went to dealer to pick up truck (got the its done call). pay the bill and guess what it wont start 1058.00 later and its about 20.00 worth better. I did get it to start but timing seems to far advanced, where it was retarded when I dropped it off. Needless to say I didnt take it and left a few a-hole remarks to the guy that took my complaint. Oh what a feeling TOYOTA. And we are expecting snow in the next 24 hours.
I am screwed   :rivers: :rivers: :rivers:
Plowking [OP]
  • Male Posts: 504
  • Awesome yota
    • Buy me a drink
Well no truck and no snow its gonna rain. I think I am looking at another 12 hours troubleshooting and a temperature sensor part that is ordered, My truck has a warm dry home at the dealership for the weekend. I am betting total cost of this repair will ring in at 1700.00 to 2000.00
WHAT A BARGIN
  • Male Posts: 7,110
u should have swapped in a good used motor or bought a different truck...that is ridiculous
Plowking [OP]
  • Male Posts: 504
  • Awesome yota
    • Buy me a drink
The motor was punched out and redone 2.5 years ago, The truck is and or was the project from hell. But really a good truck for 20 years old I really cant complain the truck owes me though
Plowking [OP]
  • Male Posts: 504
  • Awesome yota
    • Buy me a drink
It has been 10 days in the dealers hands I am getting nervious. No word yet. Sweet looking 86 on ebay though hmmmm turbo too, damn what a nice truck to gut and make her a runner
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=001&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=110205938325&rd=1
Plowking [OP]
  • Male Posts: 504
  • Awesome yota
    • Buy me a drink
12/21 Talked with dealer today and I think they found the problem. Algea in gas tank yeah really, green living stuff in my tank.
I am looking for a gas tank now, total potential bill is now pushing the $3000.00 mark. Yes you read that right. Need to find good gas tank from one of you guys, That will save me some 400. +/-
Thanks E mail me at JSOHOSKY@comcast.net
« Last Edit: Dec 21, 2007, 02:05:30 PM by Plowking »
KDXSR5
  • Poser Shot Extraordinaire
  • Turtle Points: 61
  • Male Posts: 2,812
WOW!! :yikes: I have never heard that one before! That is wierd. Can't help you on the gas tank, but good luck! Hope that was all that is wrong with it :crossed: , $3000 is more than twice as much as my truck cost me.
DeadlyPeace
  • Male Posts: 593
  • Member since Nov '07
  • HEAVILY medicated for your protection!
    • ToyotaOffRoad
Damn that sucks, sorry dude. Try checking out the www.ToyotaOffRoad.com board too. I know there's quite a few people in your area on there. If no one here has one hopefully one of them might . Good luck.
Never let people think you’re a horrible person and always keep the heart of a young child…
Plowking [OP]
  • Male Posts: 504
  • Awesome yota
    • Buy me a drink
Ok 12/27/07 Still no truck, today I called and told them to clean the tank and this is where it got ugly. the guy on the other end told me we cant clean your tank sir there is (rust) in the tank. I called him out on it, he was handling my truck and went on vacation (service rep type). To make a long boring story a little shorter, a guy I went to high school is trying to hook me up. I was told the only way it was leaving the dealership was with a new tank. And was told it would be taken care of for x amount of $ period. Once it all happens I will elaborate on the story. Original guy helping me was milking me and my wallet and insulting my intelligence. The number I set is what they are gonna do it for we shall see?
 :crossed:
DeadlyPeace
  • Male Posts: 593
    • ToyotaOffRoad
Damn them Sealerships, I call :bull crap:
Good Luck. Hope you get it back soon. Must be going nuts without your TOY.
Plowking [OP]
  • Male Posts: 504
  • Awesome yota
    • Buy me a drink
Pick the truck up tomorrow, the price was set as agreed, road tested it and put 15 miles on it. ( hopefully new gas) A buddy of mine joking with me said when you pick it up dont be suprised if it is loaded with mud. Will post bills in the next day or 2
DeadlyPeace
  • Male Posts: 593
    • ToyotaOffRoad
Glad you finally got it back.......I hope :dunno:
Plowking [OP]
  • Male Posts: 504
  • Awesome yota
    • Buy me a drink
The truck is home I have put 55 miles on it and it never ran better.
Total bill(s) 1085.00 and than 2000.00 for the second round of work dealer had it for 4 weeks.
Strangest combinations of problems I have seen.
New dealer did while they had it
       Air meter box
       Gas tank w fuel pump, and fuel tube assembly
       Temp sensor replaced
       Timing belt replaced cause it jumped a tooth
       Oxygen sensor replaced  (had it laying around for almost 2 years)
       CPU/ replaced although it didnt need one.
Now there is no chance of snow and it was 65 degrees today .
Live and learn, hoefully this post will help the next guy
lucky7
  • Male Posts: 778
What do you think was realy the main problem and did they give any type of warranty?
Plowking [OP]
  • Male Posts: 504
  • Awesome yota
    • Buy me a drink
Green stuff (algea) growing in the gas tank, low fuel pressure, pickup tube clogged, fuel filter clogged, truck was running real bad and driving it anyway I believe caused the timing belt to jump a tooth.
They will get lucky as I dont drive the truck much less than 5k miles a year. I do believe they fixed the problem(s)
They did take 440.00 off the bill. the total on part 2 was $2400.00
Last post Aug 15, 2002, 10:34:25 PM
by BigMike
Last post Nov 10, 2002, 09:30:52 AM
by Paul_Elbisser
Last post Apr 04, 2007, 10:35:02 PM
by AaronB
Last post Jul 23, 2007, 04:13:29 PM
by BLACKDOG
Last post Jan 05, 2020, 08:11:14 PM
by abnormaltoy
