Author Topic: Bent front housing? pics included  (Read 2694 times)
toy4x4ota
  • Turtle Points: 31
  • Male Posts: 468
  • Member since May '05
  • learning how to drive
« on: Mar 23, 2007, 03:11:37 PM »
I am putting together my front axle and I think that it is bent becuase on the driver side I cant move the axle with the spindle on.  When i try to put the hub on, it won't go onto the studs or dowel pins because the axle is not centered in the spindle and i wont move freely. i just put in some poly performance birfs and inner shafts but i doubt that they are the cause of the problem.
i can take more pictures if these dont really show what i am talking about.
« Last Edit: Mar 23, 2007, 04:07:37 PM by toy4x4ota »
LIFTED TRUCKS ARE GAY
CTENG in KS
  • Turtle Points: -501
  • Male Posts: 4,295
  • Member since Jun '04
  • ^Alfred the Great
    • CTENG's Eco-Rant
Re: Bent front housing? pics included
« Reply #1 on: Mar 23, 2007, 08:04:45 PM »
Two questions.
Are the inner shafts fully seated inside the birf?
Are the axle shaft assemblies engaged fully into the third member?
toy4x4ota [OP]
  • Turtle Points: 31
  • Male Posts: 468
« Reply #2 on: Mar 23, 2007, 09:27:31 PM »
i know that the inner shafts are seated into the third because i martak the inners.  about the birfs being all the way seated in the inner im not sure because i did not use any c-clips.
inmyownsummerami
  • Male Posts: 243
  • Member since Oct '05
  • Rockin the White Wheels
« Reply #3 on: Mar 23, 2007, 09:37:10 PM »
you didn't use the c-clip that keeps the inner shaft from sliding into the birf?
WHITE WHEEL ROCK CRAWLERS "If your wheels ain't white, they ain't right"
 :greengrin:My 1st Gen. Toyota SAS (2wd to 4wd) :greengrin: (In Progress)
RIP "Goody Goods" My DDW Brother
alwayzbroken
  • Turtle Points: 603
  • Male Posts: 1,905
  • Member since Feb '05
« Reply #4 on: Mar 24, 2007, 01:08:11 AM »
Are the knuckles shimed properly?
toy4x4ota [OP]
  • Turtle Points: 31
  • Male Posts: 468
« Reply #5 on: Mar 24, 2007, 10:03:58 AM »
on the poly performance shafts there isnt a spot for the c-clip to keep the two from sliding into eachother, i didnt use the most inner c-clip either in case i was to ever break a birf, i also didnt use the c-clip on the hub side because i like to take my knuckles off the camo method.
i didnt use a tool or anything to check the preload so hopefully your right.  im going to have to check that today
CTENG in KS
  • Male Posts: 4,295
  • ^Alfred the Great
    • CTENG's Eco-Rant
« Reply #6 on: Mar 24, 2007, 01:10:26 PM »
If you didn't have much trouble removing the old birf and shaft combo then bent housing would not be my first thought.  More than likely something is just out of alignment.
toy4x4ota [OP]
  • Turtle Points: 31
  • Male Posts: 468
« Reply #7 on: Mar 24, 2007, 02:29:49 PM »
a friend just gave me the housing with the axle truss already welded on and everything. so i have no idea about the old birfs coming in and out easily. i still gotta check the knuckle though, not till later working on the roomates truck today.
8D3TOY
  • Turtle Points: 5
« Reply #8 on: Mar 24, 2007, 03:39:12 PM »
If the trussing was not welded in a proper manner it may have warped the housing with all the heat from the weld.
SACD_Runner
  • Turtle Points: 2
  • Male Posts: 217
  • Member since Mar '07
« Reply #9 on: Mar 24, 2007, 09:36:15 PM »
Agreed. I'd recomend checking the knuckels too, Just in case.
Starting from scratch again...
madhunt
  • Turtle Points: 52
  • Male Posts: 490
  • Member since Apr '06
« Reply #10 on: Mar 25, 2007, 10:59:59 AM »
if they welded the truss on with one fat bead all the way across, its warped for sure. :twocents:
HIGH AND TIGHT OFFROAD
toy4x4ota [OP]
  • Turtle Points: 31
  • Male Posts: 468
« Reply #11 on: Mar 25, 2007, 11:18:13 AM »
the truss has a lot of undercut on the weld but i think i see the start and stops of each weld, as if he stiched it. but i dont have any idea how he did it though, and my friend doesnt remember how he welded it
DTB
  • Shoutbox Moderator
  • Turtle Points: 2
  • Male Posts: 7,110
  • Member since Nov '05
« Reply #12 on: Mar 25, 2007, 02:12:00 PM »
i wouldnt say that for sure.....more likely if it was an earlier axle....
if it has the stock truss on the bottom long side it would be alot less likely to "peel" up from warping
Quote
CTENG in KS
  • Male Posts: 4,295
  • ^Alfred the Great
    • CTENG's Eco-Rant
« Reply #13 on: Mar 25, 2007, 08:23:33 PM »
if it was an earlier axle and there is no bottome truss you can always try welding a bead along the bottom to get it to warp back the other way...might get it str8 enough to run.
toy4x4ota [OP]
  • Turtle Points: 31
  • Male Posts: 468
« Reply #14 on: Mar 27, 2007, 11:57:38 AM »
i took off the bottom knuckle plate and added a thick shim, took off the steering arm and took out a thin and thick shim, and it seems that it fixed the problem.  so i am going to run and hopefully wheel my truck at the local spot this weekend.  its been too long since i have driven it and i took it on a little spin this morning. thank you everyone who gave me info. :biggthumpup:  :beerchug:
dallas
Last post Sep 23, 2002, 04:37:52 PM
by MD11Fr8Dog
Last post Jun 06, 2006, 06:20:39 PM
by krawlz
Last post Jul 06, 2006, 06:06:11 PM
by yotaboy79
Last post Aug 06, 2006, 06:31:23 PM
by shmizle
Last post Feb 26, 2008, 08:53:27 AM
by OOPS
