Seems like you're just asking to bust motor mounts if you just lift the back end without lifting the engine.
you will need to raise your engine as well if you are raising your tranny or tcase. 4crawler sells some easy bolt in mounts. http://www.4crawler.com/4x4/ForSale/MotorMount.shtml and also has a good FAQ for questions such as this. If you were to raise your tcase and tranny without raising your engine to match there would be exaggerated angle on your output u-joint as well as potentially clearance issues with your fan and fan shroud in addition to increased stress on your motor mounts. I have his mounts and plan on using them along with fabbing up a new crossmember/skid plate mount to raise my drive line 2" on my 83 mini. I do have a 2" body lift as well so there wont be the sheet metal clearance issues that you might have. good luck.
Started by yota18 Engine
Started by 93hunter Engine
Started by hilux-1983 Engine
Started by 84Flatbed Toyota Pickup/4Runner Tech 1979-95
Started by RynothealbinO Toyota Pickup/4Runner Tech 1979-95
