Author Topic: fuel pump problem need help  (Read 2846 times)
yotatruck
  • Turtle Points: 2
  • Male Posts: 23
  • Member since Feb '06
« on: May 02, 2007, 05:11:09 PM »
i got a 89 toy it just shut down one day like u cut the key of no warning at all i check the plugs geting good fire no fuel changed the filter and fuel pump but i am geting no power to the pump i wire it strait it will run fine at idle when u drive it blows fuse under the hood i looked for a cut wire or short found nun i dont have a clue maybe the computer or a sensor ????
foward progress
BLACKDOG
  • 3.0 Killer
  • Turtle Points: 718
  • Male Posts: 7,644
  • Member since Aug '04
  • I used to fit
Re: fuel pump problem need help
« Reply #1 on: May 02, 2007, 05:24:09 PM »
What fuse are you blowing?  the EFI fuse?  I had a similar issue, and it turned out that the O2 sensor wires had gotten too close to the Cat, burning through the casing and shorting the wires out against each other.  This was causing the EFI fuse (not the relay, the 15amp fuse)  to blow, killing the truck.
              -Ronald Reagan
*ROKTOY*
  • Male Posts: 1,066
  • Member since Nov '06
« Reply #2 on: May 02, 2007, 05:29:02 PM »
Check your circuit open relay.
yotatruck [OP]
  • Turtle Points: 2
  • Male Posts: 23
« Reply #3 on: May 02, 2007, 06:07:08 PM »
circuit open relay is good i bought a new one i will check thr o2 wires yes it is the 15amp fues that is blowing
foward progress
BLACKDOG
  • 3.0 Killer
  • Male Posts: 7,644
  • I used to fit
« Reply #4 on: May 02, 2007, 06:26:10 PM »
yeah, check those wires.  when I swapped my stock crossmember out for the marlin one, I ziptied the wires up since using the marlin crossmember eliminates the little plastic clip holding those wires.  I didn't route them far enough away from the cat ( I also had an exhaust leak blowing right onto them, wich prolly didn't help)  and they just cooked
              -Ronald Reagan
yotatruck [OP]
  • Turtle Points: 2
  • Male Posts: 23
« Reply #5 on: May 04, 2007, 08:59:15 AM »
hey blackdog the o2 wires was melted almoast in 2 that was the problem thanks i was ready to pull my hair out
foward progress
speedemon
  • Turtle Points: 13
  • Male Posts: 267
  • Member since Nov '05
  • When's winter?
« Reply #6 on: Jun 24, 2007, 09:41:07 PM »
mine did the same thing this weekend on a wheeling trip.  i didn't check the o2 sensor wires but that is the first thing i will check.  my efi relay was hot as hell and it kept blowing that fuse.
Trail fix:  I am running a msd fuel pump with a fuel cell so i ended up cutting the wires to the fuel pump and wiring it directly to the battery with a switch.  this worked for a while, but now the fuel pump will run, it will crank, but won't start.  i didn't get to check to see if it had fire, but i don't think that is the problem.  any ideas?
2002 Tacoma sold
'84 pickup SOLD!!
'83 pickup will rise again
'86 sas runner DD
'89 runner project (for sale)
F-Toy build in progress
Last post Mar 31, 2005, 07:34:15 PM
by alwayzbroken
Last post Apr 08, 2006, 05:00:50 AM
by Johnny5
Last post Sep 25, 2006, 11:27:02 PM
by Marlin
Last post Mar 31, 2007, 09:35:41 AM
by robrub00
Last post Feb 05, 2007, 07:05:03 PM
by yotadork83
