Author Topic: High Steer  (Read 4980 times)
Yota Tony
  • Male Posts: 274
  • Member since Feb '07
High Steer
« on: Feb 16, 2007, 08:46:50 PM »
So I need to buy a pitman arm to go with my high steer, lift and IFS box.
Running rears up front, Inchworm high steer arms...lift is about 5" total.
What arm do I need to buy?
Anthony
Looking For 82-83 Hilux - Must Be 5spd, able to run and drive, Square headlights and no rust!
82 Build - http://board.marlincrawler.com/index.php?topic=31283 - Dead
Tice
  • Turtle Points: 8
  • Male Posts: 881
  • Member since Feb '05
  • I named my son Wheeler!!!!
Re: High Steer
« Reply #1 on: Feb 16, 2007, 08:55:38 PM »
If you buy the hi-steer kit from Marlin it'll come with an arm.  The one in the kit will be fine with 5 inches. :beerchug:
I don't need a winch, I wheel a TOYOTA!!!!!!!
www.wheelingarizona.com
YotaJosh
  • Male Posts: 499
  • Member since Dec '06
Re: High Steer
« Reply #2 on: Feb 16, 2007, 09:03:31 PM »
Out of curiousity, what's the minimum lift required to install high steer?
'79 Short Bed Pickup 4x4
'04 4Runner V8 Sport 4x2
Tice
  • Turtle Points: 8
  • Male Posts: 881
Re: High Steer
« Reply #3 on: Feb 16, 2007, 09:08:23 PM »
If you mount the box right I'd say 2 inches. :dunno:  I ran 3" with mine and the arm would contact my springs on full stuff. But my box was mounted pretty flat.  I bought a flat arm from some place that I can't even remember right now( too many :beer:) :gap:
Yota Tony [OP]
  • Male Posts: 274
Re: High Steer
« Reply #4 on: Feb 16, 2007, 09:42:13 PM »
I already have all the parts I need for high steer out side of a pitman arm.
Anthony
mudmaster
  • Turtle Points: 3715
  • Male Posts: 2,855
Re: High Steer
« Reply #5 on: Feb 17, 2007, 08:16:20 AM »
Sky Mfg has a couple different arms
Time to go wheelin!
Tice
  • Turtle Points: 8
  • Male Posts: 881
Re: High Steer
« Reply #6 on: Feb 17, 2007, 12:43:08 PM »
Thats where I got mine!! :hammerhead:
Since you already have the stuff and just need the arm, buy the one Marlin sells.
Yota Tony [OP]
  • Male Posts: 274
Re: High Steer
« Reply #7 on: Feb 17, 2007, 01:45:21 PM »
I'll gladly buy Marlin's (I need to get my FJ80 TREs from him) but will it work with my suspension set up?
I don't want to buy the wrong arm and be up :pokinit: creek...
Anthony
Tice
  • Turtle Points: 8
  • Male Posts: 881
Re: High Steer
« Reply #8 on: Feb 17, 2007, 04:51:38 PM »
Have you put the springs on the rig yet?  If not and you are worried I would get the lift on and then the steering arms then mount the box with Marlins arm on it. That way you can mount it in a position that it will not interfer with anything.
Yota Tony [OP]
  • Male Posts: 274
Re: High Steer
« Reply #9 on: Feb 20, 2007, 11:19:13 AM »
Don't have the springs on yet.
Want to have all the parts here so I have as little down time as possible.
I think I'm going to grab Marlin's Pitman Arm.
Anthony
Sparkie247
  • Member since Mar '07
Re: High Steer
« Reply #10 on: Mar 08, 2007, 06:35:23 AM »
The critical point here is the box mounting.  If you blow that or the bumpstops, you'll hit anyway.  You also have to watch your tie rod to pitman arm clearance.  I worked all of these angles very carefully and I still get teh slightedst bit of contact between the two...
Yota Tony [OP]
  • Male Posts: 274
Re: High Steer
« Reply #11 on: Mar 08, 2007, 11:13:06 AM »
Thanks.
Anthony
Yota Tony [OP]
  • Male Posts: 274
Re: High Steer
« Reply #12 on: Mar 30, 2007, 10:58:38 AM »
Is it possible to drill and ream the stock IFS arm for an FJ80 TRE?
Anthony
dirtchicken
  • Turtle Points: -44
  • Member since Nov '06
Re: High Steer
« Reply #13 on: Mar 30, 2007, 01:14:03 PM »
Yes you can. That's what my arm is. You can buy the inserts for the pitman arm. Just be careful when you weld the insert in. I couldn't get the castle nut on far enough to get the cotter pin is so I had to improvise. I do think Marlin has one piece arms made now so you shouldn't have that problem like I several have had.
Yota Tony [OP]
  • Male Posts: 274
Re: High Steer
« Reply #14 on: Mar 30, 2007, 06:52:14 PM »
Where can I get these inserts?
Never seen em.
Anthony
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
dirtchicken
Re: High Steer
« Reply #16 on: Mar 30, 2007, 08:09:30 PM »
That's what you need.
TurtleTappers91
  • Turtle Points: -5
  • Male Posts: 310
  • ..I walks me a mudhole and I stomps it dry... baby
Re: High Steer
« Reply #17 on: Mar 30, 2007, 10:05:33 PM »
X2 on SKY's billet pitman arm...
 It is the BEEF. :biggthumpup: And a way to change the geometry of the steering. I bought mine to correct my problem of the All Pro pitman arm T.R.E. hitting the tie rod. Many people had told me to notch my frame in that critical area. fools!  :hammerhead: The O.T.T. Industries arm looks sweet too. :puke: Wheres the BEEF?
Does Marlin have a Billet Pitman in their Billet Hi- steer kit? Or do they give you the standard?
Last post Nov 12, 2007, 04:53:14 PM
by 79coyotefrg
Last post Jan 07, 2008, 08:38:14 AM
by offroadin88
Last post May 11, 2010, 01:37:08 AM
by NWFshrman
Last post Jun 06, 2010, 07:22:42 PM
by minicrawlin
Last post Jun 24, 2010, 12:27:08 AM
by THK Matt
