I am selling my axles:
14 bolt -
4:10's welded carrier
new brake lines
has custom designed drive flange so you can run a toyota drive line. Cost $300
f/f 8 lug.
Dana 44
8 lug
4:10's welded
dedenbear knuckle
avalanche high steer arms
full high steer with 1 ton rod ends setup with toyot drag link
has fj80 pitman arm.
Both axles come with 26" steel braided brake line from the axle to fit toyota brake line.
Im asking $1000 for both. If you add up the cost in parts its way more than that so basically you're getting the axles for free.
Located in paradise, ca
Can assist in transporting up to 120 miles.
