Author Topic: 2wd cab vs 4wd cab  (Read 1431 times)
Trail-runner
  • Turtle Points: -39
  • Member since Jul '04
2wd cab vs 4wd cab
« on: Feb 12, 2007, 05:13:32 PM »
Is there any difference in cabs on a 94 2wd vs 4wd? Thinking of doing a cab swap.  4wd cab is messed up pretty bad.
86bobbedtoy
  • Turtle Points: 686
  • Male Posts: 3,938
  • Member since Oct '06
Re: 2wd cab vs 4wd cab
« Reply #1 on: Feb 12, 2007, 05:53:23 PM »
what year? nothin different except the fenders. mayby if your carbed or efi the other might be the other, if you get it.
Trail-runner [OP]
« Reply #2 on: Feb 12, 2007, 06:20:25 PM »
94 4wd cab is wrecked... want to replace with 92 2wd cab.
Gittinit
  • throttle jockey!
  • Turtle Points: 28
  • Male Posts: 2,293
  • Member since Sep '06
  • out from under my rock, and ready to roll
« Reply #3 on: Feb 12, 2007, 06:44:19 PM »
Should bolt right up. The difference as stated above would be if there are difference in trucks like, auto/manual,  efi/carb.
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
rockcrawlinredneck
  • Turtle Points: 109
  • Male Posts: 404
  • Member since Jul '06
  • 1st Gen's rule
« Reply #4 on: Feb 12, 2007, 07:25:32 PM »
You may need to swap the wiring harnesses on them but that is fairly easy. As far as the physical characteristics go I am with ^them^ just the fender's and the T-case hole in the floorboard should be different. Also the gauge cluster may not have a 4x4 light, if you use the stock 2wd harness it will most likely not even have the plug for the 4x4 switch.
 Kevin
86bobbedtoy
  • Male Posts: 3,938
« Reply #5 on: Feb 13, 2007, 10:35:51 AM »
like stated above, good luck be sure to post pics.
Trail-runner [OP]
« Reply #6 on: Feb 15, 2007, 09:45:31 PM »
Thanks for all the replies.  The reason I asked this question, I bought a 94 4x4 for $400, that had been rolled  :greengrin:. The drive-train and frame is in good condition.  I thought I had a chance to buy a 92 2wd that had been hit in the bedside.  Anyway the deal fell threw.  Looks like the '84 truck gets a '94 fuel injected 22re with a W56.  This way, I can retire the 85 4runner from DD duties, and install crossover steering with the IFS steering box from the 94.
