Author Topic: HIGH BEAMS DON'T WORK  (Read 2860 times)
mudmaster
  • Turtle Points: 3677
  • Male Posts: 2,849
  • Member since Feb '05
« on: Feb 16, 2007, 02:49:19 PM »
Here's the problem: Truck is a 1980. The high beams only work when you use the "flash to pass", when you put them on in the normal position they will not go on. I'm at a loss, but I'm thinking it's the switch. Any and all suggestions are welcome.
Time to go wheelin!
kevin286
  • Turtle Points: -2
  • Male Posts: 13
  • Yeehaw
Re: HIGH BEAMS DON'T WORK
« Reply #1 on: Feb 16, 2007, 07:55:16 PM »
I believe your truck should have 3 fuseable links (coming of the hot side of your battery). That would be where I would check first.
Just my 2c
'94 4Runner, 3.0, Downey HD Coils, Edelbrock IAS Shocks, K&N Drop-in, ARB Bull bar w/warn M8000
'83 Toy longbed. 35"s on MT Classics, DP bed, Post '86 rearend, 5.29s, rebuilt .040 over, 216cam, warn m8k w/syn rope, MC hysteer, bla bla.
mudmaster [OP]
  • Male Posts: 2,849
« Reply #2 on: Feb 17, 2007, 07:22:56 AM »
I don't think it's that just because they work on "flash to pass" I'll check anyway though, thanks.
Time to go wheelin!
  • Turtle Points: 1088
  • Male Posts: 9,757
  • Member since Oct '04
« Reply #3 on: Feb 17, 2007, 01:13:24 PM »
It most likely is in the switch.  Take a light tester and check your wires.  Find out which wire sends the signal to the high beems, trace it back to the wiring from the light switch and see if it's outputting when you pull back.  If not, problem is for sure in the switches and you could just snag some from a junk yard.  This is a good time to upgrade to intermittent wipers if you don't already have them, but remember to get the intermittent relay too so it'll work :thumbs:
mudmaster [OP]
  • Male Posts: 2,849
« Reply #4 on: Feb 19, 2007, 05:38:04 AM »
That's what I was thinking too. Weather is crappy here now so I'm waiting. Thanks, will update when I get it figured out.
Time to go wheelin!
Gearhead Wiki
  • Turtle Points: 51
  • Male Posts: 83
  • Member since Oct '05
    • Gearhead Wiki
« Reply #5 on: Feb 19, 2007, 05:53:08 PM »
my truck  is an 82 and it did the same thing. new switch from a junk yard fixed it.
My automotive wiki project https://www.gearheadwiki.com
81tyota
  • Male Posts: 13
  • Member since Dec '05
  • ^ thats my 81 p/u 3 1/2" lift and 35's
« Reply #6 on: Feb 27, 2007, 04:24:08 AM »
my 81 has that same problem to, guess i now were to check first now!
4XFlyin
  • Turtle Points: -8
  • Male Posts: 541
  • Member since May '05
« Reply #7 on: Feb 27, 2007, 06:28:44 AM »
Yes it could be the switch, but make sure your fusible links are good. Had this issue before and it was the fusible links.
82 1st Gen with 4.3L vortec and 4l60e. Linked front and rear
My build up. Getting linked
http://board.marlincrawler.com/index.php?topic=50700.msg711361#msg711361
olemisstoy88
  • Turtle Points: -381
  • Male Posts: 521
« Reply #8 on: Mar 01, 2007, 06:50:30 AM »
mine has the same problem, I just pull the stick back and thump it fwd to turn them on.
88. 4x2  Total chaos 6.5" caddy uniball kit  Racerunner 2.5 x 14" coilovers on front, 62" deavers, fabbed engine/shock cage, bed cage, roll cage and great frame, complete int., (5) 5x4.5 outlaw II w/235 buckshots <----- parting out! make offer
'84 4x4 . 5 speed 22r  3.5" lift  33x10.5s bfg MTs  Hannamann Glass frontcap, 32/36weber, LCE swirlie plate, Magnaflow,
"Im madder than Toby Keith at a Dixie Chicks concert"
Last post Jan 17, 2006, 08:32:26 PM
by Skinny_Pedal
Last post Jan 30, 2012, 11:56:14 AM
by Hunterwarren
Last post Feb 03, 2015, 05:36:41 PM
by hodge built
Last post May 25, 2019, 05:23:30 PM
by OOPS
Last post Mar 15, 2020, 10:18:09 AM
by RN48
