Author Topic: Dummy lights comming on.... and off... and on.....  (Read 2431 times)
weirdtimes_7
  • Male Posts: 1,032
  • Member since Nov '06
« on: Mar 26, 2007, 05:52:29 AM »
I got done replacing the spark plugs, wire's, and completely changing out the rear diff seal.... and now my battery light is flashing on and off...what could be making this happen??? I haven't really had time to check to see if the wire from the battery to the alternator is good, but i know the battery posts are good and tight... So what do you think??? I need some advise...
military_stang
:respect:
myyota
  • Turtle Points: -1
  • Male Posts: 120
Have your alternator checked, thats what happens when it starts going bad.
86 4Runner
Solid Axle Swap, 5'' Of Lift, 37x12.50-15 MTR Tires, 5 Speed Manual Swap, Inchworm Duel Cases With 5.7 Gears, 63'' Chevy Springs In The Rear, 5''Trail Gear Springs In Front, Marlin Crawler Third Members, 4.88 Gears With A Detroit In The Rear, High Pinion Front With 4.88 Gears and an ARB, Downey Header, Optima Battery, Trail Gear Sliders.
weirdtimes_7 [OP]
  • Male Posts: 1,032
Dang, i don't wanna replace it.... is there anything else it could be????
military_stang
:respect:
SACD_Runner
  • Turtle Points: 2
  • Male Posts: 217
  • Member since Mar '07
Not always the case. So, If your alt goes out your truck will rev to 3k to keep power to the battery. If your light is twitching i would check your terminals. Could be as simple as not having them tight enough. befor throwing 170$ at a new alternator get it checked along with your battery.
Starting from scratch again...
SQUIRREL MONSTER
  • Turtle Points: 151
  • Male Posts: 657
  • Member since Jul '05
  • squirrel powered by hampsterous oxide!
do the 3rd gens have external regulators? if so id also have that checked. but like sacd runner said, check all your connections, (battery, alternator, and grounds). could be a loose wire bouncing around. if all of em look good, have the alternator checked.
weirdtimes_7 [OP]
  • Male Posts: 1,032
Sweet, thank you all for  your help!!!!
military_stang
:respect:
86 4runner
  • Male Posts: 973
  • Member since Feb '05
  • SAS
when the alternator is going out the battery light and the e-brake light will both come on
86 4 Runner SAS, 37 inch Toyo M/T's, E-Locker rear, Lock Right front. 30 spline Longs, 5.29's, Dual Cases, Warn XD9000i
robrub00
  • Turtle Points: -231
  • Male Posts: 929
  • Member since Apr '05
  • One Day Ill be actually driving my toyota!
clean off your battery connections and make sure there tight and making contact and cheack your ground cable!!!.  i hvad a toy start acting all wierd on me the day i bought it and was driving it home. poped the hood and the battery cable was barely on. and the lights keept going on and off
weirdtimes_7 [OP]
  • Male Posts: 1,032
The cables on the terminals are tight, so it's got to be a ground or ????
military_stang
:respect:
SQUIRREL MONSTER
  • Male Posts: 657
or the alternator is goin. while you are down there, also make sure the wire from the alternator is on tight, if its not, then try it again. if its tight then take it out, have it checked at a local parts place. chances are, if its the original alternator its gonna be due for a new one.
weirdtimes_7 [OP]
  • Male Posts: 1,032
I believe it's the original from purchase from dealership. If so, thats a lot of miles on such a small thing.
military_stang
:respect:
SQUIRREL MONSTER
  • Male Posts: 657
yup, that'd be lots o-miles
Last post Dec 15, 2004, 09:37:16 PM
by reklund5
Last post Aug 13, 2005, 09:37:48 AM
by *FFC*
Last post Sep 13, 2005, 08:56:05 PM
by BruceTS
Last post Oct 29, 2010, 06:20:43 AM
by Dr.Maxwe001
Last post May 13, 2014, 11:45:58 AM
by markl
