Alright thank you everyone I finally understand how this works now! I got one more question, Would it be worth it to buy a turbo transmission so that i could do 23 splines throughout my dual cases? Or is 21 splines in the front and 23 in the second case one going to be strong enough? I plan on doing the marlin 4 inch trail flex kit with 37 inch mtr's and I wanna build it right the first time so that it wont break. Thanks
I'm running an r151 trans in my 85 runner. As far as I know all r-151's are foward shift. now with what i know about dual cases. (I'm running 23 spline foward shift front and top shift 23 spline rear). As mentioned earlier the adaptor dictates whether you can run 4.70 gears. the 4.70's are 23 spline only. What I did since I couldn't afford the adaptor and the gears ate the same time is bought marlin's 23 spline input shaft and put it in my rear case (PRESS REQUIRED) If you even think you are getting 4.70's get the 23 spline adaptor.
MC-14003, TS™ 4.70 Gear Set, 21 spline, $449 MC-14004, TS™ 4.70 Gear Set, 23 spline, $449
Ya thats what i was thinking about... but I have no idea if the 86 tranny is any good
Started by dhbiker456 Project Research and Build-Ups
Started by TATER Engine
Started by yota-tota Project Research and Build-Ups
Started by jafish Toyota Pickup/4Runner Tech 1979-95
Started by Boheefus Toyota Pickup/4Runner Tech 1979-95
