Author Topic: check engine light woes!  (Read 1141 times)
Phazertwo
  • Turtle Points: 8
  • Male Posts: 812
  • Member since Aug '05
  • So many yoda's, so little time!
« on: Jun 04, 2007, 05:09:44 PM »
Ok, so I kept getting a check engine light on and off on my new 92 3.0.  Well, now its staying on.  I pulled the codes and got 21... o2 sensor, no big deal, however the second code on it was 14.
   IGNITION SIGNAL--NO "IGF" SIGNAL TO ECU
--IGNITER/IGNITER CIRCUIT
--IGNITER AND IGNITION COIL/CIRCUIT
--ECU
What do I look for in that?  The truck runs like a top! so it doesn't make sence that the igniter is messed up. Also I just replaced my spark plug wires, could that have somthing to do with it.  I have checked for shorts in the wires, and have found nothing. anyhelp is awsome!
PZ
92 xtra cab, with some stuff...
...why buy when you can build?
BLACKDOG
  • 3.0 Killer
  • Turtle Points: 718
  • Male Posts: 7,644
  • Member since Aug '04
  • I used to fit
Re: check engine light woes!
« Reply #1 on: Jun 04, 2007, 05:30:02 PM »
Pull the main EFI fuse in the engine bay fuse box (big silver thing)  for about 5 minutes.  This will reset your system, and if it is running like a top, eliminate the 14 code (or both if you've already replaced the 02 sensor)  I've had mine come on after doing a cap/rotor, and plug wire swap. The differences in resistance can cause the computer to misread some signals for some reason :dunno:
              -Ronald Reagan
DsrtJeeper
  • Male Posts: 38
  • Member since May '07
« Reply #2 on: Jun 08, 2007, 10:22:53 AM »
I'm having the same problem. Mine runs like a top under power, but as soon as it drops down to idle; all hell breaks loose. The engine starts to load up and the idle speed drops. Check engine light comes on until I give it gas and clean out the engine at higher revs. It's EFI.
Phazertwo [OP]
  • Turtle Points: 8
  • Male Posts: 812
« Reply #3 on: Jun 10, 2007, 01:32:18 PM »
well, I replaced the O2 sensor, and the took the fuse out for about 30 miin, and all is good again.
Nothingface5384
  • Male Posts: 434
  • Member since Mar '06
  • Dun! Dun!! Dun!!!
    • CarDomain
« Reply #4 on: Jun 10, 2007, 07:55:42 PM »
hey would a bad 02 cause low oil pressure at idle and even make it sputter, or not want to go when you give it gas..going slowly or even stall?
i love your sig your down to a half of a maverick
73 Maverick(jointly owned w/ lil bro)
64 LeSabre(sold)
82 RX7 (scrapped)
92 Toyota p/u 4x4 (dead) resurrecting underway
72 Skylark (dead) resurrecting underway
87 Grand AM (junked)
79 Regal (sold)
90 Geo Prizm (R.I.P)
Last post Oct 15, 2002, 01:02:17 PM
by dan_b
Last post Sep 20, 2005, 12:02:20 PM
by GrimReaper
Last post Aug 24, 2008, 11:08:06 PM
by 1987yota
Last post Dec 01, 2006, 11:26:13 AM
by spacoli
Last post Dec 12, 2006, 01:23:28 PM
by BLACKDOG
