Aaron, what does your air tube connect to? So I don't need an OBDII cat, just OBDI?
go to an exhaust shop and get a universal cat. All it needs to be is there and in good shape. You can get a catco for like 100 or so installed around here. I run a Thorley, catco hiflow cat, 2.25 all the way back and a 2chamber flowmaster. The only thing bad I can say is they really don't like an overly rich condition, so if your carb dumps massive amounts of fuel, you won't get more than a month out of the cat. I blew mine out in about 3 weeks, but it smogged just fine.
should of put flanges on your cat so you can take on and off, you only run a cat for the smog and then run stright the rest of time. thats what i did.
Thanks for all the help everyone! What do you guys think about mufflers? I was thinking of just running a glasspack to maximize flow (and they're cheap and easy), but I don't want it to sound terrible either. Any ideas on mufflers that aren't too expensive?
check ebay...there are some uber-cheap sites that have nice stuff...i got a flowmaster hushpower (new) for hella cheap (which i think is nice but have no idea because my is still sitting in the garage)
does anyone know if the thorley headers from summit come with a carb sticker?
unlike all the peopel that run without a cat, i run with a cat, just no muffler, unless i need to have it inspected, then the muffler goes back on... my muffler has a welded sleeve on it, and a muffler clamp attached to the muffler, so its pretty much slide it on, hang the muffler up, and clamp it down.....my cat has a port on the side for a probe, and my truck has a temp probe, but i have heard its fine to run without it.muffler has a turndown
well i know i said i'd post pics of the exhaust so here they are.i went with a thorley header, 2.25" tubing all the way back, a universal cat (with welded-on flanges), and a cherry bomb glasspack.i'm thinking of painting the tubing blue to match the smog rail and the valve cover accentsfrom top to bottom:the thorley header the system from the frontthe system from the rearmy "custom" air intake (just a larger filter, extended stem from the carb to bolt it down and an extended breather hose to the valve cover)the intake and exhaust made a huge power and torque difference.
what did you have to do to get the smog rail on the header?
how loud is that without a muffler? i might have to run mine with no muffler for a couple days and was just curious....
Started by 95TacoTruck General 4WD Discussion
Started by ol yeller Project Research and Build-Ups
Started by MidgetMike Engine
Started by Bigbadtoy Engine
Started by nrgwar Engine
