Author Topic: Extension Cord for Welder?  (Read 1503 times)
854x4
  • Turtle Points: 722
  • Male Posts: 160
  • Member since Aug '04
« on: Mar 11, 2007, 10:29:06 PM »
I own a small harbor freight flux core welder, this thing is perfect for what I need it for except it only reaches 10 feet.The plug on it is just a 110 plug and I have it pluged into either a 15 or 20 amp breaker. I want to use a extension cord so i can move it out of my garage. The manual says I need 12 awg and 20 amps minimum up to 30 feet for a extension cord but all I can find around here are 12 awg cords rated at 15 amps.Also the specs say the power consumtion is 120vac,24amps. Can I use a extension cord rated for 15 amps if I only use 25 feet or less? What kind of cord do i need? I have tried to provide as much info as possible I hope someone can help.
« Last Edit: Mar 11, 2007, 10:36:55 PM by 854x4 »
1985 Toyota X-Cab 22-RE 4.88 gears Detroit Locker Rear, Open Front 4 1/2" Lift 32x11.50 BFG Mud on 15x10 rims. LC Rotors, 92 IFS Calipers,MC,Dual Diaphram Booster.
dizzydevil
  • Turtle Points: -70
  • Male Posts: 1,491
  • Member since Dec '04
Re: Extension Cord for Welder?
« Reply #1 on: Mar 12, 2007, 12:04:18 AM »
I have a Lincoln 110 wire feed welder that i run off a 12AWG 25' extension cord ( regular cord you buy at home depot)all the time and have never had a problem. I have welded body panels and cages together with it.
howdy
  • Member since Oct '03
  • I Love My Marlin Crawler!
« Reply #2 on: Mar 12, 2007, 10:34:44 AM »
I have a lincoln 175 and a plasma cutter that I run off of 50' of 10/3. I just went down to Lowes and bought the commercial grade heavy duty 10/3 and cut the plugs off and put on the plugs I needed for my welder and dryer outlet. You should be fine with some 12/3.Its probably rated 15amps because of the plugs.
For wire size check out this link.
http://www.elec-toolbox.com/calculators/voltdrop.htm
86bobbedtoy
  • Turtle Points: 686
  • Male Posts: 3,938
« Reply #3 on: Mar 12, 2007, 12:39:32 PM »
go to lowes or home depot and pick up any 300amp 3 core round wire usually black or yellow like .79-2.55 per foot. but im using 45' of 300 amp 1.35 per foot for my lincoln 220 promig175 and the wires have never gotten hot and works great.  Heres a tip, wire it into a 220 outlet (washer) just eliminate your neutral wire and 1 hot. that way your outlet isnt getting overheated, let me know if you need any help.
  • Turtle Points: 2872
  • Male Posts: 8,707
« Reply #4 on: Mar 12, 2007, 12:45:29 PM »
if your welder is like mine, or ctengs welder, then an extension cord is fine... if actually got mine plugged into a crafstmen 3 plug outlet thing, on a reel.... its got its own breaker on the tap though so if it trips, i jsut reach down and reset it.... just dont use like 18 guage.... 12 or 10 will be fine
Last post Dec 20, 2004, 06:16:17 PM
by MUDJUNKY
Last post Jun 03, 2005, 09:38:21 PM
by BUBBA
Last post Feb 07, 2011, 02:19:25 PM
by superyota
Last post Apr 17, 2011, 07:17:28 PM
by Burl
Last post Jun 22, 2023, 04:55:43 AM
by Gnarly4X
