Author Topic: 4.7L question  (Read 1935 times)
ATOYOTA
  • Member since Jun '07
4.7L question
« on: Jun 24, 2007, 11:31:45 PM »
Hi I was just wondering if any of you guys are running a 4.7 V8 and if so what tranny and t-case(s) do you have. Thanks
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
Re: 4.7L question
« Reply #1 on: Jun 24, 2007, 11:55:20 PM »
not too many run the lexus engine in our trucks
their might be a few, but it will probably take some time for them to respond, i cant think of any here offhand who have done it
welcome to the site
toysuzi
  • Male Posts: 7
  • Member since Dec '06
Re: 4.7L question
« Reply #2 on: Jun 25, 2007, 01:56:30 AM »
how diffrent is it from a 1uzfe
« Last Edit: Jun 25, 2007, 02:03:45 AM by toysuzi »
ATOYOTA [OP]
Re: 4.7L question
« Reply #3 on: Jun 25, 2007, 12:58:13 PM »
the 4.7 is a 2UZ-FE not sure how different they are I was just wondering what my options would be for a tranny and t-case, if anyone has any suggestions that would be great. Thanks
Nothingface5384
  • Male Posts: 434
  • Member since Mar '06
  • Dun! Dun!! Dun!!!
    • CarDomain
Re: 4.7L question
« Reply #4 on: Jun 25, 2007, 01:02:03 PM »
the only real differenc3 that i know is the 2uz is all cast iron was the iuz is an al block with al heads, and the obvious poweroutput, and a guess i bigger crank/bore?
« Last Edit: Jun 25, 2007, 01:11:53 PM by Nothingface5384 »
i love your sig your down to a half of a maverick
73 Maverick(jointly owned w/ lil bro)
64 LeSabre(sold)
82 RX7 (scrapped)
92 Toyota p/u 4x4 (dead) resurrecting underway
72 Skylark (dead) resurrecting underway
87 Grand AM (junked)
79 Regal (sold)
90 Geo Prizm (R.I.P)
Nothingface5384
  • Male Posts: 434
  • Dun! Dun!! Dun!!!
    • CarDomain
Re: 4.7L question
« Reply #5 on: Jun 25, 2007, 01:04:58 PM »
also..
http://www.uzswap.com/forum/index.php?topic=7.0
pretty sure that thread will answer your question, havent read it in a while, but its a informative swap thread none the least..
64 LeSabre(sold)
82 RX7 (scrapped)
79 Regal (sold)
BUDDERS
  • Turtle Points: 15
  • Male Posts: 1,335
  • Member since Jul '05
Re: 4.7L question
« Reply #6 on: Jun 25, 2007, 02:42:13 PM »
The 1uzfe (4.0L)and the 2uzfe (4.7) have the same block configuration, but the 2uzfe is cast iron.  Obviously, the internals are different, but they both have 6 bolt main bearings.  From what I understand, the transmissions can be swapped between them.  The 1uzfe had 3 different oil pan configurations : front sump, mid sump and rear sump, all of which will swap onto the 2uzfe.  The 2uzfe 2wd and 4wd tundras had the same oil pan configuration, but the Landcruisers have a different configuration (not sure what).  The 1uzfe also had different exhaust manifolds - 2, mabye 3 different configurations due to the 3 different body styles in came in.  I beleive the heads are somewhat different between the 1uzfe and the 2uzfe - at least the gs400 heads are different (high flow).  The sc400's had a hydraulic cooling fan ran off a pulley/ pump configuration when the ls400's and the gs400's did not.   Oh, The intakes are different too.  The 1uzfe has a side mount throttle body on most of the older ls400's and sc400's and around '98 or '99 they went to a front mount throttle body with a VVTi setup.  I beleive around 2001, the 1uzfe got bumped up to a 4.3L, hence the name LS430, SC430, GS430 - I beleive this was the 3uzfe.  The 2uzfe got a change in '05 and went to a composite intake and a vvti setup.  Sometime in '04, toyota changed the trans in the Tundras and now they don't have a dipstick and run WS trans fluid that's supposed to get changed every 100k miles.  The 2uzfe has always had a direct ignition system but the 1uzfe started of with a dual coil pack system with a rotor and distributor cap on each cam sprocket and eventually went to a direct ignition setup.  The early versions of the 1uzfe engine had an EGR system and eventually Lexus got that engine to burn clean enough, so they removed it from production.  The 1uzfe never had an egr system.  Some of the early LS400's had a air injection system too ('92-93 I believe).
Hope this helps,  I'm nt positive on all my info, I'm just trying to remember from my days working at Lexus and now working for Toyota.
ATOYOTA [OP]
Re: 4.7L question
« Reply #7 on: Jun 25, 2007, 04:59:56 PM »
Thanks for the info guys, Is there an adapter that works on the 4.7 to run a r-series tranny with duals, or what tranny would be the best to use I would perfer a 5spd if thats an option.
8D3TOY
  • Turtle Points: 5
  • Member since May '05
Last post Apr 20, 2003, 04:06:00 PM
by 84runner
Last post Jul 19, 2004, 03:13:47 PM
by robrocketanski
Last post Feb 27, 2005, 12:16:30 PM
by Weldo
Last post Apr 08, 2005, 07:16:22 AM
by mr4x42u
Last post Aug 24, 2006, 06:42:02 PM
by Ewong
