Custom Beadlocks
Started by rednk1980, February 02, 2007, 01:30:45 PM
rednk1980
tacostewie if you can get the okay from marlin and email me a logo i can see what we can do with putting it on the 16.5 locks there should be more room on the lock becuase it is a bigger wheel size. Ill pm you my email address
rednk1980
so me and my business partner were doing some research on the goods and bads of weld on kits and found out that alot of people don't want to run them because they have to cut their existing rim. We'll we've come up with a way to not have to cut you rim. Granted it will make your wheel 3/4 of an inch wider however if eliminates all of the cutting envolved. All you do is take the inner ring and weld it on to the outer most lip of your existing ring. then mound your tire like you normally would and bolt the outer ring on. It takes the cutting out and helps with the leak prevention. Let me know if this would be a better idea or if i should just stay the course and make the other ones where you cut your bead off.  :dunno:
alwayzbroken
Quote from: rednk1980 on February 07, 2007, 09:28:04 PM
Dude where have you been? That is the style that pretty much all the kits on the market are. There is no reason to cut your outer bead anymore. The ones that drop inside the lip are what I have and they add about 1.5." They work great.
rednk1980
Quote from: alwayzbroken on February 07, 2007, 09:43:00 PM
Yeah so i just go told that i was stupid by about a million and one people on another forum  :smack: turns out i make things way to complicated carry on foreget what i said.  :_oops:
alwayzbroken
rednk1980
give me a break im only 17 still gotta a lotta learnin to do.
YotaJohnBoy4x4
alrighty guys.... im the business partner/cad drawer of the locks.... has any one put these on a 10 wide rim... how did you like it?
"lil truck rolling on 37s"
rednk1980
ah... my partner in crime has arrived! Hes the brains of the operation
yotaboy79
i personaly wouldent put them on a 10in wheel unless your running a 16"+ wide tire but thats just me only reason i wouldent is for fear of blowing inner beads in the snow i mannaged to blow a rear inner bead with 36x12.5x15 tsl sx's the wheels started as 15x8's the bead locks made them about a 15x9 although i was also running about a half pound of air pressure but if you already have 10in wheels you might as well try it if you dont want to buy new ones if nothing else you can sell them and get some new ones
rednk1980
probably be what i end up doing is selling my 15/10's and buying a set of 15/8 steel wheels aren't that hard to get rid of.
YotaJohnBoy4x4
yea ill be finding some 8s
Quote from: yotaboy79 on February 07, 2007, 10:24:27 PM
I'm with ya on this one.
I've always felt that a 4.5" difference is ideal.
12.5" wide tire = 8" wheel
13.5" wide tire = 9" wheel
14.5" wide tire = 10" wheel
etc
alwayzbroken
I planned on getting 40" Rockers that are 16.5 wide so I welded rings to 15x10s. Well plans changed so I ended up running my 38x12.50 TSLs and have not had a problem. The tire actually went flat and I drove on it that way for quite a while and the inner bead held. I have run the combination over some really wicked trails and surprisingly they held up fine. I agree it is not ideal but I don't think it would be the end of the world. I personally would not hesitate to run a 14" tire on a beadlocked 10" wide wheel.
rednk1980
The computer is setup now, so were gonna start trial cutting.
TacoStewie
cant wait to see what you can do
4THEWKN
Loki
word...you should have a digital camera on at all times while cutting these out ;)
88 turd SAS with some "stuff" under it.
MY BUILD UP THREAD
rednk1980
Weve got the program figured out and the rings in the computer saved tomorrow were getting metal and monday were gonna cut some prototypes out. I have to find a set of 8in rims to try these out on. And get ahold of fastenall to see what kind of deal they will give us on nuts and bolts.
TacoStewie
4THEWKN
rednk1980
Stewie did you talk to marlin about us using the logo and i got a new idea for ya.
TacoStewie
i kinda brought it up and he seemed like he liked it.  they are just trying to figure out the details. but Marlin is going to be in Reno the rest of the week.  so i will get more info on Monday.
4THEWKN
rednk1980
Awsome sounds like this is gonna work
TacoStewie
4THEWKN
alwayzbroken
I bought bolts for 20.00 for one set at Fastenal. I think they were 3/8" x 1.5" long with washer and nylock nuts.
rednk1980
were gonna use 3/8 bolts but with nutserts instead of nylocks (at least on our sets) if you want hardware with them it might be a little more cost i don't know. Still waiting to see if Fastenal will give us a break for buying in bulk
