I just installed a new alt and reg. Per the factory manual the volt output from the alt shouldn't be over 15 volts. It states that if the voltage is over 15 the reg should be replaced. Now since I just installed a new regulator I thought this could not be it. I however switched out the reg again just to be sure. The current volt reading is 65 at no load ie: at idle and the I'm taking the readings directly from the back of the alt pwr supply w/o the wire attached. Has anyone come across this?
