Need more info. What year is it? What is it in? For example a 4.3L from 2000 Jimmy up will not run at all if the distributor is not set at 0 degrees. The computer will adjust timing as long as the distributor is set at zero. It will crank, but not run. Is it getting fuel? If so, what pressure fuel is needed according to the FSM? Have you checked for spark?
