Author Topic: locker Vs,spool  (Read 2632 times)
croberts
  • Member since Apr '06
locker Vs,spool
« on: Jan 24, 2007, 06:10:45 AM »
I'm about to put 5.29s in my 84. I want to know if it would more benefitary for me to put a spool or a assuie locker in the rear. its getting an assuie in the front but i've heard a spool makes it harder to take tight turns, i do alot of woods wheelling. this truck doesn't see the street. mud, hills, some rock, and i run over trees alot if that helps .
Boheefus
  • Member since Dec '06
Re: locker Vs,spool
« Reply #1 on: Jan 24, 2007, 07:19:01 AM »
spool the rear if it does not see the street, hell, even if it does. An Aussie or lockright can be annoying and squirrely on the street, but a spool acts the same all the time
KYOTA
  • Turtle Points: 1759
  • Member since Jan '04
  • Wreckin Ball '09
Re: locker Vs,spool
« Reply #2 on: Jan 24, 2007, 10:14:51 AM »
spool or save yourself some $ and weld the rear and put the extra $ in the front with a Detroit.
Boheefus
Re: locker Vs,spool
« Reply #3 on: Jan 24, 2007, 10:16:23 AM »
my taco had a welded ass before I sold it, held up just fine to 5.29s 35's and the 3.4
olivedrab85
  • Turtle Points: 102
  • Male Posts: 548
  • Member since Jul '05
  • "Ghost ride the whip"
Re: locker Vs,spool
« Reply #4 on: Jan 24, 2007, 02:26:56 PM »
weld both and buy some longs!
"Gotta keep it G rated for Marlin"   my runner http://board.marlincrawler.com/index.php?topic=26527.0
LAGEN WAGON
  • Male Posts: 244
  • Just another slow built truck
Re: locker Vs,spool
« Reply #5 on: Jan 24, 2007, 03:13:50 PM »
x3 weld it! Longs and Hydro assist.
85 EX Cab..30 Spline Longfields+Longs hub gears, 37" MTRs on crawlers..Marlin Hy steer.5.29 Detroit, Hydro, V-6 Tacoma Axle, 5.29 E-Locker, Marlin Duels, 4404's front, Chevies rear, Fully armored, Bobbed bed, Warn XDI 9000, Downey Header 2.5 Exhaust. Blah
85 runner 3" lift 30 spline longs/hub gears shave housing,trussed/armored. 4.88 detroit heims hysteer. V-6 rear axle 4.88 detroit. Marlin 4.7 case fully armored downey hi flow exhaust..The grocery getter.
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Member since May '06
  • Philberbuilt
Re: locker Vs,spool
« Reply #6 on: Jan 24, 2007, 04:00:53 PM »
X4 lincoln lock it
rednk1980
  • Male Posts: 1,295
  • Member since Mar '06
  • Pull Your Panties to the side!
Re: locker Vs,spool
« Reply #7 on: Jan 24, 2007, 06:40:41 PM »
weld it alot cheaper and you can put that money is a better place.
  • I'm Legit!!!
  • Turtle Points: 2401
  • Male Posts: 6,715
  • Member since Feb '04
  • AKA Baja Brad
Re: locker Vs,spool
« Reply #8 on: Jan 24, 2007, 07:23:43 PM »
bingo!
Loki
  • Male Posts: 354
  • What are you lookin' at?
Re: locker Vs,spool
« Reply #9 on: Jan 24, 2007, 08:57:51 PM »
my rear was welded on 5.71s and the front had a detroit when it was IFS it wheeled hard. i say weld the carrier and do like the rest have already said. go with longs and hydro
88 turd SAS with some "stuff" under it.
MY BUILD UP THREAD
Shamb
  • Raisin in the making..
  • Turtle Points: 133
  • Male Posts: 3,414
  • Member since Oct '04
  • Proud Parent
Re: locker Vs,spool
« Reply #10 on: Jan 24, 2007, 09:05:26 PM »
Quote
 :ack: :confused:  .... huh?
Ben Dover
  • Member since Jan '07
Re: locker Vs,spool
« Reply #11 on: Jan 24, 2007, 11:04:26 PM »
Spool in mine. Daily driver too.
Last post Nov 06, 2004, 12:42:41 PM
by Ferg
Last post May 09, 2007, 04:39:50 AM
by wombat
Last post Jan 25, 2012, 01:12:59 PM
by Sparkplug
Last post Feb 03, 2008, 11:07:46 PM
by Jordan7118
Last post Sep 24, 2009, 05:46:53 PM
by royota85r
