Author Topic: E-locker troubleshooting  (Read 3970 times)
80proof ftoy#20
  • Male Posts: 12
  • Member since Apr '07
  • www.westernfabricators.com
« on: Apr 17, 2007, 09:20:39 PM »
I have a factory hi-pinion third with an e-locker in the front of my f-toy. We blew a fuse this weekend, replaced it and kept wheelin'. now the locker and indicator light stay engaged and on. It was installed and wired by the previous owner so I know that it could be a thousand different things I'm just hoping that someone has a good starting point
  • Administrator
  • Turtle Points: 2124
  • Male Posts: 18,291
  • Member since Apr '02
  • 511:1 Club
80proof ftoy#20 [OP]
  • Male Posts: 12
Re: E-locker troubleshooting
« Reply #2 on: Apr 20, 2007, 09:58:09 PM »
thanks alot for the schematics ill hang on to those links
FIREBALL
  • Turtle Points: 190
  • Member since Feb '03
  • Hi Ho Marlin....u talkin to me
« Reply #3 on: Apr 23, 2007, 08:50:13 AM »
I would try pulling the motor and moving the gear rack back and forth by hand to make sure it's moving freely. Is there a chance you bent your housing? If the axle has a side load on it from a tweaked housing it won't allow the collar to move freely back and forth and could be what caused the fuse to blow. Could also be debri etc in the mechinism.
  • Male Posts: 12
« Reply #4 on: Apr 30, 2007, 09:01:26 PM »
yeah, ill try the mechanical first then move on to the wiring.This weekend @ the tin benders jambo it seemed to be actuating just fine but the in dash indicator light stayed on.The guy that built it was there and pretty much said what you did. ill pull it apart and try it THANKS!
RAZOR
  • Male Posts: 143
  • Member since Oct '05
  • It's all about the LongFields
« Reply #5 on: Apr 30, 2007, 09:19:15 PM »
Some times you can get water in the connections at the third member. And the light will stay on. Take them apart and blow them all out. Did that to mine and was all good.  :biggthumpup:
Finally Straight Axled, e-Locker, 5.29's, Lockright Rear, 13" travel tractor spline driveshaft, CV eliminator, Fully Gusseted front axle, Marlins almighty 5" Trail Flex lift Kit, 36" TSL's
In Marlin Crawler, I trust.
If you got the Nuts, Follow my Ruts!
Lift It, Fat Chicks Can't Jump!
Motocross, Because it Requires 2!
  • Male Posts: 12
« Reply #6 on: May 01, 2007, 10:28:21 PM »
yeah Im wondering if its dirt, or if the bump stop, which hits pretty close to the connections may have damaged something. I guess i need to get off my butt and figure it out!
RAZOR
  • Male Posts: 143
« Reply #7 on: May 02, 2007, 09:57:59 AM »
Ya, Beat it!  :_order:
  • Male Posts: 12
« Reply #8 on: May 02, 2007, 07:12:55 PM »
RAZOR
  • Male Posts: 143
« Reply #9 on: May 03, 2007, 10:32:48 AM »
NO.     For him to get off the comp and get to work
  • Male Posts: 12
« Reply #10 on: May 03, 2007, 10:09:12 PM »
Im not a cruiser guy but thanks for your help! Ill get to work and hopefully have some news for you,if your interested!
Last post Jan 08, 2009, 08:49:39 PM
by Doof
Last post Aug 13, 2009, 07:22:33 PM
by 84pickup
Last post Feb 21, 2012, 01:36:01 PM
by emsvitil
Last post Feb 21, 2012, 04:08:09 PM
by emsvitil
Last post Jan 01, 2022, 06:55:14 PM
by 2manytoys
