91 toyota build..update 6/7/08
Started by Austin W, March 11, 2007, 08:58:01 PM
Austin W
so i got the sas all done her are some pic's, drove it on the road and it handled great with no issues! Hope to take it wheelin this weekend, probably gonna buid a squar drive line for it.
Cleaning up the frame ang getting the motar mount plates welded
Getting the frame tubes cut and welded in
Getting the spring hanger tacked on/ hanging the springs
Mounting up the axel
Getting the skock hoops welded on and the shocks mounted
Austin W
and here are some finished pic's with the 35's mounted, overal i am happy with the height,need to raise the rear a bit though.
DTB
did you end up mounting the spring hangar completely flush? looks good btw
Rockcrawlintoy
Quote from: Aaronb on March 13, 2007, 11:33:29 PM
yeah i would definitly move the back shackle.
i dont see anything wrong with the shackle angle. thats how i am goin to run mine.
DRew
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
Austin W
Quote from: DirToyBoy on March 19, 2007, 07:37:12 PM
Yep, mounted it flush with the frame, will get closer pic's tomorrow
Austin W
Quote from: Rockcrawlintoy on March 19, 2007, 07:45:07 PM
DRew
Yeah, i havn't taken it wheel yet so i'm not going to change it entil i test it.
86bobbedtoy
ToYocRawleR
Does your exhaust have a 'P' trap in it??????
Rigs:
05 F-250 Powerstroke
93 RunneR ...Build-up  http://board.marlincrawler.com/index.php?topic=85644.0
fortysixandtwo - I drove through Dunsmuir once I dont think anything there is "super nice"
Just kidding man. I guess there is, its your bed
Austin W
Quote from: ToYocRawleR on March 19, 2007, 10:02:34 PM
not sure what you mean, it is just a 19.99 cherry bomb turbo muffler w/ 2 1/2" from the cat back.
Max Heintz
Austin W
Thaks for all of the nice words guys, i still need to fix the rear pinion angle once i get the final rear height, btw whats been your guys method for determining the pinion angle in the rear, in always thought just get the diff pinion to point at the yoke on the transfercase, any suggestions?
twistedtoy92
well it looks really nice man!!! i cant wait to get my 92 done...... i had an 89 extracab but rolled it on black ice...day after christmas..... merry fricken christmas man!!! but anyway, keep up the greatwork!! i'll keep my pic posted when i get all my parts rounded up!!! I love to see guys swappin the straights in!!! too bad they even started making the IFS in the US!! I'd be happy if they were SOLID alll the way through!!!!! save me a lot of time and money for sure!!!!
Austin W
Quote from: twistedtoy92 on March 20, 2007, 03:46:48 PM
Yeah i like the 3r gens, i can't believe they even put ifs on the new fj's. They spent all this time designing it and still put ifs on it.
twistedtoy92
No doubt!!!! I guess it's for the people who care more about the "RIDE" than how it can handle off road and on the rocks!!! You see the build on the Ultimate FJ in Fourwheeler mag??? They made that thing straight up rock!!! I think they put 37 inch BFG krawlers on it too!!!!! wish i had the money to mess around like that!!!
Austin W
they got all the money in the world to put into those builds for that event.Dynatrac axels front/rear under an fj, flop...
twistedtoy92
Ramrod
if your using a cv the pinion should point at the t-case but if your not the pinion is supposed to sit at the same angle as the t-case.  use a degree finder and do it right
Austin W
I am just useing the stock drive line(non cv) entil i get the duals. i am getting a noise/vibration from the rear end ever scince i put the chevy's on. I will check the angle on both when i get a chance.
twistedtoy92
Do you have any CV's? I was just thinkin about it and i have 3......i believe!! i need to have some customs set up or just give Tom Woods a call!!
Austin W
i don't want to spend the money on a nice drive line to have to just get rid of it when i get duals
twistedtoy92
yeah, i hear you there man.... thats why when i do my SAS I'm gonna do the duals at the same time..... I'd rather do it all at once and the best way that i can.... even though i want it SAS right now!!! Patience is a virtue........   :sleepy:
hollywood_toy90
man about the thread issue (i know it was a while ago but..) are you sure you had the bearing all the way seated in?  i have had the same issue too, but all i did was lift up on the rotor a bit and wiggle the bearing in all the way.  then but the bug nuts on and they have plenty of thread left!  great build!
Austin W
#53
Quote from: hollywood_toy90 on March 21, 2007, 11:39:39 AM
Yea it turns out the rotar/wheel hub was getting caught up on the main seal that seals it. i loaded it up with a ton of grease and had my dad turn the rotar while i tighened the nut to try and seat it. It's good now.
Austin W
so it's been a while scince i have updated, my computer crashed so i have been gone gone but i have an update. So dad just decided he wanted 4.7's so we got a cv driveline made for the rear. For the front driveline i just mad one from an old driveline i had and used the ifs cv part. going to be getting 5:29's for it soon. We took it out for it's first run last weekend and everything was perfect, the tires on't rub at all with the 35's.i anded up using 2 1/2" lift blocks for the rear toget it to match the front. Here are some pic's from last weekend and stuff.
DTB
sweet..im likeing the homemade ramp  :biggthumpup:
milla85
Nice build up man! it looks great. Is that your red 4 runner in you avitar? if so do you think you could show us some pics? its look supa nice.
Austin W
Quote from: milla85 on April 23, 2007, 09:00:17 PM
Ya it's mine ihve it posted in the rig gallery http://board.marlincrawler.com/index.php?topic=31098.0
Heres a pic
twistedtoy92
lookin pretty sweet man!!!! keep up the good work!  :thumbs:
